Question about Watches
Clock and Pendulum not working
Would like to have it repaired,or get new movement
    Scholar:
  • 53 Answers
NEVER EVER USE GREASE in a clock!!!!! If you have the right person service any mechanical clock, they will use the correct oils for the clock. We have found that the new mechanical clocks actually run better with no oil. Do not use just any oils these kind of products are great but are not good for clocks. You do not have to oil the inside of the movement. The best way to oil a clock is to take a syringe and needle, fill the syringe with oil and on the outside of the movement you will see where the gears poke through and you put a very little oil on each hole, both front and back of the clock. That is more than enough. You are welcome to email me for more information. I fix these clocks for a living. yvonne.finch@gmail.com
Posted on Mar 27, 2013
  • Yvonne Mar 27, 2013
    Robert Shaw. Sorry to burst your bubble! You are not a clock maker. A true clock maker always has a solution to the problem. I do not know where in the world you are. Here in South Africa clock parts for most mechanical clocks are scarce and if we can get them are rather expensive. We are clever! We do not have to use much brain power. We go to auctions or pawnshops or 2nd hand shops and charity shops and buy up these clocks that people do not want. It does not matter if they are whole or not, if they are not whole the become our spares. A lot cheaper than making gears!!!!! I fix mechanical clocks for a living! Most of my work is from Jewelers and antique shops. For more information contact Yvonne at yvonne.finch@gmail.com
bobshaw356
SOURCE: I have a 1983 reproduction
Hi Petah 920...I have also aquired the same clock, with the pendulum and other parts missing. I intend to fabricate the missing parts ( I am a clockmaker) and engineer. My problem is not knowing the exact parts, I have contacted Thwaites
Posted on Sep 03, 2010
cmcduncand
  • 714 Answers
SOURCE: pendulum in beat but stops running after a few
CLOCK OILING TIPS * NOTE: Many Master Clock Smiths and Hobbyists used many different oils and as many different techniques.
* It is only good sense to use only the best in quality when selecting clock oils and grease. A number of fine oils are made especially for clocks. The oil used should stay in place and not evaporate easily and have no tendency to gum or get sticky as it ages. Most clock oils meet these standards. [CAUTION: Never consider using non-clock lubricants, as they tend to not really work well in clocks. Some are too light and cause unnecessary bushings wear, while others are too thick or can evaporate, over time will gum up and stop the clock prematurely.]
Oiling Procedures
-Main-springs are oiled after cleaning and before they are recoiled.
-Teeth and pinions are never oiled.
-Normally, the dial train of gears, hour wheel, minute wheel and minute wheel post are not oiled. However, oil is used between the center shaft and cannon pinion where slip friction is present in setting the hands.
-All points of friction such as train wheel pivots to bushings are oiled. Verge faces are oiled directly.
-Oil is always used sparingly and should never run all over the plates.
Hope this tip helps.
R/
DAvid
http://antiqueclock.clockstop.com/oil.htm
Posted on Feb 08, 2010
cmcduncand
  • 714 Answers
SOURCE: the clock time cannot be set on a
You question is a bit non descriptive except that the clock does not work and the hand clutch has failed.
GOTO:
http://www.nawcc.org/business-directory/
Hopefully this will guide you in the correct direction for a local repair person.
Hope this tip helps
R/
David
Posted on Feb 15, 2010
male_28_cam
  • 1555 Answers
SOURCE: we have a seth thomas
1, Wind the clock. If the pendulum still does not swing, check the hands of the clock. If the hands are touching each other, push the hour hand gently toward the clock face. If the hands still touch, gently bend the minute hand away from the clock face.
2. Examine the swing of the pendulum. If it moves, and then stops, or if it swings erratically, the clock is probably off-balance. Gently tilt the clock to one side and restart the pendulum.
Watch the swing of the pendulum. If it stops again or continues to swing erratically, try tilting the clock in the opposite direction. Tilt the clock at various angles, on each side, and front and back, until the pendulum runs smoothly and regularly.
Note the clock position in which the pendulum swings freely. Place a wedge underneath the clock in the place needed to maintain this angle. If a wedge alone will not hold the Seth Thomas grandfather clock in the proper position, try lifting the clock slightly up against the wall.
Use a screwdriver to attach a bracket to the wall at the appropriate position. Additional brackets may be needed depending on the angle required. It may also be necessary to employ a combination of wedges and brackets.
Posted on May 28, 2011
mcnishl
  • 62 Answers
SOURCE: metal pendulum wall clock run
Hi! the movement must be bad, you can actually have a battery clock movement replaced easily at a watch or clock shop! We charge about $30.00 to 50.00 if the movement is available, you did not mention what type of clock? if you can let me know i may be able to help further. thank you!
Posted on Sep 21, 2011
I have a Dakota Daniels grandfather clock. The chimes work, the pendulum works, but the clock hands don't move.
Change the batteries. The weight makes the pendulum and chimes work, but the clock in this thing is battery operated :>)
Accurate hourly Westminster chime movement tolls the hour - Automatic night shut off
  • Cathedral pediment, blue moon metal dial with raised roman numerals
  • Pendulum, weights and chains are made out of metal - Real tempered glass
  • Sturdy construction - Made of MDF & solid wood - Batteries (3-AA & 2-C) not included
  • Dakota Daniels grandfather clock Google Search
    Dec 12, 2016 | Dakota Watches
    Tip
    Cuckoo Clock Repair
    CUCKOO CLOCK
    REGULATION AND REPAIR TIPS
    REF: 30 hour and 8 day clock
    [From my shop notes:]
    {FACT}
    -1/8 inch movement of the pendulum bob is equal to about 3 min per 24 hours running.
    -To increase the time of the clock, move pendulum up.
    -To slow down the time move, pendulum down.
    Regulation notes:
    These novel clocks are at best only a "fair" time-keeper. You can expect 100 to 120 sec per 30-hour winding period. I recommend that if it is within a few minutes per winding, simply RE-set the time.
    -The regulation obstacles are obvious:
    1. Open pendulum, this allows even the slightest breeze from a fan, ceiling fan or even cross-winds inside your house to affect both time qualities and/or its running ability.
    2. The Pendulum material is wooden, and sensitive to climatic condition, during times of high humidity the clock will slow down.
    REPAIR TIPS:
    1. Recommend regular servicing every 2 to 3 years for these unique clocks, mostly due to the fact that the movement is open to the elements (dust and dirt is easily deposited on the movement).
    2. Sometimes the clock is "over weighted", meaning that the actual weight is to heavy for the clock. I have seen some very new clocks with the wrong weights added. Instead of the clock simply stopping after the lubrication qualities are gone it continues to run and ruined the bushings.
    -To find the correct weight of a newly serviced clock, you can use a small scale. Anchor it to the floor, connect chain to the top end, wind it until it is more than double the weight of the existing weights, and then start the clock to running after the clock stops running, X's the weight figure on the scale by multiplying 1.25 or 1.35 X's the weight figure on the scale by 25 to 35 % maximum = the amount needed. [Example scale indicator is on 1 lb x 25% = 1.25 lb
    BELLOW REPAIR:
    -Unfortunately many repair persons have opted to simply replace the bellow, this is unfortunate because it can so easily be repaired.
    -I use a "RE-COVERING BELLOWS" kit.
    -This kit comes with bellow replacement material, glue, one wooden handling tool and great instructions.
    DO NOT attempt to simply patch work this, it is not fair to the customer and it will not work long.
    THE CHAIN:
    If needed, don't be afraid to replace the chain as they are easily ordered and replaced. Most cost about $3 to $4 a piece.
    The problems are:
    -If there is a child, pet, or adult in the house, the chain can be stretched. If the chain becomes damaged, it will get hung up inside the clock. "Even one damaged link can stop the clock."
    -Wrong size chain {the differences between 72 links per foot and 67 links per foot are easily confused). Recommend actually laying the chain on the chain drive gear and seeing if it fits.
    MUSIC BOX GOVERNORS:image008.jpg
    Clean and oil only. Check the pivots if worn. Don't waste your time to try and repair, just replace the Governor. Only the actual music drum can be sleeved with a new bushing. Cost for a new governor is about $25. Well worth having a few assorted governors in stock.
    -If a complete replacement is necessary, the cost is about $40 to $50.
    R/ David
    http://antiqueclock.clockstop.com/CUCKOO.htm
    on Jan 22, 2010 | Watches
    Metal pendulum wall clock run by AA batteries... does not run... new batteries do not solve the problem.
    Sep 20, 2011 | Watches
    Coaster model 900723 grandfather clock doesn't keep time
    Everybody should know that the coaster clocks discussed here run on batteries. The timing mechanisms, the chimes as well as the pendulum all are powered by a battery. Changing the speed of the pendulum is impossible because there is no adjustment. Besides, it wouldn't matter anyway. The pendulum has now affect on the clock's ability to keep accurate time. It is purely aesthetic. This is a pretty cool looking clock and even has weights, but those are also purely aesthetic and do not move the way a classic grandfather clock weight would move. The moments with these clocks are not designed to be worked on. These clocks are relatively inexpensive (approximately $300) but do add a nice look to your home. Grandfather clocks snobs would say though; this is not a true timepiece. They're right... Sorry._1513.jpg
    Nov 20, 2010 | Watches
    I have a 1983 reproduction of the limited edition Royal Observatory conical pendulum clock The parts for the pendulum may not be complete. I need instructions or schematic to see if it is all there and...
    Aug 09, 2010 | Watches
    The clock time cannot be set on a ''A'' Regulator pendulum clock, the hands move of their own accord when the key is wound anticlockwise. The pendulum does not swing either
    GOTO:
    Hope this tip helps
    R/
    David
    Feb 15, 2010 | Watches
    Bakelite antique mantle clock just bought, but no instructions of how to get it going. Ive got the key and pendulum but dont know how to set it up. Can you help?
    First you have to wind up your clock using the key supplied. The pendulum suspension spring should start to swing quite fast. Stop it swinging with your fingers and hook up the pendulum. When done, push the pendulum to whatever side and release it to start the swing - the clock should start ticking in normal order. If there is no special bar on the back of clock movement for adjusting hands, then hands must be adjusted from the dial side by moving minute hand clockwise. Move the minute hand with your finger clockwise to the desired time, at the same time do not catch hour hand, as this may end up with the incorrect time displayed. Rate me, plz.
    Jan 28, 2010 | Watches
    Does anyone know where to get a replacement 'movement' for the Michael Graves's Alessi mantle clock.
    Yep - I know a clock repairman in California who still has some of the original Hechinger Quartz Movements for the Alessi pendulum clock . Definately worth repairing .
    Jul 13, 2009 | Watches
    Hi i'll try to make this short,i have a grandffather clock i took it in for repair the part thats up in the clock that holds the pendulum had broken off,that was the only problem with it.when i got the...
    After reading all the explanations I understand that your clock is not overwound or damaged and do not need any further repairs even you've been transporting (carrying) it.
    The reason it does not work is simple - your clock is out of beat and all it needs is just to put it back in beat. This is simple operation for watch/clock repairer, but would be very difficult for you without proper knowledge.
    So, my advice is: Take your clock back to that repair shop (don't forget the receipt for the previous job done). You must carry the clock with the pendulum off, but don't leave it at home. When in shop, ask to put the clock in beat. Simply say: '' My clock is out of beat. Can you correct this for me, please?''
    As this clock was repaired there some time ago (receipt is proof), this is clockmakers responsibility to put it in beat before handling back to the customer. As well as this, clockmaker should have to explain how to carry the clock and how to hook up the pendulum without disturbing the escapement. If it was not done, you have the rights to ask to fix all that.
    Do not be afraid to go and to ask them to finish their job properly. These are your consumer rights and you are not asking for any extra work to be done.
    Do not try to contact them over the phone, as it is allways better to face the person and speek directly.
    Pull your socks up and go!
    Good luck.
    Rate me, please.
    Mar 21, 2009 | Watches
    Watches Logo
    Top Watches Experts
    Ansel Alberto
    Ansel Alberto
    Are you a Watch Expert? Answer questions, earn points and help others
