Question about iLO XM-MP3-CD Car Stereo
Radio won't turn up, nothing from front pass side
I just got a 2002 chevy trail blazer. It has the factory double din radio installed with built in amp. I can only hear a little from the speakers when turned up all the way. I can't seem to get anything from the front right of the vehicle and it's just quiet from all the other speakers. I thought maybe a ground or something with the speaker that would be causing it. The dealership says it is the factory amp that has a short in it. I haven't started diging into it yet and was wondering if i should start at the speaker or at the deck. everything else in the radio seems to be working. there are two front right speakers i can't hear anything out of, the pass door and the pass front dash speaker. please give me better answers than the dealership did, "It'll cost $60.00 for us to even look at it". I think I'll just try it out myself. Must fix soon for road trip!! HELP!!
  • pmotorman Dec 10, 2007
    I have a 97 S-10 Blazer with no sound coming from any of the four speakers. Sometime I get sound after the Blazer warms up inside or has been driven for a while.I have tried three different radio's. One is known to be good. Do the speakers use a common ground?
    President:
  • 3,130 Answers
Ok if you can, pull out the radio. disconnect the plugs off the back. Go here to find the wireing diagram of the 2003 trail blazer as I think it is the same as the 2002. http://www.the12volt.com/installbay/forum_posts.asp~TID~21084 Take a 1 and a half volt to 9 volt battery, and go to each speaker pair and touch the speaker wires to the battery, on and off to see if you hear a click out of the speakers. If you do, You know the speakers are good, if you do not hear a click when you touch the battery to the speaker leads, then of course the speaker or the wiring is bad. It would probably be less expensive to get another radio installed then it would be to get this one repaired or to get another one from the junk yard. Good Luck
Posted on Jun 30, 2007
Why would my 2003 chevy trail blazer pull to the left when I hit the brakes
Check the brake shoes, they are probably worn down to nothing on the left side front.
Nov 01, 2014 | Avid Shorty 6 Cantilever Brakes Front
2002 TRAIL BLAZER BLOW AIR OUT BOTTOM & DEFROST ONLY
vacuum leak somewhere. did someone put in a aftermarket radio? most times they will screw something up when they do replace factory items.
Apr 20, 2014 | 2002 Chevrolet Blazer
2002 s10 xtreme blazer, Is the factory radio a single din or double din
I do believe you can search through Crutchfield.com and in there is an explanation on din sizes and with a vehicle search you can see what size din yours should be.
You should have a double din if it is OEM. A single din is about 2" tall while a double is 4" tall.
There was also a DH (din and a half) found in early 80's to early 90's GM vehicles (and maybe other makes).
Sep 06, 2011 | 2002 Chevrolet Blazer
I am looking at bluetooth radios for my wife's chevy Venture (2005). I keep seeing Double DIN is this correct?
yes this vehicle has a double din radio. the old standard radios like most aftermarket are single din,double din refers to being double size of this.
Dec 13, 2010 | 2005 Chevrolet Venture
Wiring Apine SPS-600C speakers
hey there,i hope the project turns out great,
1) round up all materials needed such as door components and indash radio,install plug for aftermarket radio,get a radio install kit they are like 10-15 bucks ,and if ur doing a double din radio you will have to cut trim to fit and inside compartment behind radio,but if your doin stock 1 din you will be fine.
2) in order to get to radio in dash you must pull dash bezel off from around gauges and radio and the radio has push down release tabs on both sides of radio ...push these down and pull radio outwards.
3) use new wire plug harness and install radio using install kit so radio sits in it and slides back in with tabs.
4) door panels come off with (3)crews that are 7mm near door handle,bottom of door near speaker,and inside where the switch panel is.must pull up switch panel to get to screw others are visible.
5) take mirror cap off and lift upwards on panel the whole panel will come off make sure to unplug vanity light at bottom door and all switches.remove n set to side door ....remove speaker and unplug then install new speaker cut plug install new crimped wire connector caps and install speaker and do reverse to put door back on and this go's for the otherside as well.
6) if theres more to your system write back with any ?'s ok ill try to help as much as possible.
couldn't find anything about the network?
May 17, 2010 | Alpine SPS-600C Car Component System
Double din radio doesn't fit in dash
i have a 2002 ford escape and i bought a double din radio and it did not fit and found out it is actually a din and 3/4 with out serious mods (cutting a bigger hole in dash) double din wont fit i bought a single din stereo and a din a 3/4 dash kit works fine
Jun 10, 2009 | 2003 Ford Escape
2002 CHEVY BLAZER
Can purchased an adapter kit at Best Buy or Circuit City that is color cordinated with the factory wires for about 12.00. This will go right into the factory plug.
Radio 12v orange + radio harness
Radio Ground black - radio harness
Radio Ignition dk. green + radio harness
Radio Illumination gray (dimmer) + radio harness
Factory Amp Turn-on N/A
Power Antenna N/A
LF Speaker +/- tan - gray +,- radio harness
RF Speaker +/- lt. green - dk. green +,- radio harness
LR Speaker +/- brown - yellow +,- radio harness
RR Speaker +/- dk. blue - lt. blue +,- radio harness
Immobilizer Bypass Module: Required: Yes Type: Passlock 2 Part #: 457G, 555L, or 555T
Notes: The Passlock 2 wire colors are yellow, orange/black, and red/white (not used).
Sep 21, 2008 | 2002 Chevrolet Blazer
Chevy blazer wont start 2002
if it turns over there are a cocuple of things to check. crankshaft sensor and the coil pack maybe the computer.id start with the crankshaft sensor
Jun 29, 2008 | 2002 Chevrolet Blazer
2002 Chevy Cavalier audio wiring diagram
to the guy who is looking for the wire diagram, you can buy a wire kit for the stereo connection for about $60 from best buy or some other place like that. your car's door ding and some other things wont work with out it. hope that helps you some.
May 30, 2008 | Car Audio & Video
iLO XM-MP3-CD Car Stereo Logo
346 people viewed this question
Top iLO Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Libran Moreno
Are you an iLO Car Audio and Video Expert? Answer questions, earn points and help others
