Question about SanDisk 16GB Ultra Backup USB 20 Flash Drive 16 GB USB External Hard Drive
My sandisk backup 16gb usb will not open; every computer i put it in says to format, but i do not want to lose everything on it!!! first of all, can i fix it so i can recover my files? secondly, what did i do to cause this so it won't happen again? thanks!
  • SanDisk Master
  • 27,725 Answers
Click start click to open on my computer you should see your usb drive could be E: or something right click select properties there will be an array of options select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7 Click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive then you restore it to its default status Right click on usb drive select properties you will have an array of options Select the hardware option then select your drive properties policies restore defaults In XP Right click on your drive select properties then on customize restore Default in W 7 You might have to alternate doing this repeatedly until the problem is resolved Click start control panel scroll to folder options view place a tick in show hidden files folders and drives
this may vary depending on your operating system.
If you need more help with this post a reply Hope this helps.
Posted on Jan 08, 2013
5 Suggested Answers
JoAT
  • 121 Answers
SOURCE: USB flash drive wipe out
I went to the Sandisk website and they actually have a bunch of how-to videos on there that will help you out with your problem: http://www.sandisk.com/Retail/Default.aspx?CatID=1459 As for getting your information back, you would need special recovery software in order to do that. Here is a link that might be able to help you with that: http://www.download.com/VirtualLab/3000-2248_4-10642058.html
Posted on Mar 23, 2007
  • 6 Answers
SOURCE: Error occurred while initializing U3 Launchpad
Your SanDisk Cruzer® Micro SDCZ6-2048 (2 GB) USB 2.0" may be giving problem due to the internal errors.
Therefore 2 GB card may be scaned through anti virus, if problem repeats then format ur card from the computer.
Posted on Jan 23, 2008
Xome
  • 79 Answers
SOURCE: my sandisk cruzer blade 8gb is very slow in file
Formating a Hard Disk loose a very tiny capacity which we can't sense. Sandisks are very fast one. Ithin your USB drivers are not updated.
Think this is helpful !
Posted on Aug 11, 2010
anncandy01
  • 10 Answers
SOURCE: sandisk suddenly says the disk is not formatted
Possible Reasons:
1. The device is too old and can be corrupted with time went on. As you know no hardware can be life-long ever.
2. There are bad sectors in the specific area of the disk that is required for a file system, e.g. for a boot sector or the FAT table sector. Since such a drive is obviously not possible to use, Windows refuses to format it.
3. Sometimes, you cannot format the drive to the FAT file system if it has been formatted to a file system which is not recognized by Windows. Such a drive should be reformatted to NTFS first, and then to the FAT file system.
Solution:
Step 1: Try the problem removable disk on another computer (better be most common Windows OS). See if the device can be accessed normally. This way can clear the buffers and eliminate incompatibility. Sometimes it will let the error disappear and make the drive work normally again.
Step 2: If the first method still won't help. Try recovering the data with some data recovery programs first of all. If you are running Windows, you can use Data Recovery for Windows. For Mac OS X users, turn to Data Recovery for Mac
Step 3: After the files are recovered, then follow those steps to try format the error drive (connect the disk to your PC first). My computer -> Properties -> Manage -> Computer Management -> Storage -> Disk Management -> select the problem drive and then format it from here.
Step 4: It's not over. After formatting, try use the data recovery software recommended in #2 to re-scan the drive to see if you can harvest more data. Note: format won
Posted on Aug 11, 2011
How i format my 16gb data traveler
If your computer is XP, Vista or Windows 7, right click on the "My Computer" icon,
then left click on "Manage", on the left side list left click on :"Disk Management".
If your fash drive is pluged in and detected it will appear on the list of drives.
Look for the 16GB drive, then left click to have a list of option to perform on
the drive. Select "Format" and a pop-up window will appear for formatting options.
I recommend "Fat 32", as it is best for normal transport or backup option.
Aug 24, 2011 | Computers & Internet
When i try to transffer data to the sandisk sd 2gb card im getting 0x8007045d error help please
it is because your card is formated as FAT ( this means that you can only store small files on it ). To fix this do the following 1. open my computer 2. right click on th sd card 3. press format 4. in format select fat32 instead of fat 5. click format (you will lose all data currently on the card) 6. when it is finished you should be able to copy files onto it
Mar 16, 2011 | SanDisk 2GB microSD Memory Card
How do I copy my pictures FROM my SanDisk 16GB cruzer flash drive to another computer
You just need to go to "My computer" and then there should be an icon for it. Click that icon and you should see your pictures,then just drag and drop them to the desktop or wherever it is you'd like to keep the pictures.
Mar 09, 2011 | SanDisk EACH Flash Drive, USB 2.0, 16GB,...
I am entering the correct password for Sandisk Cruzer Micro 16GB. But It says the password is incorrect. I have one out of five chances left before the drive is locked permanently. I am 100% sure that I...
You're out of luck on this one that is why they put the security feature on there. You'll either have to take a chance with another password and lose your info or format the drive and lose the info anyway. Sorry couldn't be much help.
Aug 26, 2010 | SanDisk Cruzer Micro 2GB USB 2.0 Flash...
Sandisk cruzer 16gb, Macformat, tv won't recognize
Dowload codec Klite pack, via Google, and open the files with that media player, the tv should then pick it up, seeing as its a multi codec reader program, Hope it helps
Jan 16, 2010 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Can't open my sandisk cruzer 16gb
i have a 16 gb pendrive which is detected in my mac but not in any windows...............help me out here
May 10, 2009 | Electronics - Others
Dont worry about being prompted, that is an OS option and you may of turned off by accident. When you insert the flash drive into your USB port, does th elight on the drive ligh up? If not your flash drive may of gone bad.
If it does light up, click on "My Computer" and see if it shows up there.
Apr 03, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
USB flash drive not holding data
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Dec 12, 2008 | SanDisk Sansa e250 MP3 Player
Can't format my sandisk micro cruzer 16gb flash drive
Try this --
Download the HP disc format tool using this link--
http://www.eocfiles.com/bdc86eb1ed2989c30dcd1902e84939ae/bootdisks/SP27608.exe
After downloading the file you need to install this.
After installation,launch the software, and select the Flash Drive Letter and try formatting.
If this does'nt work,plz let me know and I'll give you one more alternative.
Nov 13, 2008 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
SanDisk 16GB Ultra Backup USB 20 Flash Drive 16 GB USB External Hard Drive Logo
96 people viewed this question
Top SanDisk Computers & Internet Experts
Sandy Moore
Sandy Moore
Cleverer2
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
