Question about Olevia Televison & Video
"Olevia 65 LCD TV"
Picture freezes
I have found a solution to the scrambled / freezing picture for the 65" Olevia LCD T11. At the recommendation of 3D electronics in plano TX, I installed a 200mm fan on the back cover with the air blowing directly on the CPU of the main / video card. I had to cut a whole in the back cover to mount the fan and actually left the bottom panel off to let more air flow. There are some spare 12v terminals on the second power board on board furthest from the main board. I cut the whole out with a jigsaw and had to extend the power wire due to the length required.
Posted on Sep 28, 2013
SOURCE: 37" Olevia LCD TV
Look here:
http://tech.groups.yahoo.com/group/syntax_lcd/message/227
Posted on Jan 25, 2008
ginko
  • 19396 Answers
SOURCE: olevia tv
If an LCD TV has sound but no picture do the following:
Use the source button to ensure that source is not set to the wrong input.
Try unplugging power cord for ten minutes, to ensure it is not a setting problem.
Check all the video cables at the back of TV.
Check Light /Color settings.
If problem persist and does not depend on external receiver or settings, then it is likely an internal fault.
If it has sound but no picture then one of the following parts is faulty, and must be tested and replaced:
The inverter is the high voltage board that provides variable power to the backlight lamp. This is the most common. When inverter is faulty you can get no picture, or a very dim picture that can only be seen by pointing a torch light with a 45 degree angle on the LCD surface from very near distance.
The inverter must be tested by reading voltages with a multimeter.
The LCD ribbon cable/LCD display and connectors.
This is quite uncommon, but happens. If the TV had been hit or moved the LCD cable may have slipped out, or the LCD connector may be damaged.
The LCD controller board.
This is the board that controls the video signal, it is difficult to test, as there is need to read determined values on IC pins. To test this board you need to purchase a service manual and follow the troubleshooting diagrams on service manual.
Input/Output Signal boards.
This are the boards where you connect the video and audio cables, if a signal board is defective, then you may get no picture on particular inputs located on faulty board.
If under warranty contact the manufacturer ringing the number on the user manual.
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
Posted on May 25, 2009
  • 45 Answers
SOURCE: no picture/sound Olevia 65" LCD TV 265T
Since the manuf. of olevia is out of buss.. the only service center that i know that has parts in stock for olevia televisions will be Amergence Technology they are a 3rd party repair center that is located in California and if you will like give them a call at 866-965-3842 and just ask for a price quote and they could explain to you the repair process as well..
Posted on Jul 28, 2009
SOURCE: Olevia 32" LCD HD TV model 232-S13
I have had the same problem with my daughters Olevia...232-S13 out of the blue ti just decides to not turn on...blue light lit where the on/off button located but no sound and no picture....i guess the saying "you get what you pay for" stands clear here.......very upsetting.....
Posted on Oct 18, 2009
freetek
  • 5568 Answers
SOURCE: olevia lcd tv has sound but no picture... Used
Try viewing the screen from a flat angle with some light source at the opposite angle while turned on. If you can see image 'ghosts,' then either the backlight fluorescent or the high voltage inverter for it has failed. This may not be cheap to repair but I wouldn't consider it a death notice.
If you or a tech finds which it is, you might try here for the board:
Jimmy's parts
These will be 'pulls' from mfr. overstock or disassembled sets. They do offer a warranty.
If the backlight has failed, I'm pretty sure a tech will know where to get them.
Posted on Dec 02, 2009
Olevia 265TFHD 65
FIGURING OUT YOUR PROBLEM IS ONE THING, BUT FINDING THE PARTS WILL BE THE BIGGEST CHALLENGE. I HAVE A OLEVIA 255TFHD AND IM CATCHING HELL FINDING PARTS. SYNTAX BRILLANT, THE COMPANY THAT MADE OUR SETS HAS GONE OUT OF BUSINESS. PARTS ARE SCARCE
May 11, 2012 | Olevia 237T 37 in. LCD TV
Can someone help me out i have a olevia LT32hvm tv where the picture freezes and picture gets blurry
The symptoms you've described is fault from the video processor on the mainboard.
Unplug the unit from the outlet overnight and then plug back in and check if the symptoms still persist, yes, then you have to replaced the Mainboard.
Mjsazon
Oct 16, 2011 | Olevia LT32HVM 32 in. LCD Television
I have sound but no picture on an Olevia 237V
If you get no picture on all inputs (TV, DVD, ETC.) then the problem can be in the backlight inverter board or the power supply that supplys the power to the inverter board.
Nov 01, 2009 | Olevia 237T 37 in. LCD TV
Picture on Olevia lcd is too large for screen.
If you are on a cable or dish box, check aspect setting from you box, TV needs to be 16-9 or full, set TV first then change setting on box.
Aug 09, 2009 | Olevia LT32HVM 32 in. LCD Television
No picture/sound Olevia 65" LCD TV 265T
Jul 14, 2009 | Olevia LT32HVE 32 in. LCD Television
Olevia tv
try unpluging, wait about 30 seconds and plug back in.
Mar 23, 2009 | Olevia LT32HVE 32 in. LCD Television
What is code for Olevia 42" TV, Product # 242-S11?
I have the Olevia 65 inch LCD TV and cannot find the comcast remote code for my TV! Any help?
May 16, 2008 | Olevia LT32HVM 32 in. LCD Television
Jan 12, 2008 | Olevia LT32HVE 32 in. LCD Television
SYNTAX OLEVIA MODEL# LT37HVS LCD
My LT37HVS was purchased in 2006 and the LCD light engine "blew" with a loud noise and only displays super dim picture-in-picture component feeds.
Need service for a quote. HELP!
Nov 17, 2007 | Hitachi 65S500 65" HDTV-Ready Rear...
Picture Freezes and Black Screens
Reset by unplugging the TV for 2 minutes and the going from there. Maybe a bad digital board since thats the only way images can et frozen on a TV.
Mar 10, 2007 | iLO 3200 32 in. LCD Television
Televison & Video Logo
161 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
