Question about Sewing Machines
Machine will not sew. Message comes on screen, "Put on Foot A."
  • Sewing Machines Master
  • 7,365 Answers
The machine probably need to be serviced to see if the motherboard
has a problem
Posted on Jan 08, 2013
SOURCE: "Lower presser foot" error on SE 270D
OK; My SE-270D is about 5 years old and it just recently started giving me the "lower presser foot lever" I have already spent $30 going on line to fixit websites only to be told to take the unit to a service center. I went through the normal routine of trying to reset the computer of which did not work. I can't afford to spend $75 just to let someone look at my unit and then pay even more to have it fixed. I could buy the same machine or equivalent (brand new) for about $200. I am sort of mechanically inclined so I decided what the heck, I will just open up this machine and try to figure it out myself. I mean what do I have to loose. I opened up the unit and discovered there is a tiny "pressure switch" which is activated when the lever is pushed up or down. When the lever is up the switch is "off" when the lever is lowered it releases the spring loaded whitch to the "on" position. The tiny switch is right below the thread tension dial. I discovered that the switch could be activated manually by pulling it over with my finger. I had to make a hole in the casing so I could get to the switch after I put it back together. WALA! it works. When I lower the presser foot lever I then pull the broken switch into the proper position and it works like a sewing machine. I gambled on this solution because I have a tiny bit of mechanical knowledge. So if you are lacking in that area, please don't try it.
Posted on Nov 26, 2008
SOURCE: Janome, memory craft 4800, sewing machine
how to delete programmed patterns and start new lettering
Posted on Jul 11, 2008
  • 37 Answers
SOURCE: The presser foot came off Brothers sewing machine
position the foot under the shaft making sure the horizontal pin on the foot is in line with the horizontal groove on the end of presser foot fitting on the shaft. Lower the pressor foot arm and it should snap right on. If not, press it up manually. the directions should be in your manual. If you don't have your manual, you can get it online at www.brother-usa.com
Posted on Apr 16, 2009
  • 1116 Answers
SOURCE: I cant get the machine to sew a buttonhole.
I am not familiar with your machine, but some buttonhole attachments require a lever be lowered and inserted into a tab.
Review your manual to see if a step was overlooked.
Posted on Mar 07, 2010
  • 139 Answers
SOURCE: I have a Singer 2662 sewing machine. The
This website should help: http://www.singerco.com/resources/buttonhole.html
Posted on Apr 16, 2010
Machine set for embroidery. Get to start and screen keeps coming up to put p foot on. It is on. Turned of several times.started again. Still keeps coming up on screen please attached p foot.
There is a button that sets the machine to embroidery or to sewing. It is probably under your stuff tray. It must be set to the right position for it to work.
Sep 30, 2016 | Sewing Machines
How do I fix the following problem with my Janome MC9000 sewing machine?
Unfortunately you are probably not going to be able to fix this.
It needs a sensor adjusted (probably), or a component replaced.
Sep 25, 2014 | Janome Memory Craft 9000 Computerized...
Problems with foot pedal light
sounds like there is a design fault, I suggest if you can take the
machine back and get a different brand of sewing machine.
I've been sewing for over 25 years and I would put up
with that kind of sewing machine.
probably a computer problem.
Nov 15, 2012 | Sewing Machines
Pfaff ambition 1.0 sewing by itself
sounds like there a problem with the motherboard giving the wrong
commands. the machine definitely needs to be checked.
Sep 11, 2012 | Sewing Machines
Foot pedal not working
yes, it is possible that the foot pedal can go out,, it would be a good
idea to have the foot pedal checked at a repair shop to see for
sure
Aug 27, 2012 | PfaFF Tiptronic 2040
Keeps giving me the Fc warning signal no matter what I do
The foot control has been disconnected while sewing. Turn off te power and connect the foot control.(connected to foot pedal on the floor has come loose from machine body)
Jul 15, 2010 | Kenmore 19110 Computerized Sewing Machine
I have a Janome 11000-it won't embroidery
You have to be sure you have the correct foot on the machine and that it is put on correctly. You can't use a regular foot - you need to use the embroidery foot P, which require you to remove the foot holder altogether, and put on the P.
Dec 18, 2008 | Janome Memory Craft 10000
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
