Question about Whirlpool Kitchen Ranges
Why does the message F5E1 come up on the oven display after I auto-cleaned the oven. The oven is still locked. MOD: RF 265LXTY3, Serial #RW-1117104-X. I have a manual, but it doesn't tell anythi
I set the clean time for 3 hours, and it worked fine until the end.
  • Whirlpool Master
  • 5,188 Answers
The F5E1 message means that the door lock mechanism isn't working. This could be a fault at the lock, the mechanism or the wiring.
First press and hold Cancel to clear the error temporarily. Another code should appear. Press Cancel again to clear the second error. (Some models require unplugging the power cord to reset the code.)
To unlock the door, take a metal wire hanger and bend it. Slide it into the door opening and try to get the lock to move. (The lock is in the middle of the opening.) Then try to open the door. Otherwise, see below to see if you can unlock the door from the back of the unit.
You can check some of the parts by taking off the back panel and attempting to move the lock. Similarly check the motor and the cam that controls the lock. It should take a bit of force to move but not a lot.
I hope this helps.
Posted on Jan 08, 2013
SOURCE: F5E1 error
Whirlpool-KitchenAid-Roper Appliances: Oven Fault Codes:
>>Exception Note:<<
Chart below does not apply to Whirlpool Models using the "Y" line in the products model numbers. Applies to models using 4 digit displays only.
F0-E0 Analog to Digital failure
Disconnect panel for 30 seconds
Should the above error re-appear, replacement of the control is required.
F1-E1 Defective ERC Replace ERC
F2-E0 Shorted Keypad Replace Keypad
F3-E0 Sensor or Sensor Fuse Open Replace Sensor or Fuse
F3-E1 Shorted wire or Sensor locate short and correct it or replace Sensor
F3-E2 Oven over heat Replace Sensor
F3-E3 Cleaning Temp over heat Replace Sensor
F5-E0 Door Error Check Door
F5-E1 Door Latch Check Latch
F5-E2 Door Switch Check Switch
Posted on May 11, 2008
  • 1015 Answers
SOURCE: My oven won't heat
First you will need to verify if the igniter is coming on for the oven burner when the oven is turned on. You will need to remove the oven bottom cover. There is usually two screws at the back bottom of the oven compartment that holds the bottom on. If there are no screws then it should just lift out. You may need to slide the bottom away from you then lift from the back. You will need to remove the oven racks to make enough room to lif the bottom out. Once removed you should be able to see the burner(you may also need to remove a heat spreader on the burner). Now turn on the oven and watch for the hot surface igniter to start to glow. If it does then you will need to make sure the gas orfice and venturri for the burner are not plugged with debris. You can use a small can of compressed air to try and dislodge any debris. Then give the oven gas valve a light tap with a screwdriver or a wrench. Oven gas valve is usually located at the bottom of the oven. Remove the bottom storage compartment to reach it. If you tap it and the burner comes on there may have just been debris in the valve and you may have cleared it. Then turn the oven off and back on completely several times. If the burner comes back on you should be ok if it does not then it could be a weak hot surface igniter or a bad olven gas control valve. Now going back to the start if the igniter does not come on you will need to verify if the igniter is getting voltage. If it is then test the igniter with a ohm meter. The reading should usually be between 500 to 700 ohms. A common problem with hot surface igniters is that they will crack. Examine the igniter for any visible cracks. If the igniter is not getting voltage then you will need to verify that all wires are properly connected and none have come loose. Look for any melted wires from the self cleaning process. You may need to dis-assemble the back of the range to see if any wires have come loose or melted. Now I need to stress to you that safety is important. Be very careful performing these procedures. You can get shocked or possible burned.
Posted on Oct 06, 2009
freetek
  • 5568 Answers
SOURCE: SELF CLEANING MAGIC CHEF OVEN BOUGHT 24 YRS AGO
That's fairly typical but I would suggest removing the shelves and cleaning those with oven cleaner if they need it at all. Expect the door to remain locked for additional hours for safety.
The temperature rises to > 900 degrees F and is necessary to start the catalytic process that consumes the crud.
Sorry I didn't see your message earlier-
Posted on Nov 25, 2008
leroyal
  • 2120 Answers
SOURCE: Oven won't heat. No gas smell. Broiler and stove work.
Bad oven control circuit board. Look up on eBay
Posted on Feb 21, 2009
SOURCE: GE Profile XL44 Spectra gas oven
My Spectra XL44 suddenly refuses to ignite the baking portion of the oven - broiler and top work just fine. The day before it was working fine. Wondered if it was an electrical egnition problem - gas feed or what??? Help!! Mregressor@aol.com
Posted on Feb 28, 2010
How do I find out what FSE1 or F5E1 means on my oven display
If your oven is by Whirlpool (or from that family), the F5E1 error code indicates that the door lock mechanism is damaged, lock motor isn't working or the sensor can't tell if the door is locked. Did you try to do a self-cleaning cycle on the oven recently? Can you open the oven door? Look at the lock mechanism near the top of the door jamb in the oven and check whether the latch move freely from left to right and back. If the oven door is locked, you open the back panel and try to manually move the lock mechanism to open the door.
Please add a comment with the model of the oven for further assistance. The model number will be on a plaque on the oven frame for most models.
I hope this helps.
Feb 01, 2015 | Exercise & Fitness
Self Clean will not work. F5E1 Latch not operating
Before you go working too hard to get you oven to go into the self clean (self destruct) mode....check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! "
May 21, 2010 | KitchenAid KERA205P Electric Kitchen Range
My oven code is F5E1 , my oven was in self clean , now the door is locked
F5E1 is door latch assembly. One way that may work to unlock is to turn circuit breaker to stove off for few seconds then turn back on and door lock should activate and unlock. If not you are going to have to replace the door lock assembly.
Mar 03, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Oven door is locked and won't open
Sorry to hear the "self clean" Gremlins are at it again. Several things have happened, none good. During the cycle at full power for several hours, a circuit on the control board has failed. Various errors are now keeping functions from occurring normally, although sometimes door switches fail causing similar anomalies. At any rate 'self clean' eventually becomes 'self-destruct'. Boards run 150-300$ . Hope info helps- Thanks-ED
Feb 27, 2010 | Kitchen Ranges
My Whirlpool Accubake super capacity 465 self-cleaning oven does not work. When started E1 -F5- appears on screen. Model# RF 386 PXGO. Serial# RJ0525903.
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.%#FDG
Jan 02, 2010 | Whirlpool Accubake RF362LXTT Electric...
Self clean cycle won't start...get message F5E1
F5E1 error means there is a problem with the door latch or relay.
Mar 27, 2009 | Kitchen Ranges
Tried to selfclean my NEW oven but get error message F5E1
Reading all the questions and responses - I had the same problem (would press "self clean", it would run for less then a minute then give the error message), so once I saw the code was E5F1 and what it meant (thanks for whoever posted that), I just pressed on the door for the first minute of the cycle, and self-cleaning then worked. Go figure :)
Jan 06, 2009 | Whirlpool RF378 Electric Kitchen Range
Inglis F5E1 Oven model: IJP85801
The error code F5 E1 is normally associated with problems cleaning
in this case latch not locking. If you did not initiate the cleaning mode then (as u indicate - was baking) then we have a bigger problem. The controller (clock) has malfunctioned. Press any key for about a minute - F2 should appear - then press cancel observe for about a minute - try operation - either back to normal or change control board
Aug 18, 2008 | GE Monogram ZET3058SHSS Stainless Steel...
F5E1 error
>>Exception Note:<<
May 11, 2008 | Whirlpool RF378 Electric Kitchen Range
Kitchen Ranges Logo
455 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
