Question about GE CVM2072SMSS Microwave Oven
Control keyboard does not work
Touch screen is not working
  • GE Master
  • 9,047 Answers
See this page.
Posted on Jan 09, 2013
How do I reset the lg microwave. It's asking reset date but my touch screen
If the microwave buttons don't work the touchpad and control panel assembly are probably defective.
Jan 07, 2015 | LG LMV1630ST Microwave Oven
What's your problemPvm2070sm1ss ? touch screen control panel intermittently stops working
The touch screen has built in semiconductors that sometimes become intermittent, the only solution is to replace the touch screen.
May 17, 2012 | GE Microwave Ovens
I have chefmate microwave and suddenly stopped working. it is showing 2:50 code on the screen only...it was working fine and dont know what happened to it and touch pad is not working..how do i make it...
HELLO.
The code on the screen indicate electric panel fault resulting from the touchpad malfunction.
The touch pad on your microwave oven acts as the brain of the appliance. It not only contains the buttons that you use to enter cooking settings and times, but also controls the function of the entire microwave. If the touch pad malfunctions or breaks completely, the microwave will cease to function. In this instance, the broken touch pad must be removed and a new touch pad must be installed, to restore functionality to the microwave.
1 Unplug the microwave from the wall outlet.
2 Remove the two screws, located on the front or top of the grill at the top of the microwave.
3 Pull the grill off of the microwave.
4 Remove the mounting screw from the top of the control panel.
5 Lift the control panel up and out to loosen. Look behind the control panel to ensure there are no metal tabs securing the control panel in place. If there are metal tabs, gently rotate the control panel to free the tabs.
6 Transfer the wires from the old control panel to the new control panel one at a time to ensure that the wires are properly installed.
7 Install the new control panel into the microwave and secure using the mounting screw that was removed.
8 Replace the grill from the top of the microwave and secure it using the screws that were removed.
9 Plug the microwave back into the wall outlet.
Thanks.
Sep 12, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Touch screen fading in & out, unit works fine
You can get that repaired for $39.95 in most cases (details here) or order a control / display unit here.
Jul 27, 2010 | Dacor DMT2420SS Microwave Oven
Touch screen not responsive. Can operate oven only by pressing one-minute button. Cannot set clock, change settings, etc.
try opening up the control panel,disconnect the connector ribbon coming from control panel and connected 2 control board by just pulling it out and cleaning end of connector ribbon and iserting it back.some times this works.if not then 4 sure touch panel needs to be replaced.
Aug 15, 2009 | Kenmore 63792 Microwave Oven
G2 touch screen doesn't work any longer
You must remove the vinyl cover from the control panel and wipe down the face underneath it with denatured alcohol. It's pretty tricky depending on your mechanical caliber.
Then clean the inner side of the vinyl cover the same way. Caution don't soak the power unit just dampen a cloth, this goes for the cover also!
Aug 13, 2009 | Microwave Ovens
Dacor Touch Screen is flickering and doesn't respond to touch
Mar 31, 2009 | Dacor DMT2420SS Microwave Oven
Error Code
I would recheck the control board installtion that you made, as well as verify that you got the correct replacement. Also the board may contain static sensitive componets so you might want to make sure you are grounded when handleing the control panel. Good luck
May 14, 2008 | KitchenAid KHHS179LSS Convection /...
Control Panel Touch Screen Goes Blank
This is a problem with the control panel assembly, which we commonly repair for $32.50. Feel free to e-mail me at _ for more information or visit _ for full details.
Aug 01, 2006 | Sharp R-340 Microwave Oven
GE CVM2072SMSS Microwave Oven Logo
245 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
