Question about Xerox Phaser 6360 Laser Printer
Xerox phaser 6360 maintenance kit instructions
I need instructions on how to replace the maintenance kit in a Xerox Phaser 6360
  • 4 Answers
SOURCE: Phaser 8400/8500/8560 maintenance kit
No, it will not work because the chip (CRUM) is not compatable.
Posted on Jan 13, 2009
  • 2072 Answers
SOURCE: Svc Rprt Flt Xerox Phaser 850. 15.004.45:96992, 22.613.05:96992
Yes you can. What you are experiencing is the drum heaters are not working. The way to verify that is, if you can turn the lights off in the office your in, and then turn the machine back on. On the right side of the machine you will see a fan vent area, slots cut out in the cover where the fan is mounted. Watch through those openings for a glow inside the machine, I very much doubt you will see any glow. There are two 150 watt halogen lamps in there that are used for the drum heaters, one or both of those lamps have gone bad and need replaced. The code you are getting comes from the fact those lamps are not working and the drum does not reach operating temperature.
If you want to replace them or have someone that can, let me know I will send you the instructions. You can purchase those bulbs at any lowes or home depot, anyone who sells halogen light bulbs will have them. Cost should be around $15.
Posted on Jan 21, 2009
  • 117 Answers
SOURCE: XEROX Phaser 8560 - Maintenance Kit
They sell a lot of maintenance kits that way.I worked for a major Tampa are copier company for 10 years and they used every part until it just quit.However, you should line up a maintenance kit at the ready.Sometimes a counter will shut down the copier when it gets to the point where they want it to stop.
Posted on Apr 07, 2009
wrinaldo
  • 185 Answers
SOURCE: RESET INSTRUCTONS FOR XEROX 8560 MAINTENANCE KIT
There is no reset. Xerox never designed a supply reset for this machine.
If you installed a new one, either 1) you've got a bad one (get it replaced under warranty) 2)
the chip is not being read (due to drum maintenance camshaft cracked and out of position
Posted on Jul 31, 2009
  • 9 Answers
SOURCE: xerox phaser 8400 error code 07,007.40:38566 -
http://www.xerox.com/office/8400kb/,case=R1011021647
Posted on Sep 19, 2009
Just put in a new imaging unit to a xerox phaser 6360 and now everything is pink... any ideas how to fix?
Check which colour you replaced and check that everything is seated correctly.
Good Luck.
Jul 22, 2014 | Xerox Phaser 6360 Laser Printer
How do I Reset the Maintenance Kit Life count on a Xerox Phaser 6360
Your just not meant to.
Fit genuine Xerox parts and have no further problems.
Good Luck.
Jul 17, 2014 | Xerox Phaser 6360DN Printer
Xerox phaser 6360 imaging unit stuck
The lid lifts a lever on the right side of the printer that moves a set of gears that releases the imaging unit. If the lever is broken or disconnected, it will not release. You may have to remove the right side panel to resolve it. You have to release the top, by removing 4 screws, and then the panel will release.
May 18, 2012 | Xerox Phaser 6360 Laser Printer
Trying to install a new mpt (shootout) assembly for the xerox phaser 6350. Is there a manual/diagram somewhere that I can refer to? Thanks!
Here is a link to the complete service manual for the xerox phaser 6350 it has full diagrams and step by step detailed instructions for every part of the printer
http://www.scribd.com/doc/42787465/XEROX-Phaser-6300-6350-6360-Parts-List-Service-Manual
Hope this helps
Mar 23, 2010 | Xerox Phaser 6350DP Laser Printer
Xerox phaser 6360 is ghosting. replaced transfer roller but no help thanks Bruce
Most common cause of this is the use of 3rd party toner. This isnt true for all printers but some of the newer Xerox are notorious for it as the 3rd party toners are not produced to the exact specs as xerox. If your not using genuin Xerox toner you have your cause.
If your mechanicaly savy you can completely dissasemble most of the printer in order to clean out the toner. Then start over with new Xerox toner cartridges. I have had to service 2 of these printers in this way, and both were like new when done.
Dec 16, 2009 | Xerox Phaser 6360 Laser Printer
I have a problem with ghosting on a Xerox Phaser 6360. Have replaced the Transfer Roller, Imaging Unit, and Fuser. It looks like the problem is mainly in Magenta. This is not a repeating defect, but a...
I have the same problem with whatever color that used most. The Xerox sent its people over to fix it. However, the problem gets after a few days. Probably, it cannot handle large volume.
Dec 02, 2009 | Xerox Phaser 6360 Laser Printer
Phaser 8560 warns to replace the maintenance kit
Call Xerox. If they can't reset it, They will sent you a new Mtc kit. Thay will want that count sheet. Plus, They will not warrenty any kits over 6 months.
Sep 26, 2009 | Xerox Phaser 8560MFP Laser Printer
Apr 07, 2009 | Xerox Phaser 8560MFP Laser Printer
Xerox Phaser  6360 Laser Printer Logo
66 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
