Question about Breville BKC700XL Stainless Steel
Breville BKC700XL will not turn on
I've changed to a power outlet that works with other devises, and when I try to power on (my 2-year-old) machine won't turn on. Does it have a fuse?
4 Suggested Answers
EwingElect
  • 276 Answers
SOURCE: Have a Breville Ikon Panini Press ... doesn't work
First point of call would be to check the microtemp, which is the small heat regulating fuse inside. If that has blown, you most likely will have no power.
Otherwise call you local Breville Service Centre. If you're in Australia you'll find them at http://www.breville.com.au/care_agentsearch.asp
NOTE: In Australia, this model has a Two year product guarantee. Check your receipt as it may be under warranty!
Posted on May 20, 2010
  • 232 Answers
SOURCE: I have a Breville Fresca
Turn your machine off, then push and hold the 1 and 2 cup buttons and then while still holding them push and hold the power button. Wait until the clean cycle begins.
Posted on Oct 03, 2011
azisme
SOURCE: My Breville BOV800XL doesn't have any power.
My BOV800XL did the same thing. Of the three parts you mention the thermal fuse is by far the easiest to test and in my opinion the most likely to go out first. Check it with a meter. If you have trouble locating it read the FixYa solution for "The Breville BOV650XL will not power on." Check it for continuity like you would any fuse.
I found replacement parts at ereplacementparts.com. The thermal fuse assembly was $23 when I checked. Or you could just replace the actual fuse portion of the assembly with a comporable fuse such as http://www.mcmelectronics.com/product/NTE8213. Basically you need a 216*C thermal fuse. These can be had for less than $2 plus shipping. Buy a few just in case.
I just ordered my fuses today so I can't report on the success of my repair, but I am confident the new fuse will solve the problem.
Posted on Nov 07, 2012
Breville bov800xl wont turn on. Reset option?.
If the screen turns on and looks like it's working but there is no heat, then the problem is the thermal fuse. It takes reassembly and a $5 replacement fuse. I replaced mine with one of the same specifications and it lasted a month. I replaced it again with one that trips at a 10 degrees higher setting and it's been good for a couple of years now.
Feb 25, 2015 | Breville BOV800XL 1800 Watts Toaster Oven...
Keurig troubleshooting
the switch mechonisum is defaulted in side the back panel.it can be inspected to make sure contact is being maid by the power light on the frthe unit
May 01, 2013 | Breville BKC700XL Stainless Steel
Would not power on
then you arnt getting power to the unit at all ! plug somthing ealse in the same w plug u are useing
Water not coming out. How do I clean the machine?
The Instruction Booklet for the Breville Gourmet Single Cup Brewer for the BKC600XL / BKC700XL can be found here:
http://www.keurig.com/customer-service/brewer-registration-and-support/~/media/Files/Keurig%20Brewer%20Manuals/Breville_BKC700XL.ashx
The booklet has an extensive section on cleaning.
Mar 12, 2011 | Breville BKC700XL Stainless Steel
I used the filter with my own coffee and now it is clogged. How do I fix it?
The Instruction Booklet for the Breville Gourmet Single Cup Brewer BKC600XL / BKC700XL can be found here:
See Page 32 for Troubleshooting. You may need to unclog the Exit Needle and run a cleansing brew.
Mar 06, 2011 | Breville BKC700XL Stainless Steel
Can't find my manual. How do I clean it?
http://www.scribd.com/doc/21061955/Breville-BKC700XL-Manual
Found your manual....Click or paste the above link to the site with it! If you cannot find what you are looking for inside manual, run down to the nearest home store or grocery and purchase descaling solution and follow directions for use from the back of the descaling container. Most machines require frequent descaling (once every 3 months) depending on your water quality. Hope this helps!
Mar 01, 2011 | Breville BKC700XL Stainless Steel
The lights are not on when plugged in.
Make sure you have power at the outlet being used.
Secondly make sure you have switched on the power switch at the rear of the right side of the machine.
For additonal Troubleshooting tips your Instruction Booklet can be found here:
Missing the instruction manual for a breville bxc700xl coffee maker just purchased from bed, bath and beyond. Any help?
You can visit the Breville Support website for the BKC-700XL. The owner's manual and quick start guide are available for download (PDF format) or on-line perusal.
http://brevilleusasupport.com/product/bkc700xl
May 01, 2010 | Breville BKC700XL Stainless Steel
Breville BKC700XL Stainless Steel Logo
134 people viewed this question
Top Breville Coffee Makers & Espresso Machines Experts
Steve Banks
Tally Girl
Tally Girl
Are you a Breville Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
