Question about HP Pavilion dv1000 Notebook
Hp pavillion zd8000shuts down during boot up not hot
Progressively has gotten quicker to shut down has done this a couple times over last months. Then a couple days apart then after 30 mins of use en 5 mins now won't even make it thru startup. Laptop is elevated from table as I know they are notorious for overheating. I hear fan running.
  • HP Master
  • 7,627 Answers
Try the Memory mods, the CMOS battery. You have cleaned the fan and vents, right? May be a component failure, hard to say on a older machine. Take a look at HP support: http://h20000.www2.hp.com/bizsupport/TechSupport/SupportTaskIndex.jsp?lang=en&cc=us&prodTypeId=321957&prodSeriesId=434660&taskId=110
Posted on Jan 08, 2013
wayneard
  • 1901 Answers
SOURCE: HP pavilion DV6700nr laptop looses power
If it is (and it does sound like) a heat problem, the first thing do to would be to make sure the vents are clean and the fan and heatsink are free of dust buildup.
Here is a page from HP to assist you in doing so:
Reducing heat in notebooks
If you go into the BIOS setup, many have an option to monitor the CPU temp. Watch it and see what temp your computer shuts down.
Hope this helps. Thanks for using Fixya.
Posted on Jun 04, 2009
soc21610k
  • 215 Answers
SOURCE: Lap top gets so hot it burns my skin
As for the overheating cause, I can only say if you've ever added on hardware to it maybe the current fan is inadequate for the job. As a solution I would see about getting an upgraded, fan. Or buy a cooling stand, they plug into a USB and your laptop sits on top of it. Hope this helps.
Posted on Jun 21, 2009
  • 111 Answers
SOURCE: hp pavillion dv9000 won't boot. tries to start,
There is a Limited Enhancement Program that includes this model. If you are in the US call 1-800-474-6836. If you are outside US check the HP.com website and search for the Limited warranty enhancement Program.
This is normally a video chipset issue that is embedded in your MB. If your notebook is part of the program, hp will shoulder the repair cost for the MB replacement.
Please vote, Thanks!
Posted on Jun 27, 2009
  • 78 Answers
SOURCE: HP Pavilion dv6000...startup and shut down...over and over !
there is two screws under the touch bad but they don't look like a screw i don't no the name of it in english but they are somthing that the srew goes into it you must remove them and every thing will be easy to open and replace the motherboard
Posted on Oct 25, 2009
  • 17 Answers
SOURCE: HP 6735s screen black out on startup.
The problem is a damage to the MB by excessive heat produced by Nvidia GPU. The only way to fix this permanently is to take out the MB and reflow the GPU with heat. You can find a video on youtube how to do it. You must take out the piece of gel between GPU and cooling unit and replace it with copper bar or penny made prior 1983 - still made out of copper. Also clean the fan. Use heat transfer paste like arctic cool - not a glue, on both sides of the penny. Install win7. Win7 does not use the coprocessor and will help to ran the notebook cooler. Install speedFan 4.40 - free utility to see what the temp is of your GPU and CPU. If you did good job it will stay around 55C. If your HP notebook is still running check the temp. If the GPU is running 80C or more it will melt the connections on the MB and quit working sooner or later.
Posted on Apr 21, 2010
Hp pavillion dv6910us will not boot. Power, quickplay bar, touchpad, and dvd lights turn on only then immediatly shuts down no beep codes or fan sounds are heard.
The motherboard is the problem, common in HP, sub out the ram one stick at a time and try power on each time, remove main battery as a last resort. If none of these help the main board must be replaced.
Mar 23, 2012 | HP Computers & Internet
My dryer is about 5-7 years old. last three months, It will run for a couple of minutes and then trip the breaker. this will happen with or without heat. vent is clean, seems to be more an issue of how...
yes hes probably right,, once a machine gets bogged down by whats inside of it, thats usually time for a new motor , its trying to draw more amps than it can handle just to try and run properly,, when this peaks the circuit breaker in your panel it trips
Jul 07, 2011 | Whirlpool Dryers
My HP pavillion dv7 keeps shutting down. I'm trying to run a system recovery back to the factory settings. It got up to 51% done and then the laptop shut off. Subsequent attempts at booting it back up...
Be sure that the laptop is plugged in to the power supply before you start! Are you restoring from an image in the machine or a CD or DVD disk?
Either way this takes quite a while and most manufactures warn you that the machine will reboot a few times (I have seen some take 5 reboots) to complete the task, so be patient.
The last part of your question concerns me. If you power cycled the computer (turned it off then on) half way through the process it could be hard crashed. If you have the CD or DVD dish this would not be a big problem but if you are restoring from an image this could be bad. Let us know.
Ron
Jan 06, 2011 | HP Pavilion DV7-1232nr Notebook
My HP pavillion w XP home OS keeps shutting
I have just tried to fix on of these.
Shuts down for no reason, the more you try and use it,the quicker it shuts down.
I cleaned the fans, refitted the heatsink and CPU, cleared out all virus/malware infections, thought i had fixed it, it ran for 1 hour in safe mode.
I rebooted and it shut down after 5 minutes.
It seems this model is prone to damage to some solder joints after overheating.
You can fix the solder, but it just breaks it again after about 3 months.
You may get it working longer if you use a laptop cooler stand.
My advice is to sell it for spares and get shut
Nov 01, 2009 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
New motherboard put in my hp pavillion dv6262 in January when computer wasnt even 2 years old. Computer is trying to start up showing a black screen and within a few seconds shutting back down again. Is...
I have reviewed your problem and have the fallowing items for you to check and or try.
Try booting into safe mode and see if the same thing happens.
( F-8 )
Choose safe mode with network configuration installed.
If the unit runs without shutting down, it is a program conflict and not a hardware issue.
Run this safe mode start up, with no external devices connected.
Note... Remove any Flash Cards or USB devices, CD or DVD's .
If the unit runs without shutting down in safe mode, you may want to run a complete restoration of software.
Hope this helps.
Oct 23, 2009 | HP Computers & Internet
HP Pavillion dv4000 is stuck with a 'disk read error'
try with Disk Manager so Format with Low Level Format...run in under DOS
Laptop turns off when charger is plugged in !!
Charger is bad and is not putting out the correct voltage which causes the computer to shut down. Battery probably isn't much good either if it only lasts for one hour. Get new batter and charger. Ebay'ers will help you find one cheap.
Jun 01, 2009 | HP Pavilion dv1000 Notebook
My HP Pavillion slimline won't get out of "start up repair"
Re-boot, keep on tapping F8, enter in, choose
"last known good" there, leave to re-boot,
Or
re-boot, F8 again, safe mode this time,
System restore then once booted into safe mode.
restart it.
Regards.
Apr 07, 2009 | HP Compaq Presario V2000 Notebook
Won't complete booting
Sounds like at the very least, the hard drive is. This is common when a file required by the OS is corrupted, and the OS tries to not damage data so it restarts or shuts down.
Jan 18, 2009 | HP Media Center PC 873n (P9875A#ABA) PC...
HP Pavilion dv1000 Notebook Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
