Question about Acer Aspire™ T180 PC Desktop
COMPUTER CHECK SUM ERROR'S ?
When ever I switch on my computer, I found a messages as CHOM's CHECK SUM ERROR'S ? Now How do I get rid off this problem?
Please help me immediately....................?
    Problem Solver:
  • 35 Answers
Go into the bois and turn off the "error msg" or "error on halt"
Posted on Jan 21, 2009
    Problem Solver:
  • 16 Answers
If you can enter bios (usually by pressing f2 or del), then load the default settings, otherwise, you will have to position the jumper properly, instructions for that are as follows.
1. Touch an exposed metal part of the case to ground yourself.
2. Unplug the power supply from the wall.
3. Move CMOS reset pins to short pins 2 and 3, then wait 10 minutes.
4. Replace CMOS reset pins back to 1 and 2.
5. Replug the power supply and boot.
Posted on Jan 20, 2009
Bad Locksum BIOS CD_Rom not found when I try to
it's not locksum ,its Check SUM or CRC errors.
what OP, are you running,? windows what. i guess.
the CMOS battery just died.
install a new one.
all puters this old do that, the battery is good for 7-10 years,
and all fail.
DO NOT FLASH your BIOS, fix the real problem first
when the battery dies, all our bios setting were lost
including boot device, and order
fix battery
then go into BIOS and put back boot order.
Mar 22, 2017 | HP Pavilion a815n (PS512AA) PC Desktop
M3plugin.dll problem
Did you already tried doing a system restore on the time that everything was working fine? if not yet tried doing that first and hopefully that will correct the problem but if still have the same problem you can try some anti malware software like Malwarebytes this will be helpful to you....
Oct 14, 2008 | Intel Motherboard
Pitco Fryer is displaying CHECK SUM FAILURE - in almost 10 years, I have never seen this display - what is it????
Check sum failure is an error on the configuration of the computer board. You have to reset the computer board to factory setting to get rid of this error (if check sum failure appears every now and then on the display). Make sure that you have the list of your cooking parameters before you reset the board to factory setting. Any settings made prior to a factory reset will be lost. Details on how to reset the board to factory setting can be downloaded at pitco website on www.middleby.com.
Feb 20, 2011 | Pitco Frialator SG18S Deep Fryer
When I logon to my computer, 2 little error messages come up with the same message: Runtime error 21 025D49D2. I can exit out of one of them, but if I try to exit out of the second one my screen loses...
Having Problems With Error 21?
Cause: Error 21 takes place when the system is misconfigured or its essential files are missing. Such problems occur when a PC is not maintained properly and has accumulated many critical issues that require immediate repair.
Solution: To repair Error 21 correctly, download and install the repair tool below. This tool was design to successfully diagnose, find and fix the problems on your computer.
http://www.restoreguard.com/p/error-21.html?keyword=Error%2021&gclid=CKXWrq7il6UCFS9e7AodYkPWHw
I found this by google.com searched "run time error 21 025D49D2"
it came up with run time error 21....
click on this link above...
good luck...
Nov 11, 2010 | HP Computers & Internet
My computer cant boot and brings a message that bios check sum errordetecting drive Asystem disk not found
check cable that connect motherboard and hard drive OR there is some problem in hard drive, OR motherboard
May 26, 2010 | Computers & Internet
I bought a 1 TB external just a month ago and my saved music folder on there gives me the message "cyclin redundancy check" error..what is the best way for me to recover these files?
When your computer writes a block of data to a disk-drive, it calculates a "check-sum" value, and writes that value, along with the data. When your computer reads that same block, it also reads the check-sum value, and it recalculates the check-sum, using the same "Cyclic Redundancy Check" algorithm.
If the "new" check-sum matches the "old" check-sum, then it is declared that the data was correctly written & then read. Any "mismatch" indicates an "I/O-error", i.e., at least part of your disk-drive is dying, even though it's only a month old.
Maybe, it's only one file in one folder that has become "unreadable", but it could be much more.
Copy all the files that you can, and exercise the warranty on the disk-drive to get it replaced.
Apr 07, 2010 | Office Equipment & Supplies
Help
Greetings,
When you upgrade your computer to Windows XP, you may receive an error message that is similar to one of the following: C0000221 (Bad Image Checksum)
-or- STOP: C0000221 - Bad Image Checksum in ModuleName
-or- STOP: C0000221 - Bad Image Checksum. User32.dll is possibly corrupt. The header check sum does not match the computed check sum.
Please go through the below mentioned link:
http://support.microsoft.com/kb/326687
Sep 20, 2009 | Microsoft Windows XP Professional for PC
''Bad Image'' Error?
First download a copy of Dr. Web, Malware Bytes and Superantispyware. Run these one at time. This should get rid of all your problems, if not a Windows repair is next.
Mar 29, 2009 | Computers & Internet
Engine light on
It comes back as a Internal Control Module Memory Check Sum Error. Unplug the battery positive terminal for a few minutes. Hope that gets rid of it. If it doesn't you are likely looking at changing out the engine computer.
Dec 03, 2008 | 2000 Dodge Grand Caravan
Check sum error denioted in win xp
you internal cmos battery is flat needs replacing. then reset time and etc in bios
Oct 10, 2008 | Televison & Video
Acer Aspire™ T180 PC Desktop Logo
102 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
