Question about Kenmore 24032\24036 Top Load Washer
I want to clean my water inlet valve but i can't take the top off the washer
    President:
  • 1,214 Answers
It appears the valve is accessable from the back rear, not the top.
Go to Sears Parts Direct and enter your model number for exploded view details.
Normally you would clean this valve by turning the water off, moving the washer away from the wall, then disconnecting the hoses and cleaning the screens in either the hose ends or the valve inlet connection.
The valve(s) are not usually serviceable.
Posted on Jan 20, 2009
Rinse cycle not much water
see the next steps and use the common sense:God bless you
Water Inlet Valve
First check the hoses that connect to the water inlet valve. Remove these completely there should be a screen in at least one end and maybe both ends. Clean these screens. Next check the back of the water inlet valve screens and remove and clean. If cleaning these out does not correct the problem you will need to check to make sure you have power going to the water inlet valve. Most top loaders will have 120 volts going to the valve. Check each solenoid on the valve. You will need to have the washer on and turned to a fill cycle when checking. If you have power and still no water replace the water inlet valve. No power replace the control.
Control / Timer
This is less likely the problem but can fail. If you have no power going to the water inlet valve when selecting a fill cycle the timer/ control has failed and you will need to replace the timer.
Aug 01, 2012 | Roper RAS8445KQ Top Load Washer
Ge toploader whse5240D1WW will not fill with water
please the causes and remedies: God bless you
f your Top Load Washer Has No Water Entering Check The Following
Water Inlet Valve
Control / Timer
Jul 18, 2012 | GE WHSE5240D Top Load Washer
Washer fills extremely slow. Hoses are fine water
Hi, check to see if there's good water volume coming through the hoses attached to the washing machine. If there is, check to see if the screens inside the water-inlet valve are clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If they're clean, you probably have a defective water-inlet valve. If so, you should completely replace the valve.
Jun 19, 2011 | Maytag PAV2300 Top Load Washer
How do i clean the water hose filter
On the back of the Washer, you have your hot and cold water hoses that hook up to the Washer Water Inlet Control Valves. Shut the water off at the Main water valves in the wall. Disconnect the hoses from the Washer and check the filters inside the Water Inlet Control Valves.
Mar 14, 2011 | Maytag Centennial 3.2 cu. ft. SuperSize...
Cold water rinse takes hours to fill
Check to see if there's good water volume coming through the hoses attached to the washing machine. If there is, check to see if the screens inside the water-inlet valve are clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If they're clean, you probably have a defective water-inlet valve. If so, you should completely replace the valve.Replace the water inlet valve with this part.
Dec 26, 2010 | Whirlpool LSR5132PQ Top Load Washer
Frigidaire FEX831CS Top Load Stacked Washer won't fill with water
First you should remove the hoses and clean the screens in the ends of the hose, some hoses have screens in both ends. While the hoses are removed look inside the water inlet valve there should be a screen in there also remove and clean the screen out. Some screens will not be removable so you will need to clean in place or remove the water inlet valve. If all is clear you will need to check the solenoids on the water inlet valve for power.If the solenoid has power when put in a fill cycle and no water eneters your washer you will need to replace the water inlet valve. Most water inlet valves must be replaced as a unit, so if one solenoid fails you replace the hole valve assembly. These are inexpensive and easy to replace. There is a video at http://appliancehelponline.com/topwaterinletvideo.html that will walk you thru the testing procedure. It may be a different model but the testing will be the same. If you need help disassembling there are also videos of disassembling most styles. You can also enter your model # for diagrams and illustrations of your specific model. Not all models will be available. All parts come with installation instructions.
Jun 03, 2010 | Frigidaire FEX831CS Top Load Stacked...
Water pooling in washer in between loads
The problem is caused by a leaking water inlet valve and the only way to solve it is by replacing the water inlet valve assembly. It is an easy "do-it-yourself" fix that only requires a minimum effort.
Water Inlet Valve Replacement Procedure
  1. Remove the three screws at the back of the machine holding the top cover.
  2. Slide the top cover to the back and lift it from the washer.
  3. Put a bucket or pan under the inlet valves.
  4. Remove the fill hoses from the machine and drain the water into the bucket or pan to avoid flooding your floor.
  5. Remove the screws holding the water inlet valve assembly to the back of the machine.
  6. Use a pair of pliers to press the spring clamp holding the inlet hose to the inlet valve assembly and move the spring clamp away.
  7. Install the new water inlet valve assembly and all other parts disassembled in reverse order of the procedure above.
  8. Make sure to clean the fill hose filters, if there's any, before attaching it to the water inlet valve assembly.
Jan 20, 2010 | Kenmore Elite 45986 Front Load Washer
Water goes in very slow. Cleaned the intake filter where the hoses connect.IS the valve worn out to where it does not open all the way?
Check if the volume of water supplied to the washer from the water line through the hoses attached to it is good. If yes, the screen inside the water-inlet valve if it is clean. If clean, the water inlet valve is defective and you need to replace it. The water inlet valve is located inside the washer on the upper back portion. It is where the water supply hoses are attached to.
Oct 26, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer doesnt take hot water
All the symptoms described are typical of a water inlet valve that has either become clogged with sediment or has a solenoid failure. You can elect to replace the water inlet valve, or attempt to clean. Cleaning requires shutting off the water source and disconnecting the inlet hoses. Check the sediment screens in the water inlet valve and clean with cotton swabs and distilled vinger. Place the hoses in the wash tub and turn on the water supply to make sure the hoses are clog free. Sometimes a good cleaning can help. However, the majority of the cases involve replacing the valve. The following link explains how:
http://www.fixya.com/support/r600647-replacing_water_inlet_valve_kenmore
I hope this information is helpful. Anyone with questions are encouraged to post back and let me know.
Aug 01, 2008 | Kenmore 24032\24036 Top Load Washer
Maytag atlantas top loader water keeps dripping from top of drum
Your water inlet valve is probably leaking by. If the water pressure is too, or if there is sediment build inside the valve, sometimes the solenoids will not close properly. Try cleaning the valve to see if this helps. If not, I would recommend replacing it. Depending on which valve you have, repairclinic.com has two listed for this model washer for $20 to $30. Let me know if this helps, or if you need further assistance.
Apr 23, 2008 | Maytag Atlantis MAV6260AWW Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
22 people viewed this question
Sal De
fordexpert
Robert Rankin
