Were are the sensors for the loading door & bin full, to clean so light will go off and shredder will work.
Only used twice after brand new, now light will not go off and machine does not work.
  • 3,904 Answers
The feed sensor is right up by the paper slot usually on the back side of the slot as you are looking at it.
Posted on Jan 09, 2013
SOURCE: Staples SPL-1506X Shredder Issue
I had the same problem. I have a solution but I do not recommend this unless you have technical experience with repairing electrical appliances. I took the back cover of the main shredder unit to expose the wiring (there are 7 screws in total). The bin full sensor has a blue, green, and red connected to it. I clipped the blue wire to defeat the Bin Full error. You can look through the plastic window to check that the bin is full.
Posted on Aug 09, 2008
  • 105 Answers
SOURCE: The "bin full" indicator is always on.
you will have to clean or replace the bin full sensors
Posted on May 14, 2009
  • 3 Answers
SOURCE: full bin light is always on!
On most shredders the full bin sensor is actuated with a plate just under the cutter head. When the bin gets full the paper builds up and pushes the plate back.
Be sure to unplug main power before during any service.
Try wiggling the plate back and forth to clear out any backed up paper.
Posted on Jun 04, 2009
JayBlair
  • 328 Answers
SOURCE: shredder says bin is full but its empty won't
What model is it? Most of the time some paper shreds are hanging down from the cutter asm and blocking the sensors. Unplug the unit and reach up underneith to remove the shreds.
Posted on Sep 07, 2009
  • 610 Answers
SOURCE: SHREDDER INDICATOR KEEPS COMING ON WHILE SHREDDING
look for two LED lights where paper falls into bin and wipe them off, but the sensors could be faulty as well. I have seen both.
Posted on Nov 11, 2009
Our shredder will not anymore shred the red light will signal
Blades probably Jammed
Safety First
Power Disconnected
Open up and free the mechanism
Apr 05, 2016 | Shredder Office Equipment & Supplies
SAFESENSE ISN'T WORKING ON C-480C FELLOWES
Use a cotton bud dipped in alcohol and clean sensors
Run shredder once a day in reverse for 15 seconds to clear cutters
Empty wastebasket when bin full indicator light is illuminated using b0
If this does not solve the problem goto
www.fellowes.com for an extensive on-line support section
Feb 27, 2014 | Fellowes Manufacturing Powershred C-480C...
We have a Fellows Pwoershred 2200SC that keeps showing the full bin light even when it's empty. Tried cleaning the eye near the feed area with canned air as per recommendation by a shredder maintence...
There are also sensors under the shredder head to indicate when the bin is full. You either have a defective sensors or a dirty one (clean with air).
Aug 29, 2011 | Fellowes 2200SC Shredder
The "Bin Full" indicator light
There is a sensor in the bin area of the machine that is faulty. If you have cleaned the bin area completely and still have that problem then the sensor is bad and will have to be replaced. Look on the manufacturer website for the replacement part.
Jul 11, 2011 | Quartet gbc 4220S Shredder
I have a shredder from Staples and need to know if the bin full indicator can be bypassed.
A shredder at our office had the same problem. Take out the bin & turn the shredder upside down. There is a sensor on the bottom that looks like two led lights. If it is covered with paper dust, the shredder will think the bin is full. It might work if you simply wipe it off.
The sensor can be hard to find if it is really dusty, so just wipe off the entire pottom really well.
Feb 09, 2010 | Office Depot Ativa DQ60M Shredder
Office max shredder, says bin full but its not, only half full
I had the same problem. I found that the sensor on the shredder is light sensitive. The viewing window in the bin was letting too much light in and was triggering the bin full light to turn on. I covered the window with a piece of paper and then restarted the shredder.It worked fine after that.
Feb 08, 2010 | OfficeMax 0M96431 Shredder
The basket full light will not go out
YOU WILL HAVE TO HAVE SENSORS REPLACED
Sep 15, 2009 | Fellowes DM15C Shredder
The empty basket light stays on all the time
Try cleaning the bin full sensors. located on both sides of your machine, inside the bin,under the cutter head. If that does not solve problem, you need to replace bin full sensors.
May 04, 2009 | Fellowes Powershred 320 Shredder
Mar 26, 2009 | Fellowes Office Equipment & Supplies
Apr 25, 2008 | Office Depot Ativa DQ60M Shredder
44 people viewed this question
jasbo
jasbo
