Question about Dell Dimension 4600 PC Desktop
Power led light is a steady orange but pc will not power up
Dell inspiron 531s when turn on pc power light stays amber fans run but the pc dont boot up
  • Eric Jan 25, 2013
    Like Walter said, The unit is receiving power, however, the power supply is no longer putting out enough juice
  • Eric Jan 25, 2013
    Like Walter said, The unit is receiving power, however, the power supply is no longer putting out enough juice to run all components
  • Dell Master
  • 998 Answers
If the power light is blinking amber, the computer is receiving electrical
power, a device might be malfunctioning or incorrectly installed.
- Remove and then reinstall the memory modules (see "Memory" on
page 112).
- Remove and then reinstall any cards (see "Cards" on page 116).
- Remove and then reinstall the graphics card, if applicable (see "Cards"
on page 116).
• If the power light is steady amber, there may be a power problem or an
internal device malfunction.
- Ensure that all power cables are securely connected to the system
board (see "System Board Components" on page 107).
- Ensure that the main power cable and front panel cable are securely
connected to the system board (see "System Board Components"
Copy and paste this link to your internet browser for your computer's manual.
ftp://ftp.dell.com/Manuals/all-products/esuprt_desktop/esuprt_inspiron_desktop/inspiron-531s_owner%27s%20manual_en-us.pdf
You can also go to support.dell.com
Posted on Jan 08, 2013
    Sergeant:
  • 378 Answers
Replace power supply! amber led = bad power supply I'm DELL certified
Posted on Jan 25, 2013
  • 2427 Answers
SOURCE: black screen on start up
yep
unplug the system
open the case
look for a battery and take it out
take out the memory (rams)
wait ten minutes
press power button 5 times
put everything back in
and boot it
Posted on Jan 12, 2008
SOURCE: Dell GX270 won't boot up with solid amber light on Power button
Check motherboard for bad capacitors. I had the same problem and when i had bad capacitors replaced everything is ok.
Posted on Feb 20, 2009
SOURCE: Turning on DELL 530 the orange led remains on
I'll save you 3 hours on the phone with DELL. Same problem.
If you are OK with this, turn power off, discharge system by pressing on button for 5 seconds. Identify the slot for the phone jack/modem. Remove it. Plug in and turn on. If that is the problem, turn off and insert the card in the adjacent slot. They asked that I replace the motherboard, so if you're under warranty, call them.
Posted on Dec 10, 2009
joecoolvette
  • 5660 Answers
SOURCE: My Dell XPS 420 will not turn on. Power light
Hey! Nice Computer! ( At least while it was working! Specifications show some high-end hardware parts)
Steady amber light on the Power On light, means a bad power supply.
The Dell XPS 420 uses the standard ATX style of power supply found in 90% of computers out there.
(Personal computers. Not the Cray Supercomputers!)
This is Dell Support, and the User Manual - Removing and Replacing Parts - part of the manual,
http://support.dell.com/support/edocs/systems/xps420/en/OM/HTML/parts.htm#wp1466871
From Me:
1) Computer unplugged from power, computer case open. TOUCH the metal frame BEFORE you reach inside.
Your body carries Static electricity.
Static will fry out computer hardware components.
You won't see it, or feel it.
Computer unplugged from power, you are safe.
Touch the metal frame Before reaching inside, your computer is safe.
Should you get up for any reason, walk away, then return, Touch the metal frame again)
You either have a 375 Watt, or a 425 Watt power supply.
I would recommend a power supply with more Wattage, and more Amp's on the 12 Volt power rail.
The Dell XPS 420 comes with an Intel Core2 Duo processor, or an Intel Core2 Extreme processor.
These puppy's can use a lot of power when gamin', or other intense programs are being used.
The Nvidia GeForce 8800 Series of graphics cards offered, use a lot of power when maxed out.
The motherboard with the Intel X38 motherboard chipset, uses a lot of power.
I would recommend a 600 watt power supply for a replacement.
My recommendation would be an OCZ StealthXStream 600W
Why?
1) If the temperature of this PSU is kept under 118 degrees Fahrenheit, the PSU can put out 728.8 Watts reliably. (47.9 degrees Celsuis)
2) It has Four - 12 Volt power rails.
EACH power rail can handle 18 Amps.
That's a total of 72 Amps!
3) It has all the power cables you'll need.
A) 20 + 4-pin ATX motherboard power cable
B) 8-pin 12 Volt power cable (8-pin EPS)
C) 4-pin ATX power cable
D) SATA power cables [ 3 ]
E) Peripheral power cables, (4-pin Molex) [ 6 ]
F) 6-pin PCI power cables. [ 2 ]
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3092557&CatId=106
Not advertising for the above website, nor the PSU manufacturer. Recommendation supported by personal preference, and experience.
Information about the various PC power cables and connectors,
http://www.playtool.com/pages/psuconnectors/connectors.html
Posted on Jan 04, 2010
  • 561 Answers
SOURCE: solid amber light ON Dell Inspiron 530 desktop.The
Hi
Please try the following
1) Remove ALL wires from thw back of the PC
2) Press and hold the power button on for approx 15 seconds
3) Replug only the mains power wire and the monitor cable and then retest
Please advise of outcome
I hope this has been useful
Posted on Mar 05, 2010
When I power on the desktop the power button LED turns to steady amber and the fans race constantly at high speed. The system does not seem to complete POST or boot into the O/S. I changed the CMOS Battery...
Can you check at the back of the computer to see what the diagnostic lights are indicating 4 led's (eg yygg - yellow yellow green green) - post the result and i may be able to provide a soltuion
Sep 24, 2013 | Intel K83v0 Dell Motherboard Inspiron 560...
Dimension 3100 turns on the power button has a steady orange light there is also an orange light on motherboard cpu and power suplly fans working but wont bot up
Blinking amber (orange) indicates a problem with the power supply inside the computer. If the system cannot boot and there is a solid amber light, this could indicate a problem with the power connections for the CPU on the system board (see "Power Problems" in your Owner's Manual).
Mar 06, 2011 | Dell Dimension 3100 PC Desktop
My Dell Inspiron 530 used to freeze up ever so often. I would have to manually shut it down and restart.After a while I found out that running the AVG scan it wont shut down so often.One day while booting...
This is a system fault error condition, including the power supply. Only the +5VSB rail on the power supply is working correctly.
ports to see if anyare damaged and then try powering on the system to see if you get a green power button.
Feb 23, 2011 | Dell Inspiron 530 Desktop Computer
I put in a dynex 400 wps power supply a couple of years ago and it has been working fine. Got a wireless keyboard and mouse for xmas installed it and now get a steady amber power light and the blue hard...
Solid AMber power LED indicates a failure of the motherboard or an item connected connected to the motherboard. Disconnect all external connections except power and see if the indication changes. If yes, re-connect one at a time till the fault is found. If no, remove all PCI Expansion cards, see if any change, if yes, again try them one at a time till issue ID'd
If issue still occurs, failure is most likely the motherboard
Dec 26, 2010 | Dell Inspiron 531s Desktop Computer
Steady amber Power light
You are looking at a new mother board. I would take it to a certified technician shop, so they can run a stress test on the motherboard for final benidiction.
Aug 13, 2009 | Dell Dimension E510 Dual Core 2.8 Ghz...
Inpirion 531s no boot no beep
It could be a faulty power supply try replacing that with another one ,if that doesn't work it's very lokely the motherboard is kaputt!..Good luck John
Aug 04, 2009 | Dell Inspiron 531s Desktop Computer
Solid Amber light when starting the Inspiron 530 . Every time i start the Dell inspiron 530, the solid amber light comes on and it dont start. As per Dell user manual i have tried everything but of no use....
Amber led simplifies a start-up-error. This could be a number of things.
For example:
Check if HDD is connected properly
Check if RAM is connected properly / also if this is damaged your pc wont start.
Check your m/board for any loose capacitors an if they are not popped at the top.
Your LCD screen is properly plugged in to the m/board and if the cables aren't damaged they are very thin and fragile.
also could be the power supply...
Goodluck
Ryno Gerber
Jul 30, 2009 | Dell Inspiron 530 Desktop Computer
Dell Inspiron 530 boots then the screens turn off to orange light
Is the PC actually doing to sleep or is the display just amber with the fan and power light on the PC still running?
Do you have multiple video cards or multiple ports?
You may have the monitor plugged into the non-default port on your video card or the wrong card. Try plugging the monitor into another port as the PC should use all outputs when booting but then define a default display once the driver is loaded. Also take a look at the default video display in your BIOS settings. Depending on what your setup is you should be able to choose between (onboard, PCI, AGP)
Jun 10, 2009 | Dell Inspiron 530s Desktop Computer...
Power button stay amber, dont finish booting
Generally, this is an indication of a motherboard failure. Remove any items connected externally and and expansion cards intenally and see if the Power LED indication changes. if not changes, then replace the motherboard
Mar 31, 2009 | Dell Dimension 3100 PC Desktop
Dell Dimension 4600 PC Desktop Logo
363 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
