Question about Garmin eTrex Vista Cx GPS Receiver
My garmin etrex wont raed sd card
When i put a sd card in the devise that has maps downloaded it dosent read the card.
SOURCE: Garmin nuvi 260
Re: Not sayinstreet names.
After you turn on your unit touch the wrench icon in the bottom right of the screen, this will take you to a menu which features "Settings" in the upper left of the screen. Touch "settings" and scroll down to "language" by using the up and down buttons in the lower right of the screen (down 1 should do it). Touch "Language" and in the voice category find and select "American English - Jill (TTS)". This is the voice that will give you Text To Speech (TTS) speaking the street names in English. If you prefer Spanish or French, find the appropriate catergories with "(TTS)" beside them - "Espanol Americas - Paulina (TTS)" and "Francais Canadien - Julie (TTS)" respectively. Any other selection will only give directional instructions such as "turn left in XXX".
After you have selected your voice press "OK" and back out to your main menu showing "Where to?" and View Map".
Now, when you navigate, you should hear an American female voice giving you directions by street name - assuming your volume is high enough to hear it.
RE: The computer icon displaying when you try to use your unit in the car with the 12 VDC cord.
You probably have a problem with the cord. The pin length in the USB style connector is critical and if it doesn't match up just right the GPS thinks it is hooked up to a computer. If you know someone who has a Garmin NUVI try using their cord and see if you have the same problem. Either way, call Garmin and see if they will send you a replacement cord or otherwise help fix the problem.
Posted on Nov 03, 2008
SOURCE: garmin etrex screen too dim to read
I have an older Garmin 12XL and suddenly the screen turned very dark. I tried replacing the batteries and let the GPS rest for a week so the internal lithium battery could re-charge. But that did not work. I just got an email from a friend who had the same problem... it turned out that his unit had changed the screen contrast setting all by its' self.
This may not be the cause of your problem but it's worth trying... go into your "Settings" menu and reset the contrast and see if that cures the problem. Good luck.
Posted on Nov 21, 2008
SOURCE: Nuvi 200w map download and sd card
Guys and or ladies... I know that you have to create a folder named "GARMIN" in the sd card so the maps can be recognize. Maybe this solves your problem. Let me know if it works.
BR from Spain,
Carla
Posted on Apr 01, 2009
SOURCE: Can't unlock maps on the SD card
I am still waiting for the promised free solution suggestions
Posted on Jun 13, 2009
  • 4090 Answers
SOURCE: Maps on SD card not recognized by Garmin C330 GPS
I dont thinki the 330 handles 4Gb SD cards I think 2Gb is the maximum that is why it isd taking so long and runds out of space so cannot properly load the maps.
Posted on Jul 22, 2009
A good software programme for putting maps onto a garmin etrex legendhcx
Try an Old Garmin "Mapsource" version and maps data with very low quality. I read somewhere that new versions of mapsource can't load map to Legend types
Oct 02, 2011 | Garmin eTrex Legend GPS Receiver
Garmin nuvi 3760. I have downloaded North american maps to the SD card but the Nuvii doesn't recognise the SD chip map when I go to tool, maps etc. Help
Update your unit using Garmin Webupdater. The latest updated firmware allows the units to read all sd/microsd cards You can download garmin webupdater from here: http://www8.garmin.com/products/webupdater/howtoinstall.jsp
Download install and run the program and follow the on screen prompts to update your unit.
Sep 27, 2011 | Garmin Nuvi 3790T 3790 3760T 3760 3750...
How do I install maps from the Garmin US Topo 100K to my Garmin Etrex Vista HCx? I've put in a microSD card, then what?
You need to install the map software on your PC. From there, using the map select tool, select the maps you want to add to your GS unit and then send them to the microSD card which will show up in the SEND window.
Mar 29, 2010 | Garmin eTrex Vista HCx Handheld GPS...
I can't put maps on my Garmin etrex legend HCx
Your MicroSD card may be full just from the basic maps. Try larger card for additional maps. The vendors supply the minimum to keep the cost low and then force the customer to upgrade the resources at their own expense.
Dec 22, 2009 | Garmin eTrex Vista HCx Handheld GPS...
Cant view map on gps
When you go past 4gigs on a micro SD card it becomes HC (high capacity I believe) and will not work with most Garmins. The 2 gig's the limit.
Dec 11, 2008 | Garmin Rino 530 GPS Receiver
Vista HCX Micro SD Problem
Vista only recognize gmapsupp.img files.Go to www.mapwel.biz/down.htm take MapUpload software then from mapsource select maps you want to transfer to sd card.Or directly from Mapsource select Transfer and send selected map to sd card.Maps must be unlocked.
Aug 19, 2008 | Garmin eTrex Vista GPS Receiver
Garmin etrex hxc gps adding m,ore map detail.
You will need to use Mapsource to transfer the maps to your GPSr unit. This should install when you install the Topo Britain program.
You will then choose which map segments you want to transfer, and the program will do the rest.
May 14, 2008 | Garmin eTrex Vista Cx GPS Receiver
BlueChart MicroSD map will not display
Get program MapUpload from www.mapwel.biz/down.htm after that go to Piratebay find Bluechart Atlantic 9.5 torrent.Mout it to Mapsource and with help of MapUpload send it to sd card
Apr 01, 2008 | Garmin eTrex Vista GPS Receiver
Cannot load maps onto micro SD card.
Yust go to www.mapwel.biz/down.htm get software MapUpload and now you can upload any map to micro sd card without loosing your existing map.
Feb 17, 2008 | Garmin eTrex Vista GPS Receiver
Downloading maps to my gps
you transfer them into the SD card
Oct 31, 2007 | Garmin eTrex Vista Cx GPS Receiver
Garmin eTrex Vista Cx GPS Receiver Logo
24 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
