Question about Master Heaters Master B115DT 115,000BTU Fan Forced Air Heater with Thermostat
Manaul handy master fire fan heater hmf13 - Master Heaters Master B115DT 115,000BTU Fan Forced Air Heater with Thermostat
3 Suggested Answers
jgwhomeequip
  • 1902 Answers
SOURCE: need air and fuel filter for model#hmf13 handy master heater
1-888-917-2244
Posted on Feb 11, 2009
  • 8 Answers
SOURCE: Can you use Handy Master Fire Fan Heater Md#HMF
yes,i have the same one.just make sure it is not pointing at anything an keep it in the center of the room.do not use it as a substitue for your normal hous heating system.
Posted on Oct 08, 2010
Where are the filters on a Handy master forced air heater- our smells very bad
Pretty much every kerosene heater I've seen has the filters in the same place. You have to take the cover off, then locate the pump at the back of the motor. Take 2 or 4 screws out of the pump to remove the pump cover, and you'll see the filters in there.
There are some kind of generic directions here: http://www.desatech.com/techDocs/Kerosene%20Heater%20Filter%20Replacement.pdf
I'm sure they apply to your heater too.
Be careful putting it back together, it's reeeeally easy to crack the plastic pump by overtightening the screws, and it will never work right again if you do.
Dec 31, 2010 | Master Heaters Master B115DT 115,000BTU...
Heater fires after a few seconds of blowing fuel the runs a short time and trips breaker
Check the flame sensor. It is a photo type sensor and may need to be cleaned. If that doesn't help, use an ohmmeter to test the sensor. Connect the meter to the 2 wires of the sensor then cover the openning. The resistance should change to several Kohms. Uncover the sensor and the resistance should change to a couple hundred ohms. Replace the sensor if needed.
Dec 27, 2010 | Master Heaters Master B115DT 115,000BTU...
Can you use Handy Master Fire Fan Heater Md#HMF 13 inside?
Oct 07, 2010 | Master Heaters Master B115DT 115,000BTU...
How do i get an owners manual for a Handy Master kerosene heater (HM19)?
I get about 90% of my manuals from the manufacturers web site. Give that a try. You may have to do a bit of research, I do not recognize the Handy Master brand, it may be a relabel from another manufacturer.
Good Luck
Gilshultz
Dec 02, 2009 | Master Heaters Master B115DT 115,000BTU...
Fire stoppes and fan still runs
1st take a air gun and blow in the fan to clear of debris. 2nd make sure to push your reset button on the back by your fan. Last you can calibrate your flame/heat by removing the fan housing & you will find 2 set screws try a small 1/16 turn on them and try to run, should run better for you.
Oct 09, 2009 | Master Heaters BLP375AT
Sticky fan
remove the outer cover and then the plate at the back of the motor, then lube the back of the motor and the inside of the plate with a lubricant spray. (wd40) put it all back together.
Jan 10, 2009 | Milwaukee Tool Master Heater B200 Series...
Master Heaters Master B115DT 115,000BTU Fan Forced Air Heater with Thermostat Logo
41 people viewed this question
Top Master Heaters Heating & Cooling Experts
Gil Shultz
Mike Squire
paulcarew
Are you a Master Heaters Heating and Cooling Expert? Answer questions, earn points and help others
