No picture on sylvania 15" lcd tv
The TV has sound but no picture. The LCD screen illuminates but it has no detail.
There are some color stripes running vertically on the screen.When you press a menu button the stripes move but you get no menu
  • 1 more comment
  • imgone1 Jan 20, 2009
    the model # is sylvania 6615lf
    There are some color stripes running vertically on the screen.When you press a menu button the stripes move but you get no menu. the model # is sylvania 6615 LF
  • imgone1 Jan 21, 2009
  • 19,396 Answers
Question: "The TV has sound but no picture. The LCD screen illuminates but it has no detail.
There are some color stripes running vertically on the screen.When you press a menu button the stripes move but you get no menu."
Answer : most common reason for vertical stripes on screen on an LCD TV or Monitor is a bad LCD ribbon cable or connector.
The TV must be tested with a replacement LCD cable, or the cable tested for continuity using a multimeter.
On few models LCD controller is directly connected to display, in that case, check LCD controller connection to display panel.
If the cable is fine, then as already stated the problem is a bad video chipset on LCD controller board.
The controller board is not serviceable, and when this happens the board must be replaced.
Here the replacement board: 6615LF4
Call the seller to get a replacement cable set.
Or get in touch with Sylvania customer support and ask part price, or availibility of extended warranty.
Posted on Jan 21, 2009
  • 11,896 Answers
There are several possibilities.
It is possible one of the internal fuses blew out.
It could be a bad horizontal outut transistor.
It could be a bad secondary of the power supply went bad
And many other things.
If it's just a fuse, it won't cost much, but a lot of them do not look like you would expect a fuse to look like.It might be a little yellow, green, or gray rectangualar box shaped part.
  • 10,594 Answers
Symptoms shows that "LCD Controller board" is defective.
You can get the required board from Shop Jimmy for approx $40 and its easy to replace.
Posted on Jan 20, 2009
  • Shahid Electronics
    Shahid Electronics Jan 21, 2009
    Sound is OK and picture is not there. LCD has some color vertically strip.
    Above symptoms shows problem of LCD Controller and image of subject board is appended below.
    Above board is available in Shop Jimmy for $40
    Genius:
  • 1,550 Answers
  1. Most common would be a couple of capacitors in the power supply that are not letting the proper voltage to the lamp.
  2. The lamp itself is not working properly.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Your described problem indicates a problem with the video interface/mainboard. It is doubtful for the power supply to be defective since the unit powers on nor would the inverter and/or thew bascklights be faulty since they "illuminate"
If our could postback the brand and model number, then a more detailed diagnosis could be forwarded.
Goodluck and thank you for using FixYa.
  • Louie  Role
    Louie Role Jan 21, 2009
    Appreciate the postback.
    As earlier stated, it apparently is the mainboard shown below and available here.
  • 1,031 Answers
If there is no image with the flashlight (when the TV is acting up) then you have an issue with the main board. There is usually just one board in these TVs that controls video processing and display. It may have an intermittent problem - solder joint, maybe a bad cap. You would have to open her up to figure that out
  • 1 more comment
  • Starnley Johnwells
    Starnley Johnwells Jan 20, 2009
    so its probably the backlight inverter board or the backlight controller IC
    l.also, the inverter dynamic dimming is
    controlled by the main pcb, so if the main has a fault, it would "turn
    off" the inverter, a technician can short the dynamic dimming pin to ground, if the inverter fires up and
    the light is on, then its the main pcb, if not, then its the inverter.most panels dont have a replaceable inverter.in most cases, it is part of the display panel itself.
    You most likely have a backlight issue with this TV set. Could be the
    inverter circuits for the backlights. The inverter is the power supply
    source for the backlights. there could also be a screen driver problem
Hi, Need help with ProScan TV mo#32LB30QB.
T'Con board fault. Check and replace it. If you wish to get some details; check the site linked here. Pull up older posts.
Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Jul 25, 2016 | Proscan 32LB30QD 32 in. LCD TV
What does the digital board do in a element tv work? My tv screen goes to a solid color can hear sound but can't see the picture. Had the main board changed and that did not help
Sounds like display panel fault. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Fault to Display Panel to all LCD TVs are almost similar, irrespective of its screen size and brand.
Dec 11, 2015 | Element Skateboards Element ELGFW551...
My Sylvania TV has vertical lines on the right side of screen
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
https://www.youtube.com/watch?v=TR2iWN6b-LY
LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
Apr 14, 2015 | Sylvania Televison & Video
Screen is flashing only solid colors not picture on sylvania ld320ssx LCD tv
- Flickering screen
- Dim screen
- Slow start
Mar 02, 2015 | Sylvania LD320SSX LCD TV
I own a Sylvania 6620LDF 20 in. EDTV-Ready LCD TV/DVD and my cousin punched the screen and a big amount of color lines are popping out no image comes out, crak is still there, tv can still turn on but no...
When he hit the screen, he most likely broke through the protective glass screen and broke the lcd screen that displays your picture. It's probably better for you to just replace the tv itself, it'll be more costly to repair the tv than to replace it.
Mar 06, 2011 | Sylvania 6620LDF 20 in. EDTV-Ready LCD...
I have a 3 year old lcd color 15" flat screen digital dolby mod. # lc200sl8 A the picture comes on but the whole picture is white you can see some color but very light I have tryed to darken it but won't...
I don't know if your set has a separate power supply but this sounds like the failure of a low-voltage circuit supplying power to the section which modulates the individual pixels on your display.
Sylvania is one of several names owned by Funai which is the worst of all Asian manufacturers.
Jun 26, 2010 | Sylvania LC-200SL8 TV
Turned on my TV today to find a 5" horizontal stripe across the middle of my screen. I can view the picture through the stripe but the picture brightness on the top 1/3 and bottom 1/3 of the screen is much...
This sounds like an impact injury to the screen itself. It is likely that something may have hit the screen or if the set is old, the part inside may be starting to go.
Hope this helps
Nov 27, 2009 | Sylvania LC320SS8 32 in. LCD Television
My sylvania lcd tv screen went white and still has sound
Hi taralee? my tv did the same thing last night. can you tell me what you found out? can it be repaired? thanks
Aug 23, 2009 | Televison & Video
Dropped Magnavox TV
Most likely the LCD panel itself had damaged.
Jan 01, 2008 | Philips Magnavox 15MF400T 15 in. LCD...
Televison & Video Logo
73 people viewed this question
Top Televison & Video Experts
