Question about Frigidaire 18 in. FDR252RB Built-in Dishwasher
Frigidaire 18 in built in dishwasher ...
My dishwasher won't drain... what's up? My dad installed a new garbage disposal on Saturday but we've used the dishwasher at least once or twice since with no problems...
  • Frigidaire Master
  • 43,501 Answers
It is unrelated...
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Posted on Sep 29, 2010
How to remove drain plug from garbage disposal
Good Afternoon Dogman85,
I understand you want to know how to remove the drain plug from your garbage disposal, regarding your Frigidaire dishwasher, model# PLD2850. I suggest contacting the manufacturer of the garbage disposal. They will be able to better assist in removing the drain plug from your garbage disposal. Hope this is helpful.
-Best Regards-
WP
Jun 10, 2014 | Frigidaire 24 in. PLD2850 Built-in...
Dishwasher not draining
Try to check if the hose is clogged..Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line..You should remove this line and clear it form any debris in the hose or the hose connection..Then reattach it before starting your washer again..Thank you..
Please post back how things turned on or further assistance..!!
Regards!!...
Aug 15, 2008 | Frigidaire 24 in. PLD2850 Built-in...
Dishwasher not draining completely after new garbage disposal installed
If you hooked up the drain to the disposal directly there is no vent in the line. Use the air vent on the sink to connect the dishwasher drain hose. If there is no air vent, then you'll have to install one in the sink.
Jan 26, 2014 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Whirpool built-in puddle of water in bottom, food on drain
see this causes and proceed according. God bless you
Belt, Water Pump Although few dishwashers have a water pump belt, if the dishwasher won't drain there might be a worn or broken water pump belt. After removing the lower kick panel the motor can be seen in the front, the water pump belt is on the bottom of the motor.
Drain Pump If the dishwasher won't drain, the drain pump might be defective. Test the pump motor with an Ohm meter. Drain pumps are not repairable, if it's defective it will need to be replaced.
Drain Impeller The drain impeller is attached to the pump and pushes the water out of the dishwasher, through the drain tube and into the garbage disposer or drain line. If the dishwasher won't drain, the drain impeller might be broken or worn out. Replace both the impeller and seal at the same time.
Drain Solenoid Kit If the dishwasher won't drain, the drain solenoid kit might need to be replaced. The drain solenoid is an actuator that opens a flap to allow the water to drain.
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable Pump and Motor Assembly If the dishwasher won't drain, the pump and motor assembly might be defective. If the motor runs during the drain cycle, check for a blockage in the drain line. If the motor won't run during the drain cycle or if it just hums when it should be running, the pump and motor assembly might need to be replaced.
Clogged or Improperly Installed Garbage Disposer If the dishwasher won't drain and the garbage disposer was installed recently, the installer might have forgotten to knock out the drain plug from this disposer. All garbage disposers are sold with a solid plug in the drain tube for situations where a dishwasher isn't connected. However, if the dishwasher is connected, the plug will need to be removed. If the disposer wasn't replaced recently, remove the dishwasher drain hose from the disposer and clean out both the fitting on the disposer and the end of the drain hose. These are the most common places to find an obstruction if the dishwasher won't drain.
Check Valve If the dishwasher won't drain the check valve might be stuck closed. The check valve is a small plastic device which prevents water from returning to the dishwasher after it has drained. If the valve gets stuck closed, it will prevent the water from draining. The check valve is the device that the drain hose is attached to on the dishwasher.
Check Ball If the dishwasher won't drain the check ball might be stuck. The check ball is a small plastic ball in the check valve which prevents water from returning to the dishwasher after it has drained. If the ball gets stuck, it will prevent the water from draining also. The check valve is the device that the drain hose is attached to on the dishwasher.
Oct 16, 2012 | Whirlpool Dishwashers
Dishwasher hose is hooked up separtely from garbage disposal but still dishwasher not draining
Hi - Is the unit making a grinding noise? If so, contact a professional because you may possibly have a defective drain motor/pump.
Oct 13, 2012 | Frigidaire 24 in. PLD2850 Built-in...
For Miele Dishwasher G2470SCVI Need help with remaining water in the bottom. Model# G2470 SCV1 SF Type-HG03. Runs through the entire cycle,long,short ect..everything is clean and dishes look great but
see this causes and fix it. God bless you
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable.
Drain Hose If the dishwasher won't drain the drain hose might be clogged. Remove the drain hose from both the dishwasher and the sink drain to clean it out. The most common place for an obstruction is at the garbage disposer.
Sep 28, 2012 | Dishwashers
Our sink and garbage disposal was clogged up. We got the sink unclogged, but the dishwasher had dirty water in the bottom and won't drain.
Your dishwasher drains into the garbage disposal. It you tried to use a plunger to clear your clogged sink or run the disposal with to much junk in it you may have force debris into the dishwasher drain hose. With both the dishwasher and garbage disposal disconnect from power disconnect the dishwasher drain hose from the garbage disposal. This is usually about a one inch black hose. Clear out any debris in the hose and inlet nipple on the garbage disposal. If debris is compacted far down the hose it will need to be disconnected from the dishwasher end and remove to clear the blockage.
Steve
Feb 10, 2012 | Asko 1385 Dishwasher
Water will not drain. I did have a new garbage disposer installed a couple of days ago, but don't know enough about dishwashers to even see where it connects to the disposer.
Hi Ruthp53, I am JK. I see that you have installed a new garbage disposal and now are having problems with your dishwasher (model FGHD2433KF) draining. I would recommend checking for blockage at garbage disposal and the drain. Also, new garbage disposables normally have a plug that will need to be taken out.
Hope this helps!
Sep 09, 2011 | Frigidaire FGHD2433KF Builtin Dishwasher
My viking dishwasher won't complete it's cycle. The error code that flashes is the heavy pots and pans. We've checked the filter and drains and nothing is clogged. What else could it be?
Have you checked the kitchen sink drain and air gap if one is installed in your kitchen. If using the garbage disposal unit in kitchen then make sure it is clear.
provide model number of dishwasher for further diagnosis.
Aug 28, 2011 | Dishwashers
Won't drain water
New installation? Do you have a garbage disposal, there is a pluged port on the garbage disposal. Is the drain hose free to move, not crushed or twisted, Please provide model name and number.
InMrFixIt
Jun 19, 2011 | Dishwashers
Frigidaire 18 in. FDR252RB Built-in Dishwasher Logo
243 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
