Faint gray vertical stripe going across screen
    Top Expert:
  • Televison & ... Master
  • 74,377 Answers
Check the connections to panel to T'Con board. Re-seat all the flat cables than comes and goes out to it.
Posted on Jan 08, 2013
jdbouncer
  • 72 Answers
SOURCE: philips plasma tv vertical black stripe
Ok did this happen the first time u turn on the TV. ? If so u might have a ribbon cable disconnect from the logic or u might have a defective Plasma panel. If u have a defect like your describing the IC's on the panel short out and no longer work causing that section of the screen not to function. Only fix then is replace panel
Posted on Apr 29, 2008
  • 3 Answers
Check these videos for repair instructions for black lines.
Just requires some soldering.
Video 1 / Part 1
http://www.youtube.com/watch?v=9NPobj0_GSo
Video 1 / Part 2
http://www.youtube.com/watch?v=ITd6Ahdi4s0
Video 2
http://www.youtube.com/watch?v=qBpg77ZzFFk
Posted on Feb 09, 2009
  • 1039 Answers
SOURCE: Half of my screen will turn in to vertical colored stripes
T-con board. Check lvds cable for tight connection.
Posted on Sep 16, 2009
  • 8457 Answers
SOURCE: their are vertical lines going across the screen
No,U just have a weak signal that all,U use free air right?Get a out door antena or get digital antena,better reception and signal.
Posted on Sep 22, 2009
hsips
  • 43 Answers
SOURCE: It started to get faint vertical lines across the screen
Could be an defective LVDS cable or loose contact......
www.p-ips.eu
Posted on Nov 05, 2009
Turn the TV on black and gray vertical lines going across the screen (like pen stripes) and can only be seen in the black or dark areas after 10-30 minutes they disappear and the screen is fine.
In most of the case, the problem is a defective data buffer IC located on the flex cable between the LCD panel & the panel buffer board, this problem can't be repaired, you have to replace the panel
Aug 29, 2017 | Vizio Televison & Video
Gray vertical bars on screen but no picture
It sounds like you might have shorted out the display panel driver board / boards.
These boards are located at the bottom of the screen and are prone to liquid damage.
Just before this happened, did you happen to spill something on the screen or clean the screen using a spray bottle cleaner?
The only fix I know of is to replace the whole panel but it is usually just as cheap to buy a new TV.
Nov 28, 2013 | LG 55LE5400 55-Inch 1080p 120 Hz LED HDTV...
Panasonic ctp2780sf no picture faint line going vertical across screen
There are two reasons for this fault. A fault smoothing capacitor at the video output voltage rail, or excess of screen voltage. These lines are called 'vertical retrace lines' technically. Check this link for more details. It has a post, which have information regarding this fault. Go to older posts there.
Dec 25, 2012 | Panasonic Televison & Video
My RCA L42FHD37YXII has dark green and light gray vertical stripes on left side of tv it is on all connections
the screen might be broken. when that happened to one of mine i found a crack on the edge of the screen in the glass/plastic? type stuff but it only affected the aria right near the crack. found out my roommate chucked his glasses at it. if not idk
Sep 30, 2012 | RCA L42FHD37 42 in. LCD HDTV
Their are vertical lines going across the screen
Sep 22, 2009 | Sharp LC46SB54U 46 in. LCD TV
Vertical gray stripe on left edge, all pics and text gave a blur
any vertical or horizontal line (any color any size) showing stable on the screen that is the hardware damage at the LCD panel back board ( call panel driver board) . it repair complicate but easy to do change LCD panel (common parts). you need find a PC service dealer to do so.
Feb 07, 2009 | Dell E207WFP LCD Monitor
Ibook screen issues
This is nearly impossible to diagnose via the Web. It sounds like the logic board is at fault, but not necessarily.
Nov 23, 2008 | Apple iBook G4 Mac Notebook
Striped color distortions on Nokia 300 Xa flat panel
This is power supply problem.
1. First u replaced the power out put capacitors , 6V, 12V, etc.
2. cheak the diodes.
Oct 17, 2008 | Computers & Internet
Re: Kodak Troubleshooting
The screen is purple with wiggly vertical lines. I'm going on a trip tomorrow. Help!
Dec 05, 2007 | Sony Cyber-Shot DSC-P52 Digital Camera
Televison & Video Logo
19 people viewed this question
Top Televison & Video Experts
Electro Med Services...
