Question about Water Heaters
Vaillant turbomax 28 constant hot water problem.
I have a problem with a Vaillant turbomax 28.
Central heating fine, but hot water runs for five to ten seconds than ten seconds cold, later hot again and goes on.
I thought it was diverter valve and diaphragm. Both replaced but still same problem. It is not enough to have shower or bath.
    Novelist:
  • 88 Answers
Got your fix, its a calcium buildup in the heat exchanger, and more than likely the rest of the unit, you will need to flush the unit with about 4 gallons of vinegar, you will need to recirculate it for about 20 mins through the unit, then flush with clean water, hook it back up, it might take a couple of mins for it to run properly, but it will, I have had the same problem with Rinnai on demand hot water systems, and it worked like a charm, check the filter thats inline as well, make sure it isnt plugged, clean if needed, also if you dont have a soft water system inplace, you might want to think about buying one and having it installed, that will reduce this from happening again for alot longer period of time, hope that helps
Posted on Jan 20, 2009
Intermittent hot water.Changed diverter valve,heat exchanger,fan, PCB. Vaillant turbomax 282e But still no hot water.
Sounds like you need a new Thermo coupler.
Could be as simple as a dirty pilot and needs cleaning but I suspect a thermo coupler.
Apr 14, 2016 | Water Water Heaters
Vaillant boiler leaking only when heating switched off.
It would seem a joint has come a bit loose from the heating and cooling cycle. put a drip pan under the leaking area( the drips would evaporate quickly), then next time you shut it down go through all the joints in the area with wrenches to find the loose joint.
Oct 27, 2014 | Water Heaters
Fan not running smoothly
I would replace it!
Jan 25, 2014 | Water Heaters
I have a vaillant eco pro 28 combi boiler. no constant hot water unless tap is on really low.
Oh some of these there was a small black heatexchanger just for hot water they some times block up . or it could be a blockage in the water section where it flows in .I know Valliant have a very good tech line and fitters who do house calls .
Mar 02, 2017 | Water Heaters
Hi my vaillant combi gives hot water for only 15 seconds then runs cold turn the tap off, run the water again & gets hot then runs cold some told me it might be the diverter valve can any body help...
yes it is your expansion vessel it sounds under charged to me?your expansion vessel needs to be recharged to 1 bar at least,but check manufacturers instructions it could state different.if the heating is fine and your getting hot water in intervals your diverta valve is moving and working?
Dec 11, 2012 | Water Heaters
Vaillant boiler no heating or hot water
refere to manual check for override switch loss of pressure no problem re-pressurise and check for leak top of rad valve good place to start
Oct 10, 2009 | Water Heaters
No hot water
My guess would be the unit mifired and need reset.
Mar 10, 2009 | Water Heaters
Heating, but no hot water on a vaillant turbomax 28 combi
the problem is the diverter valve unit, source a corgi engineer to fit new one, cost for valve approx 80 quid +fitting
Kindly
Richie
Dec 15, 2008 | Water Heaters
Water Heaters Logo
1,086 people viewed this question
Top Water Heaters Experts
Donni Steen
Paul Carew
Are you a Water Heater Expert? Answer questions, earn points and help others
