Question about Microsoft Windows XP Home Edition
I have a message Microsoft Runtime error
I do not know to fix,I also can not open some E Mail attachments
    President:
  • 2,559 Answers
Here is the fix.http://support.microsoft.com/kb/822521#FixItForMe
Please rate Fixya solution
Posted on Jan 20, 2009
Runtime error abnormal program termination
Sounds like you have ran a scan on your drive and the software has become corrupt.
Download the utility from Seagate and try again
Feb 08, 2014 | Seagate Back Up Plus Desktop Drive...
Run-time error 339 - OS: Windows 7
Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured Right click on the error message select properties you will see all details about the error or click start type in event viewer press ENTER you might be able work your way through the problem
Runtime errors Some applications may be causing a conflict. Many times runtime errors are a result of incompatibility between two or more programs. Press the "Ctrl," "Alt" and "Delete" keys simultaneously to open Windows Task Manager. From the "Applications" tab, close each open application until the runtime error is resolved. Check for patches, bug fixes or upgrades by visiting the manufacturer's website. Search for your product and determine whether there are downloads to fix the problem your PC is experiencing. When none of the above fixes help, reinstall the troubling program. In severe cases, you may need to reinstall your operating system. Make sure that you back up the other programs and files you want to preserve, which may be erased during the re-installation. Hope this helps.
Jan 10, 2013 | Microsoft Computers & Internet
I cant open my hide messesages in yahoo messenger it says a runtime error
You do not give your OS or a copy of the Runtime Error
Most Runtime errors in Messenger will be IE
IE is coded with Messenger and has to be kept clean and up to date
XP.
Vista
http://support.microsoft.com/kb/923737
Sep 10, 2010 | Yahoo Messenger
Error R6002 floating point not loaded
try using windows 2000 or windows xp sp2 compatablity mode for the executable file that causes the error
Jun 04, 2010 | Sony VAIO® VGCLS1 PC Desktop
"general mail failure in Excel 2003 when trying to send attachme
Hope this works :
Close Excel first and check out if Outlook or Outlook Express/Windows Mail is your mail program for Office.
Start>Settings>Control Panel....Internet options (Program Tab)
In Vista : Start>Default programs
Controls to send mail might be missing missing or disabled or there are errors when you try to mail.
when u get this error message "General Mail Failure " The "E-mail" command is missing or is unavailable, see
http://support.microsoft.com/kb/918792/en-us
for excel 2003 chek the registry for errors
http://support.microsoft.com/kb/834008
hope it works ......
Feb 17, 2010 | Microsoft Excel 2003 (06503995)
Microsoft Visual C + + Runtime Error
I just recently install Window 7 ultimate on my computer and then Acrobat 8 Pro start acting up. Try to open PDF file it will open for a little while then this thing pop up said Microsoft visual C++ Runtime Library and Runtime Error. Then it shut down.
Anyone know how to solve this problems please help.
Karoon Yip
karoon.yip@gmail.com
Jan 31, 2010 | Nova Development Photo Explosion Deluxe...
Microsoft Visual C++Runtime Library
hello there
please follow this link for a explanation and a fix for this ok
  1. "Microsoft Visual C++ Runtime Library Runtime Error" error message ... Describes the error messages that you receive after you install Office XP or an ... "Microsoft Visual C++ Runtime Library Runtime Error" error message after you ...support.microsoft.com/kb/307817
Sep 19, 2009 | Microsoft Windows Vista Home Premium with...
When I turn my computer on, I get a runtime error.
Clean Boot with Only MoSearch loadTOCNode(2, 'resolution'); The Mosearch.exe (Microsoft Office Search Service) and Mosdmn.exe (Microsoft Office 10 Search Filter Daemon) Startup items may be conflicting with some other program (or programs) running in the background. Therefore, clean boot your computer with only MoSearch selected on the Startup menu to determine whether this program is the source of the conflict. To do this, follow these steps:
  1. Click Start, and then click Run.
  2. In the Open box, type msconfig.exe, and then click OK.
  3. On the General tab, click Selective startup.
  4. On the Startup tab, click to clear all check boxes except for MoSearch.
    NOTE: In Microsoft Windows Millennium Edition (Me), leave the *StateMgr check box selected as well.
  5. Click OK, and then click Yes when you are prompted to restart the computer.
  6. If the error message can be reproduced, repeat the preceding steps. In step 3, also click to clear the Process System.ini file and Process Win.ini file check boxes.
If the error message cannot be reproduced, this indicates that MoSearch is conflicting with some other program or programs running in the background. Follow these steps to locate the conflicting program:
  3. On the Startup tab, click to select one of the check boxes.
  4. Click OK, and then click Yes when you are prompted to restart the computer.
  5. If the preceding steps reproduce the error message, the last item added to the Startup menu is causing the conflict. If the error message is not reproduced, repeat these steps until all Startup menu check boxes are selected.
  6. If all the Startup menu check boxes are selected and the error message is still not reproduced, start Msconfig again, and then click to select the Process System.ini file and Process Win.ini file check boxes.
If this doesn't fix it, let me know and I'll post another, more advanced repair.
Good luck, and please let me know how you do.
~ Spoem
Mar 24, 2009 | HP Computers & Internet
Error messages. which cause my computer to crash.
what is your operating system?
what is internet explorer version?
if you answer these 2 questions I maybe able to help you resolve your problem
Nov 03, 2008 | Microsoft Windows XP Home Edition
Microsoft Visual C++ Runtime Error
Download
http://www.microsoft.com/downloads/details.aspx?FamilyID=32BC1BEE-A3F9-4C13-9C99-220B62A191EE&displaylang=en
Microsoft Visual C++ 2005 Redistributable Package (x86)
Brief Description
The Microsoft Visual C++ 2005 Redistributable Package (x86) installs runtime components of Visual C++ Libraries required to run applications developed with Visual C++ on a computer that does not have Visual C++ 2005 installed.
hope this solves your problem it should
have fun
The Doctor
Nov 02, 2008 | Microsoft Windows XP Professional With...
Microsoft Windows XP Home Edition Logo
26 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
