Question about Kenmore Oasis HE 27082 Top Load Washer
My washer is only a year old and it will not turn on...it is locked and i can not get it open????
  • Anonymous Jan 24, 2009
    Same exact problem only a few days later...hmmm..
    Did you ever find an answer?
    Novelist:
  • 126 Answers
You can try this if you feel handy enough to take stuff apart:
unplug the power cord from the wall.
remove the top control panel (there are three screws that you can access from the top) and move it aside. no need to electrically disconnect it.
remove connector P12 from the grey control board (its the one on the lower right side just under where the top control panel electrically connects). it will have a grey jacket on it and will have a tab you have to press to take it out.
reconnect it securly back into P12.
reattach the top control panel.
plug in the power cord.
press the power button to see if it unlocks.
if its dead, then the above may not work, but worth a shot.
good luck
Posted on Jan 28, 2009
  • 126 Answers
If it is electronically controlled, you probably need a new electronic control or a new door latch. If it is under a year old it should still be under warranty.
Posted on Jan 20, 2009
How do i get the door open on a frigidaire front load washer?
check underneath the washer below where the handle is for a ring. pull to manually release lock.
Dec 02, 2014 | Frigidaire Washing Machines
Want to disengage lid lock on maytag centennial
I had the same problem. The lid lock assembly is broken. If you are under warranty get it replaced. If not remove the top of the washer and take out the switch assembly. The 4 wires going in are Yellow, Red, White, and Blue. If you short the white and blue together, the washer thinks the lid is closed. If you short the red white and blue together the washer thinks the lid is closed and locked. The yellow is only there to activate the electromagnetic switch.
Disconnecting the switch assembly will not work.
The electromagnet locks the lid and it also unlocks the lid. It is not a matter of cutting the power to the magnet.
Installing 2 switches that connect the red white and blue is the best option if you want to remove the lock.
The first switch should connect the white and blue. (LID CLOSED)
The second should connect the red to the white/blue connection. (LID LOCKED)
After that the lid should work.
Please post a follow-up if this works for you.
GOOD LUCK
Jul 09, 2012 | Maytag Centennial 3.2 cu. ft. SuperSize...
1.3 year old Frigidaire Stackable washer/dryer model FEX831FS won't drain. Checked pump and hoses. OK. Am in remote Alaska and we don't have service tech's here. Any suggestions.
What you want to check is the lid switch..remove the front panel..on the switch/lid lock asm.will be
the main switch which is part in the black body of the lock asm. the 2 terminals their will have contunuty with zero ohms when lid is closed
when lid closed the white switch will be open and closed when lid open
the one in the black body on the main lock asm. will be open when lid open
IF it does turn out that the lid lock is the problem the part number for it is 134101800
it could be purchased online at;
repairclinic.com
apdepot.com
apwagner.com
searspartsdirect.com
midwestapplianceparts.com
If the switch checks to be good test for power into the drain pump if no power the timer is what is wrong the washer (not dryer) timer is part# 131758600
Gene
Aug 24, 2011 | Frigidaire Washing Machines
Won't spin
We had the same problem. It was the door lock. In addition to the regular lock that prohibits you from opening the door while the machine is running, There is a "wax motor" lock. If this lock fails, it won't do the final spin. Think back to your top load washer, it wouldn't spin if you opened the top. The motor is a universal motor that is used on many front load washers. We found the answer by googling "front loader won't spin" - the wax motor costs $12. The wax motor is inside the door switch control. It opens up with a screw driver, be very gentle.
Oct 11, 2009 | General Electric WSSH300G Front Load...
My frigidaire affinity wont start
Yes, the original issue was the control from the beginning. the control is damaged and it cannot register the latch at this point. this is necessary and , it will fix the issue.
May 29, 2009 | Frigidaire Affinity ATF7000E Front Load...
The stays on control locked and I cannot turn it off
usually you can push and hold the button next to the lock light. it will have a picture of a lock next to it. if you push and hold it for 5 seconds it should unlock the control board.
Jan 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
GE Front Load Washer Model WBVH5100HWW - door lock light is on
I queryed another site; justanswer.com with technician Larry, who provided the solution. Replace the door latch assenbly part # WH10X1006 $146.99 from GE. A local parts house had the identical under a Whirlpool # WP8182634 for 59.46. Install the new assemble and all is well.
Nov 12, 2008 | GE WBVH6240F Front Load Washer
Door lock light on
The lid switch is defective, and you need to replace it.
Sep 02, 2008 | Frigidaire ATF6000ES Front Load Washer
Maytag MAH8700A
Joe, ds is a door lock malfunction. The door lock latch shows closed and the door switch shows open. Try this, unplug the unit for 60 seconds and see if the error comes back. If it does, with the power on press and hold the chime and xtra rinse pads together for 3 seconds. This will put it into the service mode. Once in the service mode press the chime button again to unlock and the temperature pad to lock. See if they operate. If still no luck you are going to have to do some tests on the door lock switch to see whats happening. You do have a 2 year warranty on these parts and being that it is only a year old, tell them to throw in the labor....Catriver...post back.
Dec 13, 2006 | Maytag MAH8700A Front Load Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
73 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
