Question about Nordic Track Nordictrack Exp 1000 Treadmill Motor Control Board 13
Nordictrack exp1000 computer - Nordic Track Nordictrack Exp 1000 Treadmill Motor Control Board 13
3 Suggested Answers
  • 84 Answers
SOURCE: my nordictrack exp1000 incline will
looks like a incline sensor
Posted on Mar 11, 2011
ercupa190
  • 12223 Answers
SOURCE: Only certain buttons on the NordicTrack exp1000 treadmill work.
1) You must check the flexible cord between display board vs controller motor board, and tight very well
2) Try to access to the keypanel and clean with special spray (clean contact you can find in radio schack or computer store).
3) Try to Measure the +5Vdc for I.C. including EPROM, ROM, etc.
4) And try again.
5) Measure if the power supply to display is coming out from the Lower board or Motor controller board. If not the Motor controller is faulty. You must replace it.
Use Dvoltmeter.
Remember 90% aprx the Motor controller board access to the function in the display board, elevation motor, power input, etc.
sincerely.
Posted on Nov 22, 2011
Nordic track exp1000 stops suddenly while in use
If you wish to get some details about treadmill repair ; visit the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Jan 07, 2017 | Nordic Track Nordictrack Exp1000 Treadmill...
Exp1000 runs for several minutes
The control circuit has an overload and will shut down to prevent a fire. It may not be the Motor at all, just the circuit board failing.
Feb 26, 2014 | Nordic Track Nordictrack Exp 1000xi...
Plastic under the treadmill belt is bent/warped
Dear sIR:
You must replace this parts, go to www.fitnessrepairparts.com or
www.treadmillpartszone.com
sincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a
Mar 11, 2012 | Nordic Track Nordictrack Exp1000 Treadmill...
4) And try again.
Use Dvoltmeter.
sincerely.
Nov 22, 2011 | Nordic Track Nordictrack Exp 1000...
Our Nordictrack Track Exp100S has problems. The belt rubs on the left hand side (my left as I'm walking) at the back of the treadmill. What should I do?
Inspect the rear plastic end cap. It is the plastic part at the back of the machine. The adjustment screws can be found there. These end caps disintegrate after time and break. You will see the discoloured plastic where the damage has occurred. If this is the case, the end cap must be replaced and belt readjusted.
Jan 04, 2011 | Treadmill Doctor Nordictrack Track...
I have a NordicTrack EXP1000. The walking belt was so far to the left that the edge began to fray. So, I adjusted the belt towards the right and now it slips forward now and then when it gets up to 3mph or...
If the walking belt slips when walked on, first remove the key and UNPLUG THE POWER CORD. Using the hex key, turn both idler roller bolts clockwise, 1/4 of a turn. When the walking belt is correctly tightened, you should be able to lift each edge of the walking belt 2 to 3 in. (5 to 7 cm) off the walking platform. Be careful to keep the walking belt centered. Then, plug in the power cord, insert the key, and carefully walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened.
If their is still slippage then the drive belt will need to be adjusted.
Find the motor mounts. Many motors in Icon treadmills have a main pivot joint in which a bolt runs the full length of the motor mount. This bolt will require loosening to provide maximum adjustability. Find the set bolt(s) on the motor.
This is typically run through only one side of the motor mount or may be on both sides but it does not run the full length of the mounting. Loosen this bolt but do not remove.
The drive belt must be tensioned by hand. While one person applied increased tension to the drive belt, the other person should tighten the motor set bolt(s) that are described above. Tighten the bolt and test. If the problem is not corrected, if problem persist replace drive belt
Jun 11, 2010 | Nordic Track Nordictrack Exp1000 Treadmill...
I have a Nordic Track exp1000 i fit and the track is not working.
It's either the electronics console overlay -- this thing often goes on this model -- or your motor is shot.
Have you ever seen it working?
Repairs can expensive.
You can buy an excellent replacement console electronics part for $100 (http://www.treadmilldoctor.com/Nordictrack-Console-Keypad-Overlay) , but if it's actually the motor, then you've still got more to spend.
In home service can easily run $150 for the call plus cost of parts.
If you decide that you're not going to try and get it repaired and you're going to toss it, I'd like to buy some plastic housing parts off that non-working unit from you. Please email me directly.
Cheers,
Mark
emotif@gmail.com
Jun 09, 2009 | Nordic Track NordicTrack Treadmill, A2550
Nordic Track Nordictrack Exp 1000 Treadmill Motor Control Board  13 Logo
18 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Electro Med Services...
Paul Sikkema
Paul Sikkema
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
