Question about Duravit Duraplus, Two-Piece Toilet - D13018
Fixing durovit 2 piece toilet cistern - Duravit Duraplus, Two-Piece Toilet - D13018
3 Suggested Answers
  • 5 Answers
SOURCE: cannot remove top of cistern
There are some dual flush cisterns where you have to depress one button to reveal a cavity in the second button. Put a screwdriver in that cavity to lever out the second button, then release the first button and prise that out.
Underneath the buttons is a screw which must be unscrewed to release the cistern lid.
Not sure if this will apply to you... but if not, good luck anyway.
Posted on Jul 02, 2010
  • 517 Answers
SOURCE: Toilet Flush. We have an integrated toilet
Good day!
OK please double check the connection and proper installation of it..
and try to look the cable if you press the button it should go up together with the rubber..
try to adjust the cable to upward..
if you have follow up question just add a comment to give you another idea..
thanks for using fixya and have a nice day!!!
Posted on Jun 29, 2011
Caroma toilet 12years old, concealed cistern. Water leaking around base when toilet is flushed. water level maintained when not flushing, so the leak must be between the cistern and the bowl. Had a plumber...
Fixing a leaky toilet is actually rather simple, requiring few tools and just a little time and effort. In looking at Caroma toilets on Google, they appear to be just a standard type of unit, and should present few if any problems for yourself or any handyman of modest skill.
If it is leaking around the base of the toilet - where the toilet sits on the floor, the repair item is a simple wax seal. Here is a tutorial to effect this repair: Replace Toilet Wax Ring. The wax ring is very inexpensive, usually $5 to $10 USD.
If the water is leaking from between the tank (cistern) and the toilet bowl, the job is even easier, as it does not require lifting and moving the entire toilet. A good tutorial for that repair is here: How to Replace Tank to Bowl Gasket . The gaskets, new nuts, bolts and rubber seals come in a kit and also cost only $5 to $10 USD.
I am sorry to hear your Plumber insisted you buy an entire new toilet, but do remember he is in the business of making money!
Jan 28, 2014 | Home
Tip
FIXING A TOILET THAT WILL NOT FLUSH!!! a simple but very effective money saving...
This simple how to, is based upon most lever operated toilets, with the cistern mounted above the toilet bowl. The make and model of toilet used for this feature is of the following:
Toilet and internal syphon
DUDLEY ELITEDudley S7 Cascade syphon
Problem:
My toilet will not flush, but the ball float valve is working and there is water in the cistern; no leaks present and the flushing lever is not broken or disconnected, what do I do?
Answer:
first isolate the water to the toilet or the main water supply to the house. Bail out the water from the cistern using a small jug or cup, (or you can syphon the water manually using a hosepipe or similar pipe, a towel to cover your mouth, and either a bucket or the toilet bowl) and remove water from the bottom of the cistern with a sponge.
Changing the syphon in a toilet that is not close coupled is far easier as you do not need to remove the cistern from the wall!
Undo the lower of the two large nuts beneath the cistern using a large pipe wrench or pair of water pump pliers, now disconnect the flush pipe and push it to one side.
Place a bucket or bowl beneath the cistern and undo the Nut which is immediately below the cistern (syphon replacing nut), some water may be released by the syphon, take note of any washers that are removed as new ones need fitting when replacing the siphon.
Unhook the lift rod from the flushing lever and remove the syphon.
Inside the toilet syphon, there will be a small plastic piece of sheet called a diaphragm; you can fabricate a replacement using the plastic title cover on a DVD case. Cut this to the exact same size and shape as the original part, and fit this to where the original diaphragm was. This is your new replacement.
Refitting is a complete reversal of removal, be sure to fit any washers (preferably new ones) that you have taken out. Ensure everything is tight but do not over tighten before refilling the cistern
on Aug 09, 2010 | Plumbing
Dux toilet cistern problemsolving
can only be one of 2 things. the inlet valve is not shutting off properly and so the tank is overflowing into the toilet bowl or the flush valve rubber is worn out. you can find this at the bottom of the flush valve mechanisum.
Dec 04, 2013 | Home
Water level too high in Gruppo Italia in-wall cistern
check if mechanism that releases water when you flush is tight so no water escapes.
As for water level, you can adjust to less in the tank.
Jul 27, 2013 | Kohler Toilet - One Piece with Ingenium...
Have a Duravit Starck 3 2-piece toilet 2105010000 Hinges that hold the seat and cover are broken. Where are these hinges available?
Unfortunately you won't find a universal replacement part to work with this seat which you would commonly find at your local hardware store. I've looked through the Durovit site and could not find a parts catalog. Try using the find retailer option on the manufacturers site and if there isn't a retailer in your area contact the manufacturer directly to see if they supply parts for their seats. I'm guessing they don't and you would likely have to purchase a new seat.
http://www.duravit.com/service/find-a-retailer-useo6suuk8.html
Duravit USA, Inc.
2205 Northmont Parkway
Suite 200
Duluth, GA 30096
Phone +1 770 931 3575
Toll free: 888 387 2848
Fax +1 770 931 8454
Toll free: 888 387 2843
info@usa.duravit.com
Aug 02, 2010 | Duravit 0063810000 Stark 3 Toilet Seat and...
The toilet cistern is filling up but the toilet pan is not getting enough water presure to empty
check that the water in the cistern is up to the mark etched on the inside
Do you have a close couple or a washdown [with pipe from cistern to pan]
Mar 04, 2010 | Home
After cistern refill outflow into toilet bowl continues to dribble in - and you can see a slight flow into the bowl and every so often we hear the cistern refilling a small amount to compensate.
hi i would suggest your ball valve in the cistern needs ajusting remove the top of the cistern you will see the ajustment screw at the end fo the ball **** arm hope this helps
Nov 15, 2009 | Duravit 0910100005 Happy D Toilet Cistern ...
Toilet cistern doesn't fill up
it sounds like one or more of your shut off valves has a glog from hard water calcium. were from indiana its a big problem here.To check this u will have to shut off main water supply and remove top of shut off valve and check for white crusty blockage, even if u see a few particals its present. It can severely restrict flow.
Apr 21, 2009 | Kallista Michael S Smith Country Elongated...
Can old style dual cistern be converted to new style 6/3
We have not solved the problem but after speaking to 3 Major Plumbing Supply Places
they have told us we have no alternative but to replaced both the whole toilet suite's
as older style pans don't match up with never models
Jan 04, 2009 | Home
Duravit Duraplus, Two-Piece Toilet - D13018 Logo
Top Duravit Home Experts
Paul Carew
Lawrence Oravetz
Andrew Taylor
Andrew Taylor
Are you a Duravit Home Expert? Answer questions, earn points and help others
