Computers & Internet Logo
Anonymous Posted on Jan 07, 2013
Dell studio 1735 direct media lights flash nothing else
Power up. Buttons on Media Control panel light up in sequence right to left then to right. Volume up and down and WIFI lights stay on. Volume mute flashes constantly. WIFI On/Off selector works. Nothing else happens and No display at any time through laptop screen or external monitor. Fan does not move and DVD drive will not accept a disc, indicating power may not be reaching the rest of the unit. Power adapter works fine. Battery was allowed to drain then recharge overnight. Hard drive tested good. Memory chips tested good. DVD drive untested. No change when hard drive, memory and DVD drive removed. Motherboard issue or Media Control front panel issue?
  • Anonymous Jan 09, 2013
    All great suggestions here. All were tried previously as this is not my first encounter with a political laptop (all promise & no work). Response notes: All components were remmoved, inspected and reseated. These are all original components and cleaner than most laptops I work on. I am comfortable working on laptops except when it comes to soldering. Yes, I did try an external monitor. I do have experience with the C500 series as well as the DV sereies (including the copper shim solutions). I am still leaning towards motherboard went south for the winter. I do not have any means of tracing the power trail to see where it fails; wouldn't know where to begin and how to test. Thanks for the suggestions. I will continue to test as long as I can.
    Additional observations: The battery has retained its charge over the last couple days. IWhen I plug the power adapter in, the little blue light next to the power connector does light up. I was able to manually load a disc into the DVD drive by use of the release button (why didn't they drill a hole in the side case so you can use this button without removing the unit?). but pressing the Eject button on the media panel did nothing. Pressing the Launch Dell MediaDirect recycles the right to left to right button display as stated earlier but nothing else happens. The left hinge cover has a crack in it, probably due to "dropping" it into an unpadded carrying case. or lowering the case to the ground in a less-than-gentle manner. Can't tell if this affects the WiFi network locator button since I can not get the system to start beyond the media lights display. I force-fed a Linux DVD into the DVD drive. Of course, nothing happened there. Nearing the time to bite the bullet on this one.
Computer Links
Level 3:
  • Master 2,386 Answers
  • Posted on Jan 08, 2013
Computer Links
Master
Level 3:
Answers
2386
Questions
Helped
718062
Points
7718
It shows power section issue of motherboard
    That is what I am leaning towards. I was trying to see if one of the ribbon cables might be cutting off the power, but they all appear in good shape.
5 Related Answers
Anonymous
  • 285 Answers
  • Posted on Jun 07, 2009
SOURCE: dell latitude d820. press power button. no
This may be a really stupid question, but you could have overlooked it... Are you sure the power cable is attached to the laptop correctly? It seems like it's just short of power.
Anonymous
  • 3 Answers
  • Posted on Sep 28, 2009
SOURCE: C500 Laptop won't come on power button just flashes
Have you tried attaching an external monitor when the LCD screen is disconnected from the motherboard? this connector is located under the keyboard strip – a piece of plastic just above the keyboard.
If it works, this way, then the video cable isn’t seated properly in the connector on the back of the screen. Plugging the video cable back in should fix the problem.
I don’t know how comfortable you are with taking apart laptops but I think that this information could be useful for you.
Source: http://www.asklaptopfreak.com/laptop-notebook-help/2006/08/08/laptop-powers-on-and-shuts-off-immediately/
Anonymous
  • 159 Answers
  • Posted on Oct 29, 2009
SOURCE: HP Pavillion dv6700 - black screen
Do the following without the battery inserted.
Let the computer sit with no battery for 24 hours. Do not put the battery in at all. Try using your original memory stick ONLY, with no hard drive and see if it will POST. If it does, insert the hard drive and try again. Could be the new memory...
Another thing you can try is reseating the processor. Turn the ZIF screw, take the processor out (WATCH THE PINS!!) and put back in GENTLY. Leave the memory in the computer, hard drive removed, try to power on.
These models have been known for bad motherboards. Contact HP and arrange to send it in. If you do enough digging on HPs website, you'll find the service advisory.
-Dell & HP Certified Technician
Anonymous
  • 3940 Answers
  • Posted on Jan 25, 2010
SOURCE: My Dell Studio 1535 is dead! Well almost - the
Here are some things to try:
http://www.fixya.com/support/r3581893-how_to_troublehoot_a_portable_compouter_
Most likely, bad motherboard
Paxton55
Paul Newby
  • Posted on Jul 07, 2012
SOURCE: I am an owner of
my daughters hp 6735s had the fan running all the time issue, having got fed up with this I decided to try to fix it. I downloaded the service manual from the hp website and dismanteld the laptop to remove the motherboard. The fan defuser had some dust but not much, so I removed the heatsink that covers the cpu and gpu. I noticed the cpu did have thermal compound that was in contact with the heatsink, however the gpu had compound on the chip but nothing touching the heatsink. I cleaned the heatsink, cpu and gpu with degreaser, then applied new silver themal compound from maplin. I made sure i also applied a thin coating to the heatsink. I refitted the heatsink and reassembled the laptop. I powered on the laptop and instantly noticed the laptop fan running at half speed which it should do, I installed a program from a dvd and left the laptop running and so far so good. If we had left this any longer I suspect the solder under the gpu would have become molten and then we could have had another issue which maybe we could not have fixed. I hope this helps you if you have similar issues.
What does diagnostic lights mean in dell studio 1535? How do I understand what the problem is by looking at the flashing lights? For instance, what is the problem if mute and volume up lights are blinking...
I have seen questions about the diagnostic codes (volume/mute LEDs) on Dell Studio 1735 1737 laptops where the Mute and Volume up lights stay on while the Volume down Blinks. So far as I can tell, by searching the web, no one has posted the meaning of these lights.
Well here is a link to tell what the light codes mean. If your system has power but is not performing a POST just check if the mute, volume up, and volume down multimedia buttons are lit in a sequence indicating a system problem.
Here is the wesite to explain those POST failure codes.......
http://www.techmonsters.com/DellTraining/bin/Foundation2010/Portables_Foundation_2010/Studio/Studio_1737/1737/general_ts.htm
Where is the eject cd button on dell studio 1735
It is on the far right of the Media Control Buttons display.
You can see a layout of these buttons on Page 10 of the quick reference guide for your laptop.http://support.dell.com/support/edocs/systems/1735/en/qrg/NU140A00MR.pdf
The button is a capacitive button (meaning it needs only your touch and doesn't make a "click" sound or feel)
I hope this helps, and have a great day!
Cd not coming out..it is running continuously.. button on keyboard not working..! this problem is with studio laptop..no tray provided..!!!!
I just followed the instructions in the manual I downloaded at http://support.dell.com/support/edocs/systems/1735/en/index.htm
It's much more narly than working in a big tower, but the only really tough part for me was lifting up the front panel just above the keyboard--I accidentally disabled the media control buttons. Apart from that it was pretty straight forward--lots of steps, but each simple.
Disc won't eject, eject button won't light up, in fact none of the media control buttons will light up - except for "launch Dell Media Direct" button which is lite, and won't turn off. Its a Studio model,...
You can eject your cd drive by inserting a needle (saftey pin, sewing, etc.) into the pin hole near the eject button.
You can also try opening my computer and right clicking the cd drive and select eject.
The icons on the Dell Studio 1737 media control panel do not light up. The icons work but I can't see them. Previously, I had Dell on-site replace my non-working media control panel, but afterwards, even...
This issue can be solved by downloading the BIOS update and Dell Quickset Applications.
Go to support.dell.com
Download the BIOS and Quickset. And tehn install.
The sound buttons on my dell studio are ot working
The studio is a nice looking computer. having said that, I hate the audio/media buttons. Its likely you have to call dell for service to get that panel replaced.
Dell Studio 17 touch keys do not light up
here is the link for service manual for your laptop...check the cable on center control panel maybe it loose the connection.
http://support.dell.com/support/edocs/systems/1735/en/SM/index.htm
1helpful
2answers
Doesn't turn on, Mute and 2 volume lights constantly flashing
Your Pc motherboard is faulty, have a system engr look at it for possible reapirs." it won't boot ecept it is work on. Good luck
Grand Canyon Tech
Grand Canyon Tech
