Question about Hitachi Travelstar 7K60 (DK23FA60) Hard Drive
External hard drive not accessible - Hitachi Travelstar 7K60 (DK23FA60) Hard Drive
  • Hitachi Master
  • 27,725 Answers
A Hitachi USB external hard drive is a device that acts as portable, removable storage for your personal computer. If you need additional space to house files on your computer but don't want to go to the trouble of installing an internal drive inside the case, a USB external hard drive is your best option. These drives are "plug and play" devices, which means that very little can actually go wrong. If you're having problems, fixing them shouldn't take more than a minute or two.
Check your connections. A USB cable needs to be connecting your Hitachi external hard drive to your computer. Your external hard drive's power cable also needs to be plugged into a functional wall outlet, surge protector, extension cord or power strip. Make sure your Hitachi USB external hard drive is turned to "On." An "On/Off" button is present on the front of the unit. If the indicator light around said button is not illuminated, the drive is "Off" and your computer won't be able to recognize it. Press it to turn it on and then try to access your drive again. Format your hard drive. If your Hitachi USB external hard drive doesn't currently have a file system on it, you won't be able to use it to store data. Open up the "Computer" icon in the "Start" menu. Right-click on your USB external hard drive's icon and click "Format." Click "Start." This will install a file system on your Hitachi USB external hard drive. After this process is finished, you will now be able to use your drive. Restart your computer. Certain models of computers (especially older models) won't recognize new hardware unless your computer boots with the hardware already connected. Leave your USB drive plugged in and restart your computer. Once you do this, your Hitachi USB external hard drive should appear as normal in the "Computer" folder with all of your other drives. Hope this helps.
Posted on Jan 08, 2013
My Western Digital 320GB external hard drive not accessible
i noticed you ran the chkdsk utility on this drive did you try to repair bad sectors or just files
click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start
you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
I found that you get best results by ticking one box then returning after it has finished then tick the other box if still no joy
try to use the external hard drive in a different computer and check whether you are able to access the data that is present on the external hard drive or you can try to connect it to a different port and check
hope this helps
Jun 27, 2012 | Western Digital 320GB MyBook External USB...
No longer able to access my external hard drice
From your description it sounds like your drive has developed a case of bad sectors. It's a common problem.
I would suggest http://www.r-studio.com/ if you want to try recovering the data yourself.
Or have the guys at http://FreeDataRecovery.us take a look at it for you. They operate remotely over the Internet and work off of donations.
Feb 15, 2012 | Gateway Computers & Internet
My WD External Passport HDD is not accessible. The hard drive is shown in My Computer, but everything hungs up on trying to access.
Hi.
You have to install WD Smartware, which is located on another drive.
THen you will have access to it.
Otherwise the drive is damaged.
God Bless You!
Feb 05, 2011 | Western Digital 1TB My Passport Essential...
Unable to access files
To access the files off the hard drive another way - remove the hard drive from the case and connect it to an USB hard drive adapter and then plug it into a working computer's USB port. If the computer see the hard drive as an external hard drive/storage device and you can open the folders and files then backup your data. This also indicated the hard drive is OK and the Western Digital case/electronics is faulty.
To use this as an external USB hard drive, put the hard drive in an USB adapter case.
Sep 09, 2010 | Western Digital 320GB MyBook External USB...
How do i backup my files using the verbatim external hard drive usb 2.0 . Can i access a user manual online . I received none with the product. maybe the command is so simple or obvious plese help
May I know the Model # of the External Hard Drive?
You can directly copy the data that you want to backup and paste it in the external Hard Drive. You can also right click on the folder/data and select sent to option--->and then select the external hard drive (a drive letter will be assigned to the external hard drive also).
Jun 25, 2010 | Verbatim External, USB 2.0, 750GB...
Sony Vaio laptop could not access 1TB external hard drive
try other usb port, or other computer and see whether the hdd is detected. If still not, try to go to device manager ( http://www.computerhope.com/issues/ch000833.htm ), and then assign a drive letter to the hdd. After that, try to access it from Computer, if not able to access it, format it (use quick format) and then use this data recovery program to recover your files.
http://www.asoftech.com/adr/
Oct 20, 2009 | Western Digital Computers & Internet
Need help to locate Western Digital Passport 160GB External Drive
Could be a hard drive logic board issue since the computer bios recognizes the drive but the computer operating system does not. Not good.
Jun 25, 2017 | Western Digital Passport 160GB External...
External hard drive
ya yiu can do it only you need is to download the drivers from the homesite of teh type of hard drive u r using
u hav not mentioned the name her so just simply try by searching google for the driver
Jul 28, 2008 | SimpleTech SimpleDrive 160 GB External USB...
Computers & Internet Logo
241 people viewed this question
Top Hitachi Computers & Internet Experts
Alun Cox
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
