HP Pavilion DV9610US Notebook Logo
Anonymous Posted on Jan 08, 2013
Base system missing
I am running windows 7 ultimate. Upgraded from windows Vista this is 32bit operating system. I also had a chipset issue but found a link to fix this. Any and all help will be appreciated. Thanks
max carson
Level 3:
  • HP Master 7,627 Answers
  • Posted on Jan 08, 2013
max carson
HP Master
Level 3:
Answers
7627
Questions
Helped
1014155
Points
21773
Is this in Device Manager? Did you notice this after the Win 7 upgrade? If so , it's a common problen when upgrading, Is that the only issue? Your Card Reader work? Modem? Co-processor? I have a HP Pavilion DV9320us I loaded Win 7 64bit Ultimate on with similar issues, modem, co-processor, card reader, etc. Use the Win Vista drivers, modify the drivers for Win 7. HP drivers found here: http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?cc=ca&dlc=en&jumpid=reg_r1002_usen_c-001_title_r0001&lc=en&product=3548477& AND change compatibility of drivers , This will give you the general idea: http://www.techsupportforum.com/4478-installing-a-device-driver-under-compatibility-mode-in-windows-7/
5 Related Answers
Kevin Nelson
  • 139 Answers
  • Posted on Dec 20, 2008
SOURCE: I cannot enable my wireless adapter
the drivers needed updating, got to love Windows.
Anonymous
  • 221 Answers
  • Posted on Apr 16, 2009
SOURCE: HP Pavilion laptop freezes daily and i force manual shutdown
It sound's like there could be a compatibility problem, maybe corrupt file's, or missing start up file's, have you tried doing a window's update, or doing a disc check on the hard drive, go to my computer right click the drive then go to propertie's, click on tool's then click check now for drive error's. if that do'es not work you may need to reformat back to the original xp os.
pankaj_dic
pankaj rautela
  • 1252 Answers
  • Posted on Sep 12, 2009
SOURCE: base system device driver missing
INSTALL THE CARD READER DRIVER
Silverdragon
electronic & computer repair& servicre
  • 12061 Answers
  • Posted on Apr 02, 2010
SOURCE: fn and f7/f8 not working
You need to install the special keys manager for all of that.
Anonymous
  • 349 Answers
  • Posted on Jun 18, 2010
SOURCE: missing base system driver and coprocessor vista to win 7
The ‘Base System Device’ relates to the cardbus of the laptop. To resolve this issue download and install the driver from HP website.
1helpful
Hi How can I use Gadmei PT328F tv tuner card (internal)
You can run the Windows XP mode, and run apps under Windows XP mode. Probably your device is not 100 percent compatible with Windows 7, and or it does not have a proper drivers (and the device manufacturer does not provide Windows 7 drivers).
I have an other brain teaser! bought a laptop (sony vaio) it had vista on 32bit.i upgraded to win.7 ultimate. 32bit. could it be maybe it is a 64 bit base? nota geniouse but could this be why my bat
Beginning with the release of Microsoft Windows Vista, 64-bit operating systems are slowly becoming extremely prevalent in today's market. 64-bit operating systems are poised to eventually replace 32-bit operating systems entirely. At the present however, 32-bit applications still vastly outnumber 64-bit applications. Luckily, 64-bit operating systems are capable of running 32-bit operating systems. In 64-bit operating systems, 32-bit applications are installed to a second program files folder, named "Program Files (x86)." Programs installed in the x86 folder can be initialized just like programs installed in the regular Program Files folder.
Open the 32-bit programs folder. Go to Start > Computer > Local Disk (C:), then click on "Program Files (x86)." Open the desired program folder. The executable file for the program will be located inside the folder. Double-click on the file with the ".exe" file extension. As an example, for the QuickTime program you would double-click on the "QuickTimePlayer.exe" file. You have now successfully run a 32-bit application in your 64-bit operating system. Hope this helps.
I cant install nvidia geforce fx 5600 on windows 7ultimate 32bit O.S any solution?
get the vista 32bit drivers for it,ive come across the same problem a few times with 7 on outdated hardware and for me the vista drivers just worked as well
I have intel d865gsa mother board, i want motherboard drivers for windows vista ultimate 32bit or windows 7 32bit. plz give me solution urgent
There arent any official drivers for anything above windows xp which have been released for this particular board.
Windows 7 on the other hand should install a chipset driver and get you up and going automatically with windows update.
When intel (or other manufacturers) do not have drivers for newer operating systems on their websites, it means that they have not been released yet.
With older operating systems, sometimes they stop support for them.. but on newer os's, it is in their best interest to supply them via the website.
Unfortunately, intel doesnt have em. sorry!
2answers
Soud problem
You could find what audio chipset your computer is using, and try on their site.
Look at your computers specs. or use a program like PC Wizard to find them for you
3helpful
How can I change the resolution from 1280 x 800? This is the highest possible according to the display setttings. I have removed the generic pNp monitor. I am running Vista Business. The display adapter is...
Graphics Unable to use the native resolution, such as 1920x1080, 1680x1050 and 1440x900 circuit388.gif Symptom(s):
On some displays, users may be unable to use the native resolution when using Intel® chipset graphics. Resolutions such as 1920x1080, 1680x1050, and 1440x900 are not available in graphics properties.
Cause:
The display's EDID is not read properly when connected to some digital flat panel displays. Display devices describe its capabilities by sending EDID (Extended Display Information Data) to the computer.
Solution:
Intel has released a graphics driver to specifically address this issue; however, there may be side effects to this solution such as longer than normal resume times from standby. This solution will only work with external displays such as DFP displays connected to the computer's VGA port. This driver is not designed to address issues with a notebook's built-in display (Local Flat Panel) or with TV’s connected to the system. This driver is provided as is. Intel has not tested, and does not guarantee, the operation of the driver for this purpose.
For the desktop and Mobile Intel® 945 Express Chipset Families:
If you have a computer that has the Intel® 945G or 945GV Express Chipset or the Mobile Intel® 940GML, 943MGL, 945GM, or 945GMS Express Chipset, click here for drivers that resolve this issue.
For the Intel® 3 Series Express Chipset Families and the Mobile Intel® 965 Express Chipset Family:
If you have a computer that has the Intel® G31, G33, G35, Q33, Q35 Express Chipset or the Mobile Intel® 965 Express Chipset, click here for drivers that resolve this issue.
For the Intel® 4 Series Express Chipset Families:
If you have a computer that has the Intel® G41, G43, or G45 Express Chipset or the Mobile Intel® GL40, GM45, or GS45 Express Chipset, click here for drivers that resolve this issue.
For the desktop Intel® 946 and 965 Express Chipset Families:
If you have a computer that has the Intel® 946GZ, G965, Q963, or Q965 Express Chipset, click here for drivers that resolve this issue.
How to identify your Intel® graphics controller
How to install the graphics driver
I cannot select a larger display mode (resolution, refresh rate, or color settings). How do I resolve this issue?
Error: "The driver being installed is not validated for this computer..."
Operating System:
Windows XP Professional x64 Edition*, Windows Vista 64*, Windows Vista*, Windows Vista 32*, Windows 7*, Windows 7, 32-bit*, Windows 7, 64-bit*, Windows 7 Enterprise, 32-bit version*, Windows 7 Enterprise, 64-bit version*, Windows 7 Home Basic, 32-bit version*, Windows 7 Home Basic, 64-bit version*, Windows 7 Home Premium, 32-bit version*, Windows 7 Home Premium, 64-bit version*, Windows 7 Professional, 32-bit version*, Windows 7 Professional, 64-bit version*, Windows 7 Ultimate, 32-bit version*, Windows 7 Ultimate, 64-bit version*, Windows XP Professional*, Windows XP Home Edition*, Windows XP Tablet PC Edition*, Windows XP Media Center Edition*
This applies to: Intel® 3 Series Chipsets
Intel® 4 Series Chipset
Intel® 82945G Express Chipset
Intel® 82946GZ Graphics Controller
Intel® 82G965 Graphics and Memory Controller Hub (GMCH)
Intel® 82Q963 Graphics and Memory Controller Hub (GMCH)
Intel® 82Q965 Graphics and Memory Controller Hub (GMCH)
Intel® 945 Express Chipset Family
Intel® 946 Express Chipset Family
Intel® G31 Express Chipset
Intel® G33 Express Chipset
Intel® G35 Express Chipset
Intel® G41 Express Chipset
Intel® G43 Express Chipset
Intel® G45 Express Chipset
Intel® Q33 Express Chipset
Intel® Q35 Express Chipset
Intel® Q43 Express Chipset
Intel® Q45 Express Chipset
Mobile Intel® 4 Series Express Chipset Family
Mobile Intel® 945 Express Chipset Family
Mobile Intel® 945GM Express Chipset Family
Problems with Vista Ultimate 32bit
I am running Win 7 but if you right click on the desktop, select the last item on the menu and select desktop icons you can change the icon for the full and empty pics of the recycle bin.
Lou
2helpful
2answers
Is it viata ready or what os do i need for epson tm-u220pb printer
The requirements for epson tm u series printers are.....
Windows XP, Windows 32bit: Microsoft Windows XP Professional 32bit SP3 English, Microsoft Windows XP Embedded 32bit SP2 and Microsoft Windows Vista Ultimate 32bit SP1 English
Windows 64bit: Microsoft Windows Vista Ultimate (x64) SP1, Windows Server 2008 Standard (x64)
I Have Upgraded To Vista Ultimate And I Still can,t add annimated gifs to my laptop can anyone tell me how to solve this problem as i was told that you could only do this on vista ultimate . i upgraded...
For an animated desktop wallpaper in vista ( available only in ultimate version), you will need to run the windows vista ultimate extra updates namely - "WINDOWS DREAMSCENE". After that update you can set any vedio as your desktop baground.
Dvd rom icon missing vista ultimate
reinstall the vista
or try to install a software named'Alcohol120%'
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
