Question about Cuisinart CBK-200 Bread Maker
Cbk 200 does not preheat/clicking sound/doesn't knead
When I put in my settings and press start, it says it's preheating, but the thing never gets warm at all. Then it goes into the kneading cycle, but the paddle does not turn at all, and the panel with all of the setting buttons makes a clicking sound. I took the pan out and confirmed the kneading paddle is in correctly and the base of the the pan is easy to turn by hand so it's not stuck. I also tried to make sure the pan was pressed down firmly into the machine.
    Genius:
  • Cuisinart Master
  • 1,280 Answers
You may have a broken belt (not uncommon) Unplug your machine, remove the pand and paddle and turn the machine on its side. See if you can remove the metal panel on the bottom of the machine. Once you do that you will see if your belt is broken or has slipped off. It it is either of these you can reach me at breadmachineshelp.com I can then tell you how to get your belt back on or replace it.
Posted on Jan 11, 2013
    New Friend:
Ok, I pulled off the bottom and the belt is not broken, and there are no tears in it. It is still just making a clicking sound. I think I need to just replace the unit since it is out of warranty unless someone has another suggestion?
Posted on Nov 25, 2014
SOURCE: clicking noise when on the knead cycle and the
I am having the same problem. I just purchased my machine last week. I made regular white bread last week and it worked great, but today I tried to make whole wheat bread and it froze. Any solutions for this?
Posted on Jan 19, 2011
  • 433 Answers
SOURCE: My cuisinart bread maker is making a clicking
If the motor shaft is not turning it could be the belt has fallen off the pulley or the pulley is slipping, or the motor is broken. The motor, pulley and belts are located inside the base of the machine. Hopefully it's just a loose belt. Hank
Posted on Jan 28, 2010
FlightLeader
  • 18 Answers
SOURCE: The machine stops kneading in the middle of the program
Even Replacement May Not Help for Long.
After my six month old CBK200 had the same stop and start malfunction I was sent a brand new replacement by the company. Three months later the new unit started doing the same thing. I am putting up with it for now, but as soon as I have a little more time, I will go back to the authorized repair depot and request another replacement and hope for the best.
Posted on Aug 17, 2009
daryl441918
  • 1280 Answers
SOURCE: My bread machine (CBK-200) worked beautifully for
reach in with your fingers and bend the two little clips out a little until they grip your pan snugly. Start with 1/4 " and try that. If it doesn't feel snug go another 1/4 inch.... and so on....
Posted on Jan 20, 2011
daryl441918
  • 1280 Answers
SOURCE: I have a cuisinart CBK
some machines do just rotate in one direction and that is enough to knead the dough. Was the final result (the baked loaf) not satisfactory?
Posted on Sep 19, 2011
I press start and it just sits on prheat heat.
Many bread machines pre-heat on the whole wheat cycle. Give it up to 30 minutes and it should start mixing within that time frame.
Jan 13, 2013 | Cuisinart CBK-200 Bread Maker
My bread pan doesn't sit correctly so the paddle doesn't move around well, especially when it kneads faster
First pull the springy steel clips out so they bend some and stick out a little further this will hold your pan in better. Before putting your pan in make sure the little ears on the underneath side of the pan are lined of roughly opposite of the pan ears in the bottom of the oven that push the paddle around. If that doesn't make sense contact me.
Oct 01, 2011 | Cuisinart CBK-200 Bread Maker
My breadmaker makes a clicking sound when started but does not knead.
That is normal. It is warming up and that is the clicking sound you hear. It should start after a few minutes (less than 30 minutes is normal).
Apr 16, 2011 | Cuisinart CBK-200 Bread Maker
The oven preheats, but then "cools down" before I
Most likely the problem is your bake element. When the oven is preheating it uses both the bake and the broil element. When it's done preheating it uses only the bake element, so the broil element is heating it up, and since the bake element is not working the temperature drops until it starts preheating again.
Jan 30, 2011 | KitchenAid KERS807SSS Electric Kitchen...
How long is the preheat?
Typical preheat on most bread machines is under 20 minutes. If your machine hasn't started mixing/kneading by 1/2 hour then there is a problem with your machine.
Nov 30, 2010 | Zojirushi BBCC-V20 Home Bakery Traditional...
Damn! I have the same problem too... and I only used the machine once today for the first time..... only once.... i went and bought a bunch of ingredients and wanna try out some more recipes, but it...
The clicking sound is just the sound the unit makes when it heating up. Most bread machines do that. Many of them preheat because the ingredients have to be at the right temp to rise properly. If you paddle doesn't start turning after about 15 minutes then you have another kind of problem.
Oct 08, 2010 | Cuisinart CBK-200 Bread Maker
Feb 17, 2009 | Cuisinart CBK-200 Bread Maker
TR440 Breadman won't begin kneading once "start" button is pushed
Hi Mindy.......it takes 30 minutes to PREHEAT this silly machine for wheat bread. I thought I did something wrong, too........I stopped it twice after it preheated for about 15 minutes. I did not want to waste anything so I let it stay in the machine.....I just went to check the machine and it started after 30 minutes of preheating.
I wish they would mention this in the book!!!
Julie from TX
Jan 11, 2009 | Breadman TR875 Bread Maker
Cuisinart CBK-200 Bread Maker Logo
1,010 people viewed this question
Top Cuisinart Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dale Anderson
Dale Anderson
Level 1 Expert
Tom Chichester
Are you a Cuisinart Kitchen Appliances - Other Expert? Answer questions, earn points and help others
