Question about Dell OptiPlex 380 PC Desktop
My disk top door won,t open up to allow me to install a disic
  • Dell Master
  • 7,627 Answers
Open Computer in start menu, right click on the Drive, scroll down to Eject, click. Pull the outer frontcover door down so you can access the drive, push the button on the drive , does it work? Remove the faceplate/frontcover of the desktop something is misaligned or obstructing the button on the drive or it's broken.
Posted on Jan 08, 2013
The passenger door on my c200 2008 won’t open from the inside or outside how can I get it open
you could try taking the door panel off just enough to allow you to get to the leaver so you can pull too open the door.
Oct 23, 2017 | Cars & Trucks
WHEN I PUT DISIC TO MY DVD PLAYER SAYS NO DISC
Sometimes the heads of the DVD player need to be cleaned. There are cleaning disks available at various retail stores or online. I have used them and they clear up most of the no disc issues I have had.
Sep 21, 2016 | Televison & Video
I have a Dell Inspiron 1525 with a cd in disk drive. The door will open but disk won't come out. What do I need to do to remove it?
The CD is loose in the drive. You need to remove the CD drive from the computer and then remove the metal case off the drive then you can remove the CD. Put the metal case back on the drive and install the CD drive back into the computer.
Mar 21, 2013 | Dell Inspiron 1525 Laptop
Door latch
see this causes and fix it. God bless you
Open Lever If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Door Spring If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Oct 15, 2012 | Samsung SMH9187 Microwave Oven
Hi, I have a zanussi wwashing machine model= ghg1200apm. The door won't open. I plugged out the machine after the wash and when i plugged it in again, the door wont open. Can you help me?
Hi.
The door does not open because there is water inside the machine. To open the door you need to empty the tub first.
To empty the tub disconnect power, open the door at the bottom of the machine's front side, unscrew the drain filter cap and collect water using a container.
Usually that is enough to allow the door to open. If the door does not get released, try running a cycle again.
If still no luck, then the door is locked either because the pressure switch detecting water level is clogged with soap or because the power surge has damaged some component. In that case the machine must be partially disassembled to reach the back of the door opening mechanism. The door latch is reachable either from drain filter access or from top of the appliance.
Emptying water through the drain filter and/or restarting a cycle usually is enough to release the door lock.
Regards.
Ginko
Aug 19, 2011 | Zanussi ZWF12070 Front Load Washer
Were do I purchase a new opticle drive door and linkage for this desk top. This pc has two 5.25 bays , the top one has a door that opens and closes as you insert a disk. And the second bay came with a...
What type of assembly do you have for your 2nd Optical. Is it so close together with the top one it won't open? Replacing a door and linkage is very tricky. What would happen if you put the new one on top and the other below it. Should that not work, you may have damaged your new drive. It sucks and I've done it before. Some of those 5.25's are really tight. Let me know if your 2nd drive still works.
May 02, 2011 | Acer AM3910-U4012 Desktop Computer
The door is not opening
1. the door will not open if in the sanitary cycle.
2. the door will not open if the water level is too high. (open access door at lower left on front of machine and use the hose there to drain water out of washer.
3. the door will not unlock without power to machine except for the following:
4. unplug machine, remove top cover by removing bottom screws from plastic clips on back of washer top, then standing in front of machine, using the palms of your hands to sharply push back the sides of the washer's top about 2 inches, allowing top to be lifted off machine. reach down to door latch and manually move latching arm on door latch to allow door to open.
Mar 06, 2011 | LG Washing Machines
Not enough clearance from rafters to install the
Here is the information I think you need.
There is an accessory available from Sears and some home stores called a "low clearance bracket kit". It can be used on any sectional garage door that has clearance problems due to low ceilings or obstructions, allowing the garage door opener track to be mounted much closer to the top of the garage door than is usually possible.
The top guides (which hold the uppermost garage door rollers) on your door are replaced with specially designed brackets that cause the top of the top panel of the door to move inward further as the door opens than standard top guides. The result is that the top of the panel does not rise as high as the door opens, giving the additional ceiling clearance.
I have a photo of this item on this page: http://www.naturalhandyman.com/iip/infgar/infgar1f.html
Nov 25, 2009 | Sears Craftsman LiftMaster Chamberlain...
Can't open the DVD door. Wen I turn on the DVD Player, it starts reading a DVD that's stuck inside, and after a while e turns off alone. The door doesn't open and it seems to have some process runing that...
you'll have to remove the top and remove the disk that way. there's a top bracket on the dvd drive to remove before you can get to the disk. and unplug the unit first!!
Aug 12, 2009 | Philips DVDR3330H DVD Player/HDD Recorder
Can i get a new product key for disic my will not work to upgrade to windows vista
Hello chilcote ,
if u have the original copy of disk just call microsoft support in your country they will send you new key or re-activate your key :)
Jun 11, 2009 | Acer Aspire T690 (AST690UP820A) PC...
Dell OptiPlex 380 PC Desktop Logo
113 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
