My central boiler 5036 draft is closing and reopening before it gets to desired temperature
My thermostat is set on 180. the stove draft closes and reopens repeatedly approximately every 3-5 minutes. when it closes the draft the lights dim like it is pulling more current
    New Friend:
It is most likely a loose wire or a bad controller. You should go to your local dealer that sold it to you to have it inspected and tested.
Posted on Jan 08, 2013
james3751
  • 614 Answers
SOURCE: Thermostat sensor is not reading correctly
No you need to change your t,stat. Go to home depot or Lowes and get one easy to install Any problems please get back to me I will walk you thru. Rus
Posted on Oct 29, 2009
  • 767 Answers
SOURCE: the thermostats current setting does not match the
Sounds like you have a problem with the furnace try turning the power off to the furnace and then turn it back on to see if this will get it to run. If it has a sight hole in the bottom door look to see if there is a flash code. then take off door and see what the flash code represents as the problem.
Posted on Dec 17, 2009
  • 56 Answers
SOURCE: thermostat does not follow the setting
If the thermostat is a digital /programmable you may want to recheck program to see if it has changed or been changed. If thermostat is not digital then it is prbably warn out and need replaced.
Posted on Feb 16, 2009
co7196
  • 3433 Answers
SOURCE: thermostat does not shut off A/C at desired temperature
Sounds like a bad thermostat.
Posted on Jun 01, 2009
Illeagle
  • 525 Answers
SOURCE: Where can I get a free Central Boiler owners
www.managemyhome.com usually is a great place to find users manuals
Also www.homemanagement.services.officelive.com
has numerous other website links posted that may be of help.
Posted on Jul 16, 2009
Taco 007 circulating pump stays on even though boiler shuts down
Don't know your specific unit, but in general, heating systems are two-stage devices:
1: Its too cold: the motorised HW/CH valve moved to the required position, and on achieving it, the circulaion pump starts and the boiler is enabled. (The circ pump may start immediately - its not usually important.) The hot water from the boiler circulates through the heat exchanger and/or radiators until the thermostat thinks its target is warm enough, whereupon it disables the boiler, stops the pump and closes/relaxes the valve(s).
2: The boiler is off while disabled. When enabled, it heats the circulating water to a 'high' temperature and seeks to keep it there. If it reaches that temperature, the boiler will cycle on and off as necessary to maintain the set 'high' temperature. (The circulation pump must run all the time the boiler is enabled.) This may be what you're noticing. Additionally, some boilers will run the circulation pump for a little while after being disabled to reduce the temperature if the water in the pipes and boiler.
Your question doesn't say how the pump running corresponds to thee thermostat settings, but if it were stuck on, I think you'd know!
Dec 31, 2016 | Water Heaters
My central heating is set to max 20 degrees but we keep coming home to find house hotter than that. The thermostat is in the hallway, the boiler and froststat (latter newly replaced) are in the integral...
Hi Lyn,
Had the same problem with my system. turned out to be the thermostat in the hallway. Mine is an older electro-mechanical type with contacts that open and close as the temperature changes. (these type of thermostats click as you rotate the temperature dial) What had happened was the contacts had stuck closed even as the temperature rose and thus the boiler kept going. I cleaned the contacts with WD40 oil and everything is fine again. If you have the same type of thermostat this may be the problem. Be aware that if you or anyone else removes the cover of these thermostats there is live mains at the faulty contacts, be sure to switch off the circuit feeding this thermostat or remove/switch off the fuse in the main fuse box. Alternately you could replace the thermostat. If you have an electronic digital thermostat then this solution is not valid.
Good luck
Nov 24, 2013 | Heating & Cooling
How do I set the thermostat on my powermax 155 boiler so that the heating comes into action on a lower temperature
You should have a remote heat setting via a wall or on the front of the boiler dependant upon how it is set up. If in doubt as a Central heating engineer to install a remote one you can have next to you wherever you are in the house.
Sep 30, 2013 | Heating & Cooling
Wickes 102 combi boiler constantly loosing water pressure
It sounds like your thermostat could be the problem. Have you noticed the boiler cutting off at all, or does it run continuously until it goes out on low water?
You stated, "when boiler is on", so I am wondering how you get the boiler on. If your boiler is controlled by a thermostat, you need to check it for a cold draft possibly from behind the thermostat in the wall where the wires come through. The thermostat should never be on an outside wall. The thermostat could be defective.
An aquastat can also control your boiler. If you have an aquastat, check the setting, typically 175 - 180 degrees. You should also have a "high limit" which should be set at 210 - 220. Some people run that high side limit higher; not a good idea - defeats the purpose. If the aquastat is set too high, the boiler will operate too hot and the problem you have will occur.
"pressure rises and pressure relief valve opens" This could mean that your pressure switch is prematurely venting. Check boiler temperature to see exactly at what temperature the T&P valve purges. If it blows off below the high side setting, either adjust or replace. The T&P valves are usually not adjustable. That blow off temperature is stamped on the head of the valve. So, if it discharges too soon, replace it.
Have you actually seen evidence thgat the T&P valve is opening? You may have a bad bladder in your expansion tank and your system may have air in it. Your boiler should have 12 psi when cold and 20 - 22 psi when operating. Check your boiler pressure guage.
this eventually drops below the minimum operating pressure" Technically, there is set point for a NO MINIMUM OPERATING PRESSURE. That is a function of the amount of water in the boiler. If the T&P is blowing off, it will vent water from the boiler and the boiler pressure will go down. There is a minimum operating TEMPERATURE.
Your boiler could be low on water. You will have to manually fill the boiler. Be careful of thermal shock to the boiler. Feel the piping, and fill only when the circulator is running. Make sure the water is not going directly into the boiler. The supply water should go into the circulating supply side which feeds the radiators, radiant floor, or base board circuits.
All this will adversely affect your hot water. The heat exchanger for the potable hot water may have scale build up in it. Using the hot water keeps the boiler running, and a scaled heat exchanger will give you cooler hot water and the boiler keeps running. If this is a problem, you will need to replace the heat exchanger. A better idea is to not use the boiler for your domestic hot water. Why run the boiler in the summer?
Feb 02, 2013 | Water Heaters
The water does not get got enough. I replaced the thermostat, it did not resolve the problem. The water is still warm.
Did you replace the 95 deg thermostat or the 127deg thermal switch ?
Normal temperature control works like this, you turn on power and the boiler heats up. When it reaches 95 deg the thermostat will open and turn off power to the boiler, when it then cools down a little the thermostat will close and it will heat up again.
If the thermostat should fail in the closed position the boiler will continue to heat past 95 deg until it trips the 127 deg thermal switch which is a safety feature.
In your case maybe the 127 deg thermal switch is faulty and opening earlier than the 95 deg thermostat.
Nov 11, 2010 | Saeco Classico Espresso Machine
Install trim and adjust the thermostat on a Grohe shower faucet
Before you install the temperature control knob, adjust the valve body (47111) with a wrench to set the temperature to "100 degree or close to it". Now, place the limit ring to tdc (top dead center) and control knob with the red 100-degree align to it. Your problem may have been the valve's temperature setting is out range when you installing the temperature control knob.
Jun 28, 2010 | Grohe Grohmix Thermostat Valve & Trim -...
Solid fuel stove linked to oilsystem with two zone
Put a temperature operated control (aquastat) on the piping of the wood stove so that if it is on, it will interupt the circuit wired to the oil burner at the X&X terminals of the boiler control.As the wood stove cools off, it will close the connection allowing the oil system to fire.
Mar 04, 2010 | Honeywell Electronic Programmable...
Vaillant boiler no central heating but hot water ok
Could be a lot of things, but the issue appears to center on the heating circulation system. Possible causes I can think of:
  1. Thermostat setting is incorrect
  2. Thermostat is failing
  3. Main circulation pump for heat has failed
  4. Valve for heat circulation is closed
Oct 24, 2009 | KDS Valiant 6380iPTD-01 Notebook
HONEYWELL CM921 ROOM THERMOSTAT
Remember the is a time and temperature controller if you want to use as an ON/OFF controller please ensure you OFF times are set to LOW temperatures for example at 8:00am I want the boiler firing to 21°C at 10:00 I want the boiler to go OFF at 5°C so ensure all so called OFF times are set to LOW temperatures.
Oct 26, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
78 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
