Question about Mi T M Mi-T-M CM-1250-0MEH NA Chore Master 1250 PSI Chore Master Pressure Washer CM-1250-0MEH
What can of oil to used in a chore master 1250 power washer
I want to know what kind of oil to used in my 1250 chore master power washer
My Mi-T-M 2600 pressure washer will not start, how do I clean the air filters and get a spark from the spark plug.
If you take out the plug check the tip for fouling - that will prevent it from firing properly. Testing for spark can be a pain -easier to just throw in a replacement plug and see what happens.
Did you remember to prime unit and set the choke on startup?
Try some starter fluid - if you get any sort of firing or miss you know you have spark.
Nov 10, 2015 | MI-T M Corp Chore Master 2600 P.s.i....
I need a owners manual for a pressure wahser GCV 160 from honda
MiTM will have that. See mitm.com Honda makes the motor but not the pressure washer. Honda does have manuals if you need one for that GCV160 motor.
Oct 20, 2012 | Mi T M Chore Master Pressure Washer - 5.5...
I don't know how to mix gas and oil. Can you tell me how? Thanks
The CM-1250-OMEH is a electric pressure washer could you check the model number
http://www.amazon.com/CM-1250-0MEH-Mi-T-M-Master%C2%AE-Pressure-Washer/dp/B0015BCB28
Jun 07, 2011 | Mi T M Mi-T-M CM-1250-0MEH NA Chore Master...
I have a 1250 watts inverter and i wanted to know if i can connect it to my 2003 ford explorer without connecting it straight to the battery
Let us look at the math. 1250 watts at 120 volts is w=va Watts equals volts times amps. Or in this case 1250 divided by 120 volts = 10.41 amps. But what is the 12 volt side capable of drawing. 1250 watts divided by 12 volts. 104.10 amps. This is more than what the average cigarette lighter or power port can provide. So, yes you need to connect directly to the battery, you can use a relay rated for 100 A in between the inverter and battery to control the power to the inverter. I would use a good #2 copper welding cable for the power leads. Now, if you are not planning on using the whole 1250 watts, then you can use a #4 welding cable (it is very flexible) for power leads.
JOE
Jan 21, 2011 | Inverter Aims Pure Sine Wave Power...
Garmin Nuvi 1250 stuckin "loading maps" screen
I just plugged my 1350 in (had exact same problem) into computer and deleted the GPX (trip log) and it finally started back up. Deleted all of the favorites and such but it working again.
Feb 05, 2010 | Garmin nuvi 250W GPS Receiver
Oil for a troy bilt 2550 psi pressure washer pump
What fluid and how much is required in the Troy-Bilt 2550 power washer pump?
May 17, 2009 | Briggs & Stratton Garden
What kind of maintenance should i do for my truck?
If you have never replaced the serpentine belt, I'd suggest doing that (keep the old one as an emergenct spare). I'd also change the differential fluid and fuel filter.
Apr 30, 2009 | 2001 Ford Explorer
Can't start the Honda GX160 5.5 HP Electric motor on my Chore Master 2400psi Pressure Washer. Got gas (checked through feed line), new spark plug, switch on, gas, choke ok, throttle a bit funky (about 12...
Is there an oil sensor unit if it is going bad it tells the engine the oil low and engine wont start. I had same problem with my pressure washer, i just unplugged the sensor unit and it started fine ever since
Apr 27, 2009 | Garden
Power source problem
Gasoline-powered chainsaws use a two-cycle engine (requiring mixing of oil and gas). Mobility and power are the main advantages of gas. Disadvantages include the bother and smell of mixing oil and gas, pull cord starting and the additional overall maintenance needed. Electric saws are great for smaller yard chores. They're quieter than their gas-powered cousins, lightweight, easy to start and require less maintenance. However, they have less power than gasoline-powered saws. They also add the bother of dragging a cord around behind you.
Aug 27, 2008 | Remington Polesaw Wizard
Mi T M Mi-T-M CM-1250-0MEH NA Chore Master 1250 PSI Chore Master Pressure Washer CM-1250-0MEH Logo
139 people viewed this question
Top Mi T M Garden Experts
JOHN LAPIER
Are you a Mi T M Garden Expert? Answer questions, earn points and help others
