Question about Brother XL-2600
Light bulb goes out when starting to sew - Brother XL-2600
  • Brother Master
  • 7,365 Answers
Check to make sure the light bulb is inserted correctly
if it is ,, then there could be a short in the wiring
Posted on Jan 08, 2013
What light bulb fits 4300 Morse sewing machine
The Morse 4300 and 4400 use the same small 15W screw in light bulb as many other sewing machines. This is one vendor: https://a1sewingmachine.com/LB716sm~Bulb%2C+15+Watt+Small+screw+in+base.htm . Another source is https://www.sewingpartsonline.com/light-bulb-white-7scw.aspx .
I hope this helps. However, if you have a bulb in the sewing machine, take it out and confirm that it is the screw in type. (If there is no bulb, look at the socket for some turns for threading in a bulb.) If the bulb or socket doesn't have threads, then look for a 15W push and twist bulb at sewing machine parts suppliers.
Nov 08, 2017 | Sewing Machines
Hi, I have a Brother 1034d serger and it's practically new bought it in December last year and just started using it I made 8 skirts and the light bulb keeps blowing. I went to the store Lowe's and found a...
the main problem with blowing light bulbs on sewing machines is arcing caused by a loose ground that touches on the side of the bulb base as it screws in
disconnect the power from the wall sacket
use a suitable implement and bend that ground piece back towards the center of the holder so that you have a resistance when screwing in the new bulb
The arcing is in fact power fluctuations that have spikes or surges and bulbs do not take kindly to that sort of power problems
Only the bulbs from sewing machine spares shops should be used as general purpose household bulbs are not always successful because of the vibrations caused as the machine is sewing
Sep 07, 2017 | Brother Sewing Machines
Why does the built in light go out as soon as you start sewing and comes back on when you stop?
sounds like there is a short in the wiring somewhere in the machine, it would be a good idea to have it checked
Jun 11, 2015 | Bernina Sewing Machines
Where is the light bulb located on a Memory Craft 4000 sewing machine. Need to change light
Hi Rhonda I have a 9000 and a 500e and the light should be directly above the needle shaft.
Good luck
Jan 20, 2015 | Janome Sewing Machines
Replaceing an exploded light bulb
cut a potato in half and press the flat spot into the remains of the bulb, and turn carefully
Jun 16, 2013 | Brother LS-2125 Mechanical Sewing Machine
How do I unhinge the the piece where the bulb goes
are you trying to replace the light bulb?
Mar 17, 2012 | Sewing Machines
Need to know how to change the light bulb
There are lots of different bulbs and different ways of removing them. Some just push in, some are push and twist, some screw in. Call a shop that sells your brand (have your model number ready) and they will sell you a bulb and show you how it goes in.
Feb 11, 2010 | Sewing Machines
Light goes out when I start to sew
This may or may not help.. first UNPLUG it..then unscrew the light bulb and look at the base of the bulb socket.. you should see a tang there ( small tab) that makes contact with the bulb.. sometimes that gets compressed to a point that it won't make electrical contact with the bulb or intermittent contact and the bulb flickers.. You may also have a loose wire on the socket terminals too.. Depending on your electrical skil level, you may or may not want to look into repairing that yourself.. Hope this helps..
Oct 11, 2008 | Singer 7462 Mechanical Sewing Machine
Brother XL-2600 Logo
32 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
