Question about Microwave Ovens
Need help, trying to repair my Tappan Model TMV151F microwave.
1st problem was heats OK, but No Light and turntable would stop after 5 seconds. Checked door switches all Good. Resoldered relays and other connections on the control board. NO Change. A day later the light and turntable now work, but now DOESN'T Heat??? Rich
  • Microwave Ovens Master
  • 9,098 Answers
That really sounds strange... It may be a door switch or a relay on the controller. (Internal contacts, not solder joints).
The service manual is here.
Did you take apart the bottom door switch to check it? Blurry but useful video here.
Under the circumstances, I would be most concerned with the bottom switch, but it wouldn't hurt to check the top one. It will not be the middle switch.
Posted on Jan 09, 2013
MicrowaveSvc
  • 9098 Answers
SOURCE: danby microwave m # 1153
Quite often this is due to a bad door switch. Opening the door while cooking (without first hitting the STOP pad) is the primary cause of door switch failure. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Posted on Sep 23, 2007
sharcnet
  • 2130 Answers
SOURCE: Maytag Microwave model#MMV5186AA
Typically, no heating of food, indicates a bad Magnetron (tube) or associated components. The oven can be repaired. Magnetrons are not hard to replace and can be ordered online through MCM electronics www.mcmelectronics .
However, due to the dangers of high-voltage within the unit, I would recommend taking the unit to a repair center.
Look in the manual to see what the warranty says. See if there is any information regarding the magnetron or parts. You may be able to get it repaired for free parts, less labor.
Please let me know if I can be of further assistance to you.
Good Luck,
- Jim
Posted on Mar 20, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: JVM1650SH05 Intermittent won't heat
On many of these GE (by Samsung) and similar models, there were "underperforming" magnetrons that would fail, often causing other damage.
In many cases, these ovens also need to have the high voltage rectifier diode and/or stirrer replaced.
In rare cases, the cavity would be overheated and the whole oven would need to be replaced.
In some cases, a service center will have a stock of magnetrons, and they may be of the "underperforming" type instead of the newest version.
So a repairman may (knowingly or not) be replacing a failed magnetron with one that is destined to fail soon.
It may be an innocent mistake, or it may be a way of not having to deal with a bunch of bad stock parts that may cost him time or money.
And if you just go put them in ovens and bill GE for the part and your customer for the labor, you're making money.
There should be a 5-9 year warranty on the magnetron.
Details of this whole magnetron saga are in their bulletin here. Even if your model is not on the list, the same problem can occur, requiring a kit. The parts kit is similar to this one.
I would check that, then call contact GE to find a different local servicer if possible.
Whether you use that servicer or a different one, I would mention or show the bulletin to them even if your model is not affected. It may have similar trouble that needs to be addressed thoroughly.
You need a thorough, competent checkout.
GE Customer Service is here.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Jul 18, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: GE spacemaker Microwave-Model # JVM1441WD003 no heat -clock ok
This is usually caused by either a bad door switch or a loose door switch mount, which are pretty simple problems to fix.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If the mount is broken, it's usually more economical and safer to add a dab or two of hot glue to the mount to secure the switch. Let it cool for about 30 minutes before using.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you only need a switch, you can order a universal type here for $5 postpaid.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases in about a week or so.
Posted on Feb 15, 2009
  • 178 Answers
SOURCE: GE Microwave JE2160 does not heat
Does it make any noises that it didn't before it failed?? It could be a bad secondary interlock switch, cook relay on the PCB, HV circuit problem or bad magnetron. You need an ohm meter to troubleshoot. If you take the cover off, you MUST short across the High Voltage Capacitor terminals to discharge any possible residual charge to prevent shock hazard.
Posted on Sep 11, 2009
My tappan microwave won't shutoff
I would first check the door switches and mounts. My door switch help file is here.
If those are good, then you likely have a shorted relay on the control boar, which I can repair for you. Details are here.
FixYa doesn't notify us when there's a response, so if you have other questions, please contact me directly.
- William E. Miller, AS-EET
pupista@gmail.com
http://www.MicrowaveControl.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
May 25, 2017 | Tappan Microwave Ovens
My frigidare microwave model #FFMV162LB (about 5 years old) stopped working. I was cooking last night, and in the middle of it, the table stopped turning and the heat stopped. The timer still works and the...
After 5 years of service, there could have been a magnetron failure but the door interlock (latch) could have failed which would acccount for the turntable failure.
Feb 13, 2014 | Frigidaire FFMV162LB Microwave Oven
Turntable does not operate. unit still heats, but the heating is not as even now. turntable was making noise for a couple of days before it stopped working. It was working intermittently, perhaps 1 out of...
If the oven is still heating, but the carousel isn't turning, this problem is commonly attributed to a turntable motor that has worn out and may need to be replaced. The motor is attached to the center plastic piece (called a turntable shaft or coupler) under the middle of the glass tray. The following link explains how to access and replace one:
http://www.fixya.com/support/r3555716-replacing_a_turntable_motor_on_a_microwa
This is a very simple repair, that usually is not expensive. The price range will be determined by the model and manufacturer. This repair can also be performed on an over the range model microwave oven WITHOUT uninstalling it.
You can refer to any of the following websites for comparison:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The first three sites listed offer helpful exploded view diagrams to assist you with locating and properly identifying the part(s) you need. If the model number is correct, the part number for a replacement motor is WB26X10135.
If you have any questions, please post back and let me know. I hope this helps you.
Apr 17, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
My Russell Hobbs microwave will not generate heat
If everything else is normal, the trouble may be a failed magnetron tube (the microwave source), problems on the control circuit board, or parts in the tube power circuit that are bad. It's also possible a door switch can be at fault, but this usually keeps something else (fan, turntable or light, most often) from running as well.
Microwave servicing is best left to professionals. There are potentially deadly voltages present, and a chance of microwave leakage if repairs aren't done correctly. Take the oven to a shop for an estimate, or just consider replacing it if it isn't a built-in, an over the range unit or a high-end countertop model.
Feb 02, 2010 | Microwave Ovens
Sharp 1870 just quit cooking and no turntable
The fact that the microwave and convection both do not heat indicated that the oven is in demo mode, check the user manual, otherwise it will possibly be a relay not triggering, may need a pcb replacement, check Demo mode 1st....Phil
Jan 08, 2009 | Sharp Microwave Ovens
Tappan microwave from 1995
check with www.microwaveglasstrays.com or call them toll free @ 1-877-894-0035.
Aug 23, 2008 | Tappan TMS062E1 Microwave Oven
Tappan microwave over the range tmv151f
You can download your owner's manual free here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 08, 2008 | Microwave Ovens
Turns on by itself and turntable does not rotate
You may have a control board issue. Thank God for safety switches.
This is a problem that an integrated circuit tech. can repair, but it may be costly.
Decide how much you want to put into this oven vs. buying a new one.
Contact me once you decide and I can help you find a service center.
Thank you,
Dave E. (Illeagle)
May 30, 2008 | Sanyo EM-S8000 Microwave Oven
Microwave Ovens Logo
56 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
