Question about Singer 7256 Sewing Machine
Code E4 bobbin locked up - Singer 7256 Sewing Machine
  • Singer Master
  • 7,365 Answers
There could be something wrong with the hook and hook race
so it would be a good idea to have the machine serviced
Posted on Jan 08, 2013
I have a singer Fashion mate 7256 and when I turn the machine on E 4 comes on the screen. I have looked in my book buy can't find any information on this code! Can you help m
E4 is a bobbin shaft error I believe. In order to clear the message, you need to clean the bobbin case and turn the machine on and off.
Also check the bobbin winder shaft. If it is pushed over when you try to run the machine you may get the error.
Jan 20, 2017 | Singer Sewing Machines
What is e4 error code on janome 7700qcp sewing machine
sounds like repair shop time as timing has slipped needle hitting bobbin case possibly
Feb 12, 2015 | Janome Sewing Machines
E4
What type of machine is it? This is a code to tell you what problem there is and each machine is different. In your manual there should be this information to inform you of different codes like bobbin low or improper threading, etc. Tell me the machine type and I can probably tell you.
Apr 27, 2014 | Brother CS-8060 Computerized Sewing...
E4 message
contact singer customer service about the error code e4, the resistance could be a broken or damaged part.
Mar 22, 2014 | Singer Sewing Machines
My Singer Futura SES 2000 wheel is locked up and ERROR E4 (Safty Device Activated) HELP !!!
This happened to me once. I know it happens for different reasons. My problem was a thread 'locked' under the bobbin carriage. I opened the machine underneath, where is only one screw and found the thread locked between two wheels. If this is not your case, maybe inside the upper case? Also try to change the needle, and make sure there is not other strange object inside the hoop arm, or the bobbin cage.
Nov 13, 2013 | Sewing Machines
How do I fix error E4 whe no thread is tangled?
try changing the needle
rethread the machine top and bobbin
try a different bobbin
make sure the bobbin is turned the right way in the bobbin case
clean under the needle plate and in the bobbin area for lint
also possible that something has gone wrong with the computer
part of the sewing machine.
Nov 30, 2012 | Sewing Machines
I get a E4 code whan I turn on machine and I can't figure out what is wrong.
Brother Computer Codes E1: Make sure the presser foot is lowered before sewing.
E2: You chose a stitch other than a buttonhole stitch or a bar tack stitch and you tried to sew with the buttonhole lever in the lowered position. Raise the buttonhole lever.
E3: If you selected the buttonhole or tack bar stitch and start to sew with the buttonhole lever raised, you will get the E3 code. Lower the buttonhole lever.
E4: You hit the reverse button while the bobbin winder shaft was moved over to the right. Move the bobbin winder shaft to the left.
E5: On automatic sewing machines, the start/stop button was pressed while the foot controller was plugged in. Unplug the foot controller if you are using the automatic function.
E6: This code tells you that the motor locked up because the thread is tangled. Untangle the thread, make sure the machine is threaded properly and that the proper tension is set before continuing.
Sep 21, 2012 | Sewing Machines
F4 code
Usually the error codes are shown as like E4 which would be E4: You hit the reverse button while the bobbin winder shaft was moved over to the right. Move the bobbin winder shaft to the left. If you have any further questions or feel that the error is an F error code instead of an E error code message me back and I will look futher into your F error code but even if you click this link which will bring you to the brother error message site click here http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faqh/000000/000000/000064/faqh000064_000.html?reg=us&c=us&lang=en&prod=hf_ce5000eus&Cat=56 it still basicly says the same thing and the errors are shown as E's. I await your reply if you have any further questions Thanks Rick
Jul 28, 2011 | Brother CE5000 Computerized Sewing Machine
Singer futura 250. while sewing the E4 code
Are you using bobbin thread? Is your thead new? Is themachine threaded correctly?
Make sure that when you thread the upper part the thread go under the circle that pull it.
Another thing is that when you hit the start button, pull the upper thread until the machine goes two or three times. It helps the bobbin thread to come up and the machine start sewing.I you leave it along the thread sometimes doesnot comes up and that is why the machine beeps.
I use this technique to make sure it doesnt beep and to cut the thread (the one at the beginning so it doesn't mess my design)
Feb 15, 2010 | Singer CE-200 Quantum Futura Computerized...
Singer Futura 350
Dear Wendy,
The E4, error message means the safety device is activated. Machine is locked up due to thread entangled with the bobbin case. Remove the needle plate and bobbin case. Check for any thread around the hook area. Also check your handwheel. It should turn freely. Good Luck
Jan 11, 2009 | Singer CE-200 Quantum Futura Computerized...
Singer 7256 Sewing Machine Logo
179 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
