Turn to multi region - Televison & Video
  • 32,281 Answers
These WEB sites may have the code for your player.
Unlock DVD Players - Region Free Code
www.dvdexploder.com/
www.download-info.com/dvd/index_new.htm
Posted on Jan 08, 2013
Multi Region Code Support
SEE THE INSTRUCTION. GOD BLESS YOU
  • 1
    Turn on your DVD player.
  • 2
    Open the DVD player's main drive, also commonly called the DVD "tray." The region cannot be changed while a DVD is in the machine, so many DVD players require the tray to be open as an extra precaution.
  • Sponsored Links
  • 3
    Push "Info" or "Setup" on your remote.
  • 4
    Use the remote to select the "Region" option as indicated on your TV screen.
  • 5
    Select "Region 9" to change the system to multiregion formatting. Regions 1 through 8 represent specific geographic locations and will not allow multiregion playback.
Read more: How to Change a DVD Player to Multi Region ' eHow http://www.ehow.com/how_5121939_change-dvd-player-multi-region.html#ixzz2VzwQi6NL
Jun 07, 2013 | Pioneer DV2032K All Multi Region Code...
Region free code for LG BH7520
With your set on and without disc in the tray:
1. Press PLAY from your remote control
2. Press the following button sequence: 1590 2379 390
3. Press PLAY again
This will release the region verification in your home theater (region free). However, some DVDs (multiregion in particular) will not play, since they require region detection from the player unit.
Jun 10, 2012 | LG Televison & Video
Apparently they are locked to region 4 and I have bought region 1 DVDs so they won't play
In most models the unit cannot converted to multi-regions.So it will play only in the specified region in which it is applicable to.But in some unit models there is a procedure to turn the unit to multi region so it can play all region dvd.On all models the procedure to convert the unit to multi region is different.As you have not mentioned the exact model number of your unit.t will not be easy to give exact details.If in case there is a procedure to convert your unit to multi region.
Thanks. keep updated for any more query.you can rate this solution and show your appreciation.
Sep 14, 2010 | LG Audio Players & Recorders
Problems changing region code on Samsung DVD player VR 375
HELLO!
Give these a try!
Power ON
Press MENU
Enter code 57538
The current region code appears
For codefree/multi-region press 9
Press Open DVD door button
Power OFF and power ON
You could also try this!
Turn player on without disc inside Press MENU button
Enter your region code (See list below)
Highlighted 'region area number' will appear in the upper-left corner (on some players)
Press 9 to multi-region the machine
Turn machine off
Region 1 - 29334
Region 2 - 38767 (or 5 7 5 3 8)
Region 3 - 56732
Region 4 - 76884
Region 5 - 53814
Region 6 - 24462
Have a go and good luck! (:-)
Sep 11, 2009 | Samsung DVD-VR375 DVD Recorder/VCR
I need to dezone my dvd player panasonic XV N 670B (bought in a US shop, zone 1, but I live in Europe , zone 2)
Not possible, sorry.
Region code in Panasonic DVD player is not possible to break.
Thanks.
Aug 16, 2009 | Televison & Video
How can i make my lg DP481B portable dvd player multi region. It is Region 4 currently
  1. Turn power on
  2. Open tray
  3. Press 0, 0, 0 (with remote)
  4. Change the region (0 = multi-region)
  5. Press PAUSE
Aug 02, 2009 | Televison & Video
Multi region code for GPX PDL 705 portable DVD player
I hope this helps^^ try it and gimme a shout!
Turn on power.
Open lid.
Push 9 7 3 5 from the remote.
Select 0 using arrow keys.
Exit Setup.
Done.
The one above did work me, only that after one turns on the player, enter in the 9735 with the remote and press 'enter', you can choose between making your player region-free or a different region in addition to R1. Select the desired region unlock and press 'enter'.
Make sure you check the bottom of the DVD player to see if it was manufactured in the first quarter of 2007, that might factor in whether the code can work or not.
Apr 01, 2009 | GPX PDL705
Need to multi region Phillips Soundbar
HI Ian,
Have also just purchased a Philips HTS8140 with Philips LCD screen.
Found a result on web as follows:
1.Turn on TV
2.Turn on Sound Bar System.
3.Press eject.
4.Press 9 9 9 0 (0 being Region Free or place the desired region #)
(a message displaying "region 0",or the region you chose, will appear on the screen.)
5.Switch soundbar off to soundby.
6.Turn player back on and it should be either region free or the region you selected.
So far I have not been able to check with anyother disc exept region 4.
Hope this is of help for you!
Xtopher
Jan 10, 2009 | Philips SoundBar DVD Home Theater with...
Make my dvd multi region
Turn DVD on - no disk loaded
press 'Menu'
Enter 76884
While '4' is showing on the screen in the top LH corner, press '9' for multi-region.
Sep 18, 2008 | Televison & Video
MEMOREX MVD2040 UNLOCK CODE
This is all I could find ..... Memorex DVD-2000 C/P / MVD-2020 / MVD-2022 / MVD-2027 / MVD-2027 A / MVD-2028 / MVD-2029 / MVD-2030 / MVD-2037 / MVD-2051
  1. Open the disc tray
  2. Press CLEAR
  3. Press 1, 3, 6, 9
  4. Enter region (0 = multi-region)
  5. Close the disc tray
  6. Turn the player off
Memorex MVD-2042
  1. Press OPEN/CLOSE
  2. Press 9, 7, 3, 5 (or 1, 3, 6, 9 for the "suffix B, C, D" model)
  3. The setup menu will appear
  4. Press RIGHT to move the cursor to highlight the regions
  5. Select region using UP/DOWN (0 = multi-region)
  6. Press ENTER
    (or try the instruction for MVD-2020 above)
Memorex MVD-P1072
  1. Turn on the player (without a disc inserted)
  2. Press SETUP
  3. Press 9, 2, 1, 0
  4. Select region (0 = multi-region)
Jan 16, 2008 | Memorex MVD2040 DVD Player
Televison & Video Logo
13 people viewed this question
Top Televison & Video Experts
Electro Med Services...
