Question about Sewing Machines
Pfaff 2046 thread loops on bottom - Sewing Machines
SOURCE: looped bottom thread
I have been having the same trouble--I took this in to a shop and was told it would cost $80 to repair with no warranty on the repair since the machine is all plastic. I think my bobbin tension is too tight but there is not a separate bobbin case, just a plastic space to drop it in.
Posted on May 14, 2008
sylbernard
  • 3 Answers
SOURCE: Pfaff 7570 Tension Problem
Thank you for your help. Actually I was having so much problem that I took the machine to a technician, which diagnosed a few problems. One of them was a big chunk of threads caught in the tension dials. He also told me that I was using a thread that was too heavy which is an all cotton 3 ply, thicker actually then buttonhole thread. So, I've changed threads to an all pupose type Gutterman. The stippling isn't as nice, since much thinner but it solve the problem. If anyone could tell me exactly what type of thread they use and how to adjust the tension, I would very much appreciate it. You can also be sure that I will run a pipe cleaner down the tension dials once in a whileto make sure it's all clear.
Thanks again!
Posted on Feb 23, 2009
sew dutch
  • 25 Answers
SOURCE: Thread looping on the bottom
Thread looping on the bottom means you have a problem with the top thread. In your case there is no tension on your top thread. Take all the thread out of the top and start threading over. Make sure you follow the correct path and make sure the thread goes through the tension discs. Then at the time of sewing, make sure your foot is down (this closes the tension discs and gives the thread the tension.) You may have worked on the tension setting while not realizing the thread was not in between theses discs, so also make sure the top tension disc setting is in the average before sewing.
Good luck.
(If you see loops on top, it means you have a problem with the bottom thread)
Posted on May 25, 2009
SOURCE: Pfaff Expression 3.0 works great in the shop, but
pfaff expression 2.0 works the same. I spend lots of hours with the thread tension and it don;t give me a good stitch. the needle threed ends up making large irregular loops .
Posted on Oct 05, 2009
  • 255 Answers
SOURCE: Singer 301a...sews on top of fabric
This is a tension adjustment problem. It's good to use two different colors of thread, like you did. From your description, the top thread (needle thread) tension needs to be tighter. As you tighten the tension of the top thread, you'll see that the top thread pulls the bobbin thread up into the fabric so it's no longer laying loose on the bottom of the fabric.
You'll need to have the pressure foot down when you tighten the tension. Tighten it a little, sew a practice seam, check to see what the stitch looks like. Tighten it a little more, sew, check, etc etc--until both top and bottom look the same--you shouldn't see much (if any) of the bobbin thread color on top of the fabric or the top thread color on the underside.
Let me know how this works for you, ok?
Robbie
Posted on Jan 26, 2010
My pfaff 1475 CD thread is loopy on bottom and breaks on top.
Look very closely at your sample stitching and determine which thread (top or bobbin) is looping and which is breaking. That will narrow down where the problem exists.
A top thread that loops and makes thread "barfs" under the fabric is generally an upper thread tension problem.
Try: Remove the top thread. ALWAYS RAISE the presser foot and rethread from the beginning. Set the upper tension to the midway point (probably will need to tweak this tension depending on your machine).
Sewing Lesson 10 How to Fix Tension on Your Sewing Machine
Understanding Thread Tension Threads
Sewing Machine Tension
Apr 12, 2017 | PfaFF Sewing Machines
Pfaff 2046 tension problems, needle breaks
Needle breaks
1.the needle is damaged
2.the needle is not correctly inserted
3.wrong size needle for the fabric
4.the wrong foot is attached
5.the needle clamp screw is loose
6. Top tension is too tight--loosen off one letter or number till the stitch
looks normal
7.make sure that every thread guide is used when winding the
bobbin,, so that the bobbin will wind tightly, if this doesn't help,,
then it's possible that the bobbin winder needs adjustment,, it needs
to be taken to a sewing machine shop
Aug 15, 2012 | Sewing Machines
The top thread is perfect the bottom thread is in loops
Try pulling the bottom thread to your left as tight as possible before any sewing, this gives it a better chance to anchor itself in the material.
Apr 04, 2010 | PfaFF Creative 7570
My Pfaff sewing machine has started to loop the top thread underneath. Tried fixing the tension on the bobbin thread as they state in the manual, but the problem still persists. Any suggestions?
If the thread is looping underneath, you're top tension may be too loose or the thread may not be in the take-up lever. If it's looping on top, double check that the thread is in the bobbin tension or that the bobbin tension isn't too loose.
Oct 02, 2009 | PfaFF Creative 7570
Good luck.
May 25, 2009 | PfaFF Tiptronic 2040
Tension Problem on Pfaff 2034, bobbin loops
Rule of thumb.. Loops on the bottom, problem on the top. Loops on the top, problems on the bottom.
Set your upper tension at 4, and rethread the machine from the top. Just before you thread the needle, but the presser foot down. If the thread pulls right thru easily, then the thread is not thru the tension wheel right. Because, if you can't pull the thread thru with the presser foot down, you have it threaded right.
Apr 24, 2009 | PfaFF Tiptronic 2030
Pfaff Expression 3.0 works great in the shop, but when I get it home the bobbin thread doesn't engage with the needle thread. The needle thread ends up making large irregular loops on the bottom of the...
Apr 12, 2009 | White Sewing 1521
Bottom (bobbin thread) makes loops
I don't have the same brand as yours, but on my machine there is a little screw on the bobbin case that you tighten to increase the bobbin tension. If you've got one, turn it 1/8 to 1/4 turn at a time.
Jan 15, 2009 | PfaFF Hobby 4260
Sewing Machines Logo
37 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
