How to use an eurowrapper bundling gun - Computers & Internet
    New Friend:
Yes, there are no directions and no YouTube video to show you.
* Feed the locking clips into the gun (similar to staple refills)
* Feed the strap from the bottom reel into the back of the gun (ridges down).
* Pull liberally from the front of the gun all the strap you need to go around your items.
* Here's the tricky part: take the end of the strap and shove it into the front end of the gun, immediately adjacent and below the strap that is already there. They will be ridge-to-ridge.
* Pinch the two straps together at the front of the gun and pull the slack out by pulling the single strap from the back of the gun.
(The idea is to pull the inserted end about 1/8 inch into the gun so that it will be in the locking clip.)
* When it is tight, pull the trigger which will cut it to length.
Posted on Dec 01, 2014
  • 7,627 Answers
Very carefully. What kind of computer does the gun work on?
Posted on Jan 08, 2013
Roofing how many bundles of roofing singles douse it take for a house roofed .
measure lenth x width.divide by 100= amount of squares. 3 bundles per square
Nov 02, 2016 | Cars & Trucks
How to reload staples.
If this is a staple gun then you need to release the tab on the back of the gun. It will release a long spring with a push rod on it. Insert the new staple bundle and replace the push rod. If this is a desk top stapler then pull the top until it opens. Set staples in and close the top again. Make sure to clear out any staples that may be loose or lodged before.
Nov 29, 2015 | Staples Tools & Hardware - Others
We are going to order CISCO2911-v/k9 voice bundle, and we are not sure if we suppose to order user license in order to register IP Phone, or the voice bundle itself has the license
As to the CISCO2911-v/k9, the Unified CME and SRST voice bundles include 25 CME or SRST seats across all the platform bundles. If you wish to add additional users, you need to order additional feature licenses to add up to the desired user count. Finally, if you are ordering Cisco Unified Communications Manager Express, you need to purchase IP phone licenses for each phone that you will connect to the CME system.
Apr 13, 2015 | Computers & Internet
Bostitch SB-1850BN. I bought a bundle of nail guns over a year ago, today I go to use this gun for the first time and just get a very poor poof of air coming out, no nail. I've tried it with pressure in...
At the end where you attach the air hose is the nailer imprinted with the words "add oil"? If so; add a few drops of oil designed for air nailers.
Also check to make sure no nails are stuck in the tip of the nailer and the return mechanism is reset.
Oct 20, 2017 | Stanley Bostitch Sb-1850bn 18-gauge Brad...
I need driver for my hard drive to register on my computer
Do you run a MAC? If so,this site says"software is bundled...and "Software not Universal". check it out.
Mar 27, 2010 | SimpleTech 1TB External USB 2.0 Hard Drive...
Replace handle bars
Mine had wiring inside the bars as well. Basically I removed the controls from the bars, and removed the 2 bolts holding the handle bars on. I removed the RIGHT side gas tank after draining it. I intended on cutting the wires to the connectors, pulling the wires out of the old handle bars, and pulling them back through the new bars. Note: Mark the black wires very carefully, since there were 5 black wires in the two connectors and they are all unique wires. The colored wires were easy, just match them back up. Several tricks I found on line. Use a string and a bolt to fish a pull line down through the new bars then pull the wire bundle through. This worked great on both left and right wire bundles. I then bolted the new handle bars in place and remounted the controls. I then replaced the shrink tubing up the bundles that hid the actual wires as they came out of the handle bars down to where I cut the connector wires, behind the right side tank. Next I stripped and tinned all the wires I cut (twist and get a little solder to stick on the wires) and stuck little pieces of shrink tubing up or down the wire so after I resoldered the wire I could shrink the insulation back over the splice. I picked up the shrink tubing and some extra wire a home depot. I had a soldering iron, and heat gun so away I went connecting the dots again. Litte tedious but hey. It saved me somewhere between $500 -$700 bucks which is what the harley shop quoted before I started. I tested each function, then reinstalled the gas tank and tightened up all the stuff. Below is the pin out in case you do loose a wire marker, like I did. Good Luck.
Nov 20, 2008 | 2008 Harley Davidson FLTR Road Glide
Replace handle bars
Nov 10, 2008 | Harley Davidson FLTR Road Glide...
G-Con 3 Gun
Try Computer Exchange (cex.co.uk) - they might only have them instore but worth trying online - they sell them for 15 quid. I also get the impression that the Namco G-Con 45 is compatible with TC4 but not 100% certain!
Sep 26, 2008 | Sylvania 6319CA 19 in. Combo
Computers & Internet Logo
115 people viewed this question
David Payne
David Payne
