Overfill we have a wd420p hotpoint that has started to continually fill with water which we then have to pump out .the wash light starts flashing at a certain level of water any advice?
  • 15,935 Answers
This advice is for a washer that fills and will not shut off, resulting in an overflow. Or, water is leaking from the washer while filling. The symptoms can apply to either a TOP LOADER or FRONT LOADER washer. This may be able to save you from an expensive service call by making these simple visual checks.
Water Does Not Shut Off and Overflows: The water level in a washer is controlled by the Pressure Switch. The switch is usually cylindrical in shape and has an electrical connection and an air hose attached. In many cases, the small air hose comes loose from the Pressure Switch fitting and/or falls off. This air hose is required to detect the air pressure from the wash tub as tub fills. With no air pressure, the switch will not function and the result will be a wash tub that fills continuously to the point of overflowing. The same would be true, if the air hose has any cracks, splits or holes in it.
Water Leaking While Filling: The other end of this hose runs to the air dome fitting on the side of the wash tub. If the lower end of the hose comes off, the water will begin to spill onto the floor under the washer, but the tub will not fill.
What to Look For: Check for the obvious. Make sure the air hose is still attached to the pressure switch and air dome. Then, inspect the entire length of the hose, paying particular attention to areas where chaffing may occur and at the points where the hose connects to the pressure switch and air dome. Vibrations from the washer can cause some wear if the hose is rubbing against anything, and the ends of the hose can stretch over time and not seal properly.
On most top loaders the Pressure Switch is located inside the operator console behind the knob that controls the water level. This knob is commonly referred to as the “Load Level”, “Load Size” or “Water Level”. On front loader washers the pressure switch location is usually located in the back of the washer behind the wash tub, or along the interior cabinet wall adjacent to the wash tub.
How to Correct: If the hose has slipped off, cut about ½” off the end of the hose and reattach to the pressure switch and/or air dome fitting. Take a small zip tie and place it around the hose at the point where it connects to the fitting. DO NOT over tighten as this can damage the air hose fitting. Just make the zip tie snug enough to keep the air hose from sliding off. If the hose has any cracks or holes, you can attempt to seal them by using electrical tape. Replacement tubing can be purchased at any hardware store.
NOTE: This is not an all inclusive fix, as the Pressure Switch can fail in some cases and cause similar symptoms. This is merely a preliminary check for a common occurrence that I have discovered. It can give symptoms of a major problem, resulting in a call for a repairman, only to turn out to be a simple fix that any Do-It-Yourselfer should be able to check and correct themselves. I hope this information is found to be helpful and saves many of you a future service call.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 12, 2010
After commencing a programme my Hotpoint BF71 dishwasher takes in water but overfills, filling the whole of the tub nearly to door level. The waste pump starts for a short burst and then more water comes...
Check for a float switch that senses the water level. It may have two level sense of filled and overfill the latter would trigger the waste pump to avoid a flood. If the filled switch has failed, that could cause the problem. The waste pump MAY also be triggered on the basis of the filling taking too much time before the filled switch actuates... if it has failed, the time would be exceeded.
Dec 13, 2010 | Hotpoint 24 in. BF72 Built-in Dishwasher
Hotpoint BWD 129 machine starts to fill -
Try on a cold wash or rince cycle, if this then works it could be faulty heater element.
Feb 12, 2010 | Washing Machines
Dishwasher keeps pumping out - won't start cycle - green light flashing on panel
I had same symptoms on a Hotpoint dishwasher.
Turned out to be a failed water heater.
The logic in this case goes like this:
When wash cycle starts, the first thing the machine does is pump out any water that has collected in the sump since it was last run.
It then allows a small amount of clean water in and enables the water heater.
If heater okay, it then continues with the rest of cycle.
In this case, the control board detected failed heater so pumps out the water and then stops with an error code shown by a flashing lamp.
No simple fix I'm afraid - machine had to be turned on its side, bottom panel removed, several items had to be removed to get at the water heater which was then repalced with a new one.
You dont state what make/model your dishwasher is so maybe worth adding this information as someone else may recognise your fault and have a quick fix.
Oct 02, 2009 | Dishwashers
I have a hotpoint wd420p washer dryer and its stopped mid cycle. its full of water and i need to know whats wrong
To fix the problem I stripped down the pump and discovered it was jammed with a hair clip!!
Aug 02, 2008 | Hotpoint Washing Machines
Hotpoint aquarius wf740
Sounds like water pressure could be low or inlet pipe is kinked.
F04: possible filling or water level problem. Check water inlet pipe (or shut-off valve), or the outlet pipe, or the pump or pump filter if accessible (check for blockages or foreign objects). Also could be the water valve solenoid weak, causing filling to be too slow.
F05: possible draining (pumping off) problem, check the pump filter, or pump, outlet pipe, or U-BEND.
Don't forget to rate!
Feb 27, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WD420 5+5Kg
The water level vacuum switch are not working , check hose might lose.
Dec 31, 2007 | Hotpoint Aquarius WD640 Front Load...
FDW60 dishwasher
I've just (as of 10 minutes ago) had the same problem. I followed the advice given elsewhere in this forum and removed the bottom cover - water running out so needed a big towel to mop it up. I stood the machine upright and restarted it - no problem! it started straight away.
The question now is where is the water coming from? It seems there is obviously a leak somewhere and water is gathering in the undertray setting off the microswitch.
Oct 26, 2007 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint Ultima VTD20/VTD00
possibly it is overfilling - the pressurestat has a overfill function which turns on the drain pump. how high does the water level get when this happens?
Mar 25, 2007 | Hotpoint Ultima WF860 Front Load Washer
Washing Machines Logo
44 people viewed this question
Top Washing Machines Experts
