Question about Microsoft Xbox Console
XBOX PROBLEM During a game the game pauses and comes up with the following notice "Reconnect the controller to controller port 1 and press start to continue" I usually at this stage follow the solutions as per screen advice, sometimes I have taken out my controller lead and reconnected but the same problem has continued!! Help
I have had the same problem in the past. The problem with mine was the controller wires were loose from being wrapped tightly around the controller while not in use. Try pugging in a new controller or one you know does not have issues. Good luck.
Posted on Jul 03, 2007
SOURCE:
How do you turn my kind of Minecraft to 2 player?
leave the controller plugged in and look at the menu.
Dec 16, 2013 | 1995-1997 Chevy 1500 Truck Ignition...
My xbox remote won't pause during playback
I hate to say this but it may be time for a new xbox remote.
Jun 07, 2013 | Microsoft Xbox 360 Wireless Controller
GE error E61
E61 means you have the neutral and the L2 wire either reversed or in the wrong position. ENTER TEST MODE SEQUENCE by doing the following . 1.Disconnect thepower for 30 seconds.2.Reconnect the power and within 30 seconds press the sequence of buttons listed below.3.Press the "SIGNAL"button.4.Press the "DELAY START"button.5.Press the "SIGNAL"button.6.Press the "DELAY START"button. Now after you have fixed the reveresed wiring problem you will need to remove the fault code fromt he memory otherwise the machine will not work. To remove the fault code do the following ENTER TEST MODE
SEQUENCE (cont.)
You will notice "t01". To choose the test mode that you want toverify, turn the knob to the desired test mode setting.
Push the start/pause button.To cancel the test mode, press on "power".
You will be able to choose another test mode and again press on "start/pause".
The display error codes test allows the service technician to examine and clear the fault log.
DISPLAY ERROR CODES TEST
(t02)
The control shall display the most recent error in the fault logupon entry into the display error codes test. If there are no errors in the fault log, the no error code "E00"shall be displayed on the 7-segment display.
The control shall clear the displayed error from the fault log if the start key is pressed during the display error codes test. After clearing thedisplayed error from the fault log, the appliance shall display the next most recent error from the fault log.
After clearing all errors from the fault log, the control shall display the no error "E00"code on the 7-segment display.
The control shall log the last 8 error codes in the non-volatile memory stored in a circular list.
The control shall avoid logging multiple instances of the same error code. now unplug the appliance for about 30 seconds and replug and everything should be fine
credit to the original author of this solution rcadieux4444
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
Jun 30, 2012 | Computers & Internet
My son has a xbox360 and were trying to get xbox live to connect and it wont we had it working just fine on his brothers hes not home so we hooked it up to the other xbox 360 and it wont connect
1 Disconnect all accessories and wired controllers from the Xbox 360.
2 Hold the "Guide" button down for three seconds on any wireless controllers, then respond to the prompt on your television screen to disconnect the controllers from your system.3 turn on the wireless headset by pressing the "Power" button in the center of the earpiece. 4 Press the "Connect" button on the front of your Xbox 360 system. 5 Press the "Connect" button on the wireless headset. The ring of lights around the power button of the Xbox 360 system should spin and blink once. One of the lights should remain lit up, indicating the port number that the headset is using. If you do not see any lights on the system, you may have a faulty wireless headset.6 Press the "Guide" button on your wireless controller to reconnect the controller to the Xbox 360 system. If you are using a wired controller, you can plug it back into the system.7 Press the "Connect" button on the top of your wireless controller to sync the controller with your system. You should see the connection light around the "Guide" button on the controller light up, indicating which port you are connected to. You should also see a corresponding port light in the ring around the power button of your Xbox 360 system 8 Press the "Connect" button on the wireless headset until the port light on the headset matches the light on the controller and Xbox 360 system. For example, if you are the first player, the light for port number one should be lit up on the Xbox system, the controller and the headset. When all lights correspond, your headset should be properly connected.
Sep 29, 2011 | Microsoft Xbox 360 Console
My xbox controller is not switching on ???? doesn't even switch on with the charger cable... and not working at all ???
Try to reconnect your controller and then restart your console. If you are not sure about connecting your controller, follow the next information: http://support.xbox.com/en-us/pages/xbox-360/get-started/console/connecting-game-controllers.aspx
May 08, 2011 | Microsoft Xbox 360 Controller
On screen notice says to reconnect the controller game paused
it might be the battery pack try to hold the battery pack tighter on the controller then try turning it on
Aug 01, 2010 | Microsoft Xbox 360 Console
How do you use cheat codes for gta san andreas on ps2
Enter these during gameplay without pausing:
http://www.gamespot.com/ps2/action/gta4/hints.html
Apr 06, 2010 | Prima Codes & Cheats: Spring 2005 Edition ...
Retro Nintendo 64 Controller by Retro-bit is not working properly
This is an old question but Ill answer it.
N64 controllers always need to remain still before the system starts or it will lean to one way. That means if you hold right it will continue to go right.
Slow down always does the pause button quickly, there's no way to use a controller to slow down a game. If its a pause screen it might be fine but if its 007 with a major menu change it doesn't work that well don't it?
Turbo normal works like this. Ether hold the button then press the turbo button, or hold the turbo button then press the button. Turbo works just like the slow down. It will continue to send the command to do A or B over and over.
Jul 01, 2009 | Video Game Consoles & Games
3d frog frenzy 1
I cant find anything which lets you skip or select levels, sorry.
But this is the best I could find:
Press [Ctrl] + [Shift] + L during game play Easy Win Press [Ctrl] + [Shift] + T during game play. Freezes The Time Press [Ctrl] + [Shift] + I during game play. Gives You Unlimited Lives, Makes It So You Can't Run Into Traffic Press [Ctrl] + [Shift] + P during game play. Pauses The Game
Press [Ctrl] + [Shift] + L during game play Easy Win Press [Ctrl] + [Shift] + T during game play. Freezes The Time Press [Ctrl] + [Shift] + I during game play. Gives You Unlimited Lives, Makes It So You Can't Run Into Traffic Press [Ctrl] + [Shift] + P during game play. Pauses The Game Press [Ctrl] + [Shift] + L during game play Easy Win Press [Ctrl] + [Shift] + T during game play. Freezes The Time Press [Ctrl] + [Shift] + I during game play. Gives You Unlimited Lives, Makes It So You Can't Run Into Traffic Press [Ctrl] + [Shift] + P during game play. Pauses The Game
Press [Ctrl] + [Shift] + L during game play Easy Win Press [Ctrl] + [Shift] + T during game play. Freezes The Time Press [Ctrl] + [Shift] + I during game play. Gives You Unlimited Lives, Makes It So You Can't Run Into Traffic Press [Ctrl] + [Shift] + P during game play. Pauses The Game Press [Ctrl] + [Shift] + L during game play Easy Win Press [Ctrl] + [Shift] + T during game play. Freezes The Time Press [Ctrl] + [Shift] + I during game play. Gives You Unlimited Lives, Makes It So You Can't Run Into Traffic Press [Ctrl] + [Shift] + P during game play. Pauses The Game EASY WIN: Press [Ctrl] + [Shift] + L during game play.
FREEZES THE TIME: Press [Ctrl] + [Shift] + T during game play.
UNLIMITED LIVES: Press [Ctrl] + [Shift] + I during game play.
PAUSES THE GAME: Press [Ctrl] + [Shift] + P during game play.
I hope they help
Mike
May 14, 2009 | Cosmi 3D Frog Frenzy for Windows
Wireless controller
to activate the second wirless controler you have to press the search button on the xbx360 just below memory unit b, then press the search button on the controler aswell.
Dec 30, 2006 | Microsoft Xbox 360 Controller
Microsoft Xbox Console Logo
74 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Ekse
Nathan Hamilton
Nathan Hamilton
Paul Castley
Paul Castley
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
