Question about Motorola Mc659b-pb0bab00100 -mc6598b Wlp/bb/256/1gb/num - Kit
How to install a sd card in a mc659b phone - Motorola Mc659b-pb0bab00100 -mc6598b Wlp/bb/256/1gb/num - Kit
How do i install to the sd card?
Sometimes you can't directly install to sdcard. You may need to move it there by going to settings, applications and click any app and click move to sd card. Not all apps are able to be moved to sd card or some phones/Tablets do not allow moving apps on sd card
Mar 06, 2015 | Samsung Sch R720 Admire - Black metro Pcs...
Memory full, install new SD card, how move files to new SD card?
One of these ought to work:
  1. Remove SD card, connect to PC using a card reader (and adapter if needed), copy files to PC. Connect a larger capacity SD card to PC, copy files from PC to new, larger SD card, install new SD card in phone.
  2. Connect phone to PC with USB cable, then do same process as above.
  3. Back up phone to Google, Samsung, or other cloud resource. Replace SD card with larger one. Restore phone from cloud.
Mar 02, 2015 | Samsung Cell Phones
Unable to calibrate MC65 follow the calibrating instructions but it will not calibrate
Press the blue button and the backspace.
Calibrate.
Doesn't work? Try to reset the Database. Options -> Reset DB
Doesn't work? When the machine is plugged into your computer, open the SD Card, and wipe it clean. And resync the information.
If none of these work, it is a hardware, not a software problem. And that section of the screen is not working.
Sep 20, 2013 | Motorola MC65 Handheld Mobile Computer
I cant save files direct to sd memory all data is going to phone memory direct..how to activate sd memory as my default memory in E5 nokia mobile?
1. To save files received from bluetooth on sd card: Open messaging. Go to settings. Scroll to the end and select other settings. Change the default memory to Memory card. It will ask to copy or move the messages and file from phone memory to sd card. Select move to memory card.
Now all files will go to sd memory card.
2. To save all applications to sd card, open ovi store, go to settings, change installation preference from phone memory to sd card
Jun 07, 2011 | Nokia E5 Cell Phone
Not being install on my phone.installation always fail
You didn't mention what type of phone you have. If you have an Android phone, try powering the phone down and then remove the SD card. Power up the phone without the SD card and then try the installation again.
I have had the same problem with my Droid Incredible with several programs, most notably Angry Birds. Taking out the SD card allows me to complete the installation.
Mar 07, 2011 | Computers & Internet
Will not load sd card
Try to install the sd card with the phone off,if the sd card was use in another phone or device you need to format the sd card.
Good luck!!!
Feb 23, 2011 | LG RUMOR Cellular Phone
If my phone instal game not enough memory
Your phone has 20MB internal memory and Micro SD card slot (up to 8GB) So if u don't have a SD card then you wont be able to add any other information like songs or games in to your phone. Check if you have a SD card and if yes make sure you save and install the game on the card and not the phone memory.
Jan 30, 2011 | Samsung B3410 Cell Phone
Can i install a 2GB micro SD in my LG ku800
The SD card does not need any installation, just put the 2GB MicroSD card into your LG phone and it will work straight away.
This phone need Micro SD cards (smaller) and not regular SD.
May 17, 2009 | LG KU800 Cellular Phone
Installation
To answer install question,I don't see a format option,so you pull the card out and put it in to install.
This phone uses a micro sd card,and most times they come with an adapter, the adapter is just a regular sd card, you need a usb sd card
reader,they are real cheap, Ill poat a great site to get one below.
I do not have this phone,but it depends on the operating system on your computer, if the card is in the phone and you have the plug
for the computer, and plug in the phone,your PC might see the sd card in the phone and it will list the phone as a drive, that is,your hard drive shows as C, so your phone could show as E,f, depends
on what you have for drives. Windows will either pop up a windows
that says, installed phone,or install driver, could not install phone.
This is a page of readers you can get to plug your sd card into your
PC.
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Order=BESTMATCH&Description=sd+card++card+readers&x=0&y=0
The rosewill is what your looking for, this kind of reader, it supports
sd,mmc, you can get anyone, as long as it supports sd card.
Apr 02, 2009 | Samsung Eternity Cell Phone
Installing a music from computer to my phone.
if your sd card is read by the card reader..... its possible to install a new songs.... first you want to do is find a folder to your micro sd that contain a music file.. second be sure that you know the audio format file.. then copy paste audio from computer to micro sd...
Jan 08, 2009 | Motorola Mobility W230 Phone US with...
Motorola Mc659b-pb0bab00100 -mc6598b Wlp/bb/256/1gb/num - Kit Logo
76 people viewed this question
Top Motorola Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a Motorola Cell Phone Expert? Answer questions, earn points and help others
