Question about ZT Group CISNET A7050 PC Desktop
Turn on computer; health screen appears, says boot from disc, stp
The health screen shows the cpu temp, the fan speed, the voltage, etc. then it says, verifying DMI pool data.....
then it says, boot from cd
I don't have the XP cds; CompUSA didn't include them with my Cisnet computer. I begged for them and they would not give them to me.
Someone, please help me to get my OS to boot up or tell me where to get what I need.
Thank you, Rob
  • Dan rogers
    Dan rogers May 11, 2010
    The manufacturers stopped giving out cd's with the computer. Now all the recovery information is normally stored somewhere on the D:\ drive. Unfortunately you will have to call them and find out where this info is and how you can get to it
    Scholar:
  • 88 Answers
I know the didn't include the XP cd with the computer, but they should have provided a system restore disk for you. That is the CD you need to boot and restore your system with. With no restore disk you will need obtain a new copy of XP, and use that to boot from and install a new copy. If you decide that's what you need to do, you should delete all partitions on the hard drive and then format it all as one partition. That way you will have more space on your hard drive.
Thanks for using FixYa,
I hopes this helps,
Eric
Posted on Jan 20, 2009
Computer will run for serveral minutes then shut down. I have new mother board, new power supply. i use cpu paste that is new. the cpu fans starts with a roar and then is very quite.
Hi
The initial fast running of the fan is normal, I'm assuming the fan has as 4 pin connector which is the one with thermal control ( fan speed increases as the cpu gets hotter).
Try booting into the bios, in hardware monitor tab, see what the cpu temp is doing and the motherboard temp. Look for any initial overheating. If the bios screen indicates a temperature rise to say 80 degrees within the 1st 3 minutes of booting, then recheck the security of the cpu, the thermal paste used and whether the base of the heatsink is free from pits.
Look also at the power output of the 12v and 5 v etc circuits, make sure they are within 0.5 volts (0.25 is better).
Check the motherboard and connections, in particular, look for blowing capacitors, or signs of arcing that would cause power to earth. You may have a hairline crack in the circuit that is expanding as the board warms up.
Check the ram is right for the board, remove one module at a time, test with it in and out.
Unplug all hard drives and optical drives, see if it boots to the bios and stays on and then replace each in turn.
Check the PSU.. new it may be but it could be faulty
remove the graphics card if fitted and any other slot in cards, test with these out of the computer, disconnect the usb cables from their headers
After that, the issue may be a fault with the switch, the switch wires or a faulty board or cpu.
Jul 22, 2011 | Gateway 505GR PC Desktop
No boot and CPU overheat warning siren. The CPU fan appears to be working. This old computer was recently packed up and moved, but booted once after the move.
Although the cpu fan may be working, the alarms are set to a temperature setting, so if the heat-sink that the fan is mounted gets clogged with dust ,dirt hair etc.. the processor temp rises and the alarm goes off. And in some cases if the user doesn't shut it down within a certain time period it is shut down automatically.
When you boot it up, the temp might be rising to that setting faster than the operting system can load.
Try a vac to clean it / or compressed air to blow it out
Sep 15, 2010 | Intel D945GNT Motherboard
I wanna check weather my Intel SE7210TP1 is healthy or have any proble
you could hook it up to a scope but you should just hook it up a power supply and a monitor and start it up and when it boots put it in setup (usually by hitting delete key or F10 it will say as soon as it turns on) when in set up just use arrows to system monitor and the fan rpm and cpu temp and running speeds as well as ram will show you the health of the board.
Jan 29, 2010 | Intel SE7210TP1-E Motherboard
L20 197 model (celeron) laptop.
In 19 years of working on computers I've seen 1 bad Intel CPU and it still worked it just showed the wrong processor speed. I'd eliminate the CPU being the problem. Generally if you have a bare system with motherboard, ram, keyboard and video and they turn on the system is good. The video may cause a crash if it's bad somewhere in the bootup process going into windows but it shouldn't stop the initial bootup process. The area I would likely suspect is the hard drive. If the arm inside the drive that controls the heads is loose it can cause the drive to read sometimes when cool and then to start slipping and not read when the system is warmer. If you can get into the bios there should be someplace there to check your temperatures and voltages. Those might be a suspect area. If the power supply isn't delivering the proper voltages or the CPU is getting hot could cause problems also. I'd like to hear more about what you're seeing on the screen when this system fails to boot. Does is show the ram countup, system devices and hard drives as detected in the bootup process? Or is the screen just blank. When it doesn't boot does the hard drive light blink continuously?
Oct 04, 2009 | Computers & Internet
Cpu fan
It isn't detecting your fan as the fan may be dead or the sensor is dead. Both are not repairable but cheaply replaced and fixed with a new fan. The cost of the replacement cpu fan is not that much compared to a cpu. So don't try to make it last a bit longer by hitting the f1 to continue. That will catch up with you pretty quick.
If you want to double check you need to look at either the cmos setup section of a system monitoring software and check to see cpu fan speed and cpu temps. You may not see the speed but you should see the temps. If the temp is getting over 55-60 or more shut down and go get the fan. It's dead. If you see the rpms showing then you might have a motherboard problem.
However I would say you have a dead fan. Replacements are $5-15 and you need to just crack the case and pull the old one and put in the new one. You can take it to a tech but they will charge you to check it out again and then ti replace the fan and some shops will insist on new heat sink etc (those don't ever ever wear out or go bad at all)
Jul 18, 2009 | Porter Cable 75182 Variable Speed Router...
Fatal1ty FP-IN9 SLI + Q9400 + BIOS16 = wrong CPU temp + noisy fan
I notice that the solution from myself was posted as a comment. This may prevent some from locating it. I reposted as a solution under a different name. Hopefully it would help those have the similar problem.
In addition to the following solution, you may also set the CPU core voltage to your CPU specification. My Q9400 VCore specification is 0.85~1.3625V. The BIOS auto setting sets it at 1.1625V. I just manually set it to 1.3625. CPUZ shows that C1E and stepping will lower it as necessary. It should provide the CPU more juice when it needs it, while keeps it cool when it is idle.
Ok, this is myself (Recnelis). I may find the solution for this problem. The trick is to use the beta BIOS 18 and increase the "CPU VTT Voltage" in the BIOS "SoftMenu Setup".
The beta BIOS 18 could be found here:
http://forums.hexus.net/abit-care-hexus/149415-bios-updates-intel-e0-stepping.html
To make the long story short, BIOS 16 is relatively stable for Q9400 but could not recognize the CPU correctly. BIOS 18 (beta) can recognize the CPU correctly but is very unstable - random application crashes, blue screen, freeze, etc.
Here is some "history" about the issue. Fatal1ty FP-in9 SLI uses nVidia 650i SLI. If you google "nVidia 650i 45nm quad core", you will find a lot of people has the similar issue. Many websites suggest that it is because of the difference between the release version of the Intel 45nm quad core and the one sent to nVidia for testing (due to that nVidia turned off Intel's request for acquiring its SLI technology according to some rumors). Some forums suggest voltage is among those differences.
In the BIOS, you may notice that the voltage settings in the "SoftMenu Setup" are different from the actual voltages in the "PC Health Status". In my case, the actual voltages are similar but lower than the settings. One exception is the "CPU VTT Voltage". The BIOS automatically set it at 1.2V, while the actual voltage in the "PC Health Status" shows it is only a little above 1.0V. That is more than 16% drop. 1.0V is too low to keep the system stable. Guys in o/c world usualy increase the "CPU VTT Voltage" up to 1.5V to keep the system stable. Since I'm not o/c'ing my system, I do not go that far. For my particular case, when I set it to 1.31V in the "SoftMenu Setup", the actual voltage in the "PC Health Status" is 1.2V, which is what the auto setting trys to do. For your system, you may want to increase the setting one notch at a time to safely increase the actual voltage reading.
Before this tweak, my system cannot even run more than 30 minutes under BIOS 18. After this small tweak (under BIOS 18), my system becomes a whole lot more stable (no crash so far after a few days of using). It passed RealTemp torture test (using Prim95) many many times without a single hiccup. I tried to post this at least one week after the system runs in stable status; but I think some of you may still be searching for the solution.
More good news for those who want to keep the Fatal1ty IN-FP9 SLI/Q9400 for a while: I even installed Windows 7 RC (build 7100) with the new nVidia Windows 7 mobo driver and graphic driver. Everything is running smoothly so far.
Good luck to your tweaking.
Recnelis
Apr 02, 2009 | Abit Fatal1ty FP-IN9 SLI Motherboard
My DC5000 SFF turns on okay then switches off randomly Help!!
Which fan are you referring to? As far as I know the fan in the power supply runs at the same speed at all times. So if that is the fan you are hearing it may indicate that the power supply is failing. The power supply may be over heating and shutting down. I would try a different power supply if you can get your hands on one.
Jan 18, 2009 | Compaq DC5000 PC Desktop
Will not boot
plug the cpu fan tightly and try again it might be overheating.
Jan 07, 2009 | Intel (5184-0062) Processor Board
Cpu fan noisy/chip fan fail error messages
pils,
Yes. This sounds like a fan issue. The noise often comes from bearings failing within the fan. Also, a failing bearing can make things harder on the motor as it brings the fan up to speed. This is likely the reason that you see increased warnings during the fan speed check while booting because it comes to speed more slowly as bearing wear increases.
I give this a 90% chance that your CPU fan is causing the issue. Since a decent CPU fan will cost you ~$20 online, it's not much out of your pocket if you happen to uncover another culprit.
I'll keep an eye on this post. Let me know how things go.
Apr 03, 2008 | ASUS A8N-E Motherboard
ZT Group CISNET A7050 PC Desktop Logo
Top ZT Group Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Kyocera HP Expert
didi2005
Are you a ZT Group Computer and Internet Expert? Answer questions, earn points and help others
