Question about Audiovox Car Audio & Video
My audiovox sp 10 cd changer is not responding.
This is a trunk mounted 10 disk unit in a 99 Ford Taurus with the heater and radio controls integrated. The radio unit reports "no CD" with the magazine fully loaded.
Eagleeyes
  • 199 Answers
SOURCE: Inoperable CD changer
Hi the alpine/merc/bmw cd changer all seam to suffer with the same problem, they say no disc, or no mag try firmly hitting the mag with the handle of a screw driver. the loadinga arm, tends to get stuck. you could try using some grease on the arms, and levers, white spray gease works best. but dont forget to cover the laser beforehand, you dont want grease on it :) Mark www.carradiospares.co.uk
Posted on May 03, 2007
SOURCE: Remove CD Magazine - No power to unit!
I fixed my similar problem by applying 12v to the unit according to the pinout found here:
http://users.ntplx.net/~andrew/sony/unilink/
(note that -12v goes to the connector barrel)
Posted on Apr 06, 2009
SOURCE: Clarion 6 Cd Changer 1999 Ford Expedition OEM - NO CD DJ on display
plays and changes song fine just no sound
Posted on Jun 12, 2009
SOURCE: Can't eject cd magazine - E-99 error message
I had the same problem. I opened up the unit and found out that there is a plastic gear that moves the loader. When worn the loader can not load tha magazines nor change cd's. I replaced the gear and the cd autochanger worked fine.
Gerald,
Kenya.
Posted on Aug 25, 2009
dj_relly999
  • 4070 Answers
SOURCE: cd changer magazine does not eject
good day, you may want to do it manually if its jammed, you may find a pinhole on it and u can use a paperclip, insert it in the hole and it will open. hopefully it wont jam again. hope this helps, have a nice day
Posted on Feb 10, 2010
I need a complete wiring diagram audiovox acc-25a 10 disk cd changer . most important is the coax cable with 8 pin connecter as to wich wire dose what
Call searspartsdirect.com at
for questions or assistance, call
1-888-206-3625 (Se Habla Espa?¿½ol)
M-F 6:30 a.m. - 10:30 p.m. CT
Sat 7:00 a.m. - 9:30 p.m. CT
Sun 7:30 a.m. - 9:30 p.m. CT
Feb 26, 2015 | Audiovox Car Audio & Video
I have a 1993 Mercedes 300 SE and after I got the radio unlock code from mercedes the radio worked all day just fine. I started the car the next day and the radio had a E 3 message on the display when I...
I dont remember if that year had a theft lock system or not, but I am looking into it. disconnect the negative battery cable for ten minutes and that should get you back to where you can enter the unlock code again and use the radio.
Nov 01, 2013 | 2004 Mercedes-Benz Mercedes Benz S Class
My radio doesn't have a cd but there is a button marked cd. Is it possible there is wiring in the trunk for the cd changer i have?
Usually they don't do that. We have a 1998 Ford Taurus that has the button for the cd but no wiring for a cd changer in the trunk. You can check for yourself if you like.
Aug 03, 2010 | 2003 Mercury Grand Marquis
So i have a 96 cadillac eldorado with a ten disk sony changer mounted in the trunk and it keeps saying E-99 i already unjammed the disk becuase it was stuck on it but i cannot find the reset button on it n...
it should be on the bottom edge when you open the cover to access the Cd's and if you still cant find it just unplug the changer unit for about 5mins then plug back in. generally a rest interrupts the main power connection when it is pushed
Jun 08, 2010 | Sony CDX-454RF 10-Disc CD Changer
Will the Audiovox SP-6cds hook to an Audiovox GM250 radio?
Yes - the radio has cd changer controllers.
The Changer is FM modulated - and the radio becomes the controller.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 11, 2010 | Audiovox SP6CDP 6-Disc CD Changer
Loction of cd changer plug
the unit at front with the ac controls is just a remote control unit , the radio is in your trunk left side
you have to remove the carpet and you will find a free 13 pin plug , that is the cd changer connector
it is the same in all taurus and sable from 1996 to 2007
the radio looks like this picture
this is the cd changer
Apr 01, 2010 | 1997 Mercury Sable
1999 Ford SE digital display reads ''NO CD'' and changer is stuck
Magazine-type CD changers are prone to jamming with a disc in transit between the magazine and the player. You may have to resort to disassembling the trunk unit to get access to the jam.
Apr 15, 2017 | 1999 Ford Taurus
Can not find where to plug CD player to the harness
does the radio have cd changer controlls? if so you may find the wires in the trunk if not you will have to buy a harness from ford and make sure the cd changer will work with the stock radio. Call the local ford dealer parts dep but make sure you have the vin number from the car with that they can look up the car and tell you what options where installed from the factory and can order the correct cable
Sep 02, 2009 | 2000 Ford Taurus
I have a '99 Ford Taurus with a cassette and 6 changer cd player. The radio works for a while then cuts out, then comes back on. It can play for a few hours or a few days. I recently bought another radio...
yes i agree it sounds like it is overheating. Just pull back the carpet in the trunk on the left hand side. Check all the connections make sure its got a good ground etc.
This unit is where all the power etc comes from for the headunit and speakers.
Oct 28, 2008 | 2004 Ford Taurus
Installing a cd changer into a 2002 Jaguar S-Type
SOUNDS LIKE YOU HAVE A VERY EARLY MODEL CD CHANGER ALPINE UNIT THE S TYPE
USED A AUDIOVOX CD CHANGER HOPE THIS IS USEFUL
Jul 03, 2008 | 2002 Jaguar S-Type
Car Audio & Video Logo
74 people viewed this question
Top Audiovox Car Audio & Video Experts
xxxxxx xxx
Jaime Hernandez
Are you an Audiovox Car Audio and Video Expert? Answer questions, earn points and help others
