Question about Hotpoint NVL333EY Electric Dryer
Dryer needs extra boost to get started
When I turn the start switch, it makes the usual noise but doesn't start. If I take off the top and give the drum a good push while starting, it will start turning and dry normally. Is there a capacitor or another replacable part that gives the motor an extra boost to get started, or do I have to replace the whole motor? I got a $310 quote to replace the motor, and I can get a new equivalent dryer model for $360.
  • Hotpoint Master
  • 8,220 Answers
How hard is it for the drum to turn? Have you checked the glides as seen in this video?
Paw Paws dryer repair page for GE
Posted on Jan 08, 2013
  • Stephanie Walker Jan 08, 2013
    Thanks for replying and for the link. If empty, it is easy to turn. With wet clothes, it needs a good push or two to get started. Once turning, it performs fine.
  • Dan Webster
    Dan Webster Jan 08, 2013
    The front of the drum has glides on a plastic bearing. Check out my blog page which shows what to dohttp://appliancejunk.blogspot.com/2011/0...
vostendorp
  • 347 Answers
SOURCE: DRYER DOES NOT START ONLY MAKES BUZZER SOUND. WHEN
sounds like a motor these Do not use a starting capacitor, they use very small Gage wire for the start windings ..You can get a new motor for about 130.00 dollars if you decide to replace it I would advise you to also order a new blower wheel ,, after time the blower wheel has a way of seizing its self onto the motor drive shaft and 90% of the time you have to destroy the blower wheel to get it off it adds about 25.00 to 30.00 more to the job but you will be glad you did
Posted on Nov 24, 2010
  • 686 Answers
SOURCE: drum not turning
no brushes in those motors you need new one or different dryer
Posted on Mar 12, 2009
  • 63 Answers
SOURCE: Motor does not start the drum turning
starting capacitor
Posted on Mar 13, 2009
heatman101
  • 43501 Answers
SOURCE: I think I need to replace the starter capacitor,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Jul 14, 2011
SOURCE: dryer was making high pitched squealing noise and now won't run
Please supply the model number so we can help further.
Posted on May 20, 2012
Dryer makes a buzzing noise when I turn it on but it doesn't come on, just buzzes.
Open the dryer door and slowly rotate the dryer drum in a counterclockwise (CCW) direction. Rotate the drum 2-3 revolutions and then shut the door and see if it will start. If it continues to just hum and not start could indicate a voltage issue, motor issue or a friction issue. Open the door again and locate the door switch plunger in the upper or lower corner on the hinge side of the drum opening. Hold the plunger in while someone begins rotating the drum counterclockwise. While turning the drum counter clockwise and holding the door switch plunger inwards press the start button. If it starts, there is likely a friction problem or motor problem.
What is the model number?
Nov 06, 2012 | Dryers
I have a Bosch Nexxt Dryer 800 series when you try to turn it on, it just makes a click sound, but won't turn on. Any ideas about what's wrong. Thanks Marge
see this causes and fix it. God bless you
Timer The timer is normally not at fault when the dryer won't start. In many situations where timers are replaced they end up being returned. First, check all of the more common components in this troubleshooting guide before replacing the timer. If the dryer won't start, the cause is much more likely to be a thermal fuse or switch. The timer can not be tested, it must be replaced if it is defective.
Main Control Board The main control board is normally not at fault when the dryer won't start. First, check all of the other components in this troubleshooting guide before replacing the main control board. The main control board can not be tested and must be replaced if it is defective. If there are obvious signs of burning or a shorted out component on the board, it should be replaced.
Belt Switch If the dryer won't start, there might be a belt switch that has failed. This is not a common problem and most dryers do not have this switch. If the dryer has a belt switch, the switch shuts off power to the entire dryer if the belt breaks. It is possible that this switch has failed, even if the belt is not broken. It can be checked with an ohm meter or continuity checker. If the dryer works at all, even if all it does is hum, this is not the problem.
Incoming Power Problem If the dryer won't start, check to certain there is electricity to the dryer. For a gas dryer, unplug the dryer from the wall and plug something else into the outlet to see if it's working. For an electric dryer, check the home circuit breaker or fuses. If they are working, check the outlet where the dryer plugs in with a volt meter. There should be between 208 and 240 volts. If there is power to the dryer, check the more common items in this troubleshooting guide.
Thermal Cut Out Fuse Kit Most dryers have several temperature control devices such as a thermal fuse, thermal cut out, high limit fuse or high limit thermostat. Some manufacturers sell the thermal fuse and thermal cut out in a kit. These kits normally solve no-heat problems rather than when the dryer won't start. However, in some models, this kit will solve both problems. Even though this is not the most common part to fail if the dryer won't start, both can be checked using an ohm meter or continuity checker. If they have continuity they are good. If not, they should be replaced.
Drive Belt On most dryers, if the drive belt breaks the motor can still be heard and it will still be blowing air out the exhaust tube, but the drum will not spin. However, in some dryers when the drive belt breaks the tension pulley arm trips a switch which shuts off power to the entire dryer. If the dryer won't start, check to see if the belt is broken. If it is, replace the belt and the dryer should be fine. If the belt is not broken, check the other components that can fail when the dryer won't start.
Drive Motor The dryer drive motor turns the drum and the blower wheel to exhaust the air. If the dryer won't start the motor might be defective. Before replacing the motor, check the thermal fuse, start switch and door switch because all three are more likely the cause. If the dryer won't start and the dryer motor makes a humming noise there might be something caught in the blower wheel, or the drum might be binding. Try removing the belt from the motor and checking the blower wheel for obstructions. The dryer motor can't be tested easily. If the more common components have been checked and it seems the motor itself is defective, it will need to be replaced. It is not serviceable.
Door Switch The door switch is located near the dryer door and is activated when the door is closed. If the door switch fails, the dryer won't start at all. Many types of door switch will make an audible click when they are activated. If the door switch makes a clicking sound when activated it is probably not defective. If it doesn't make a click, it can be checked with an ohm meter or continuity checker. The door switch is relatively easy to replace and is usually not very expensive.
Start Switch The start switch is on the dryer control panel. Depending on the model, either press a button or turn a dial to start the dryer. If the start switch fails the dryer won't start or make any noise. Test the switch with an ohm meter or continuity checker. If the dryer hums when the start switch is activated, or if the motor runs only while activating the start switch, the motor might be defective or something might be binding the drum preventing it from turning freely. If the dryer start switch does not have continuity when it is activated, it will need to be replaced.
Thermal Fuse The thermal fuse helps to prevent a dryer fire by shutting off power to the dryer if it overheats. If the dryer won't start check this fuse first. Test the thermal fuse with an ohm meter or continuity checker. This is the most common part to fail when the dryer won't start. Once the thermal fuse has blown, it has to be replaced. It can not be reset.
Sep 28, 2012 | Bosch Nexxt 800 Dryer
Upside down letter F and #5
does it look like this? t5 or ts could be a thermistor code.if you changed out the thermistor you most likely have a bad computer board.there should be a tech sheet in the machine usually in the top console. here's something that might help http://mikemerrittmotors.yuku.com/topic/2255 the machine doesn't run is that correct?i would check the obvious things,open the door and push in on the door switch and make sure that's working correctly,it should click when you push it in,there's a switch on the belt pulley,if the belt broke the dryer won't start,then check the thermal fuse,the thermistor and if they all check good then you have a bad computer board.just have to get in there with a meter and start reading out parts,also make sure you have 240 volts coming to the dryer,you can check it at the block where the cord connects to the dryer,after that unplug it and check all the other parts for continuity and you have to remove at least one wire off of the part you're checking.also here's the sears site so you can look up your parts if you don't have this site already. http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Dryer-Parts/Model-MDE9700AYW/3048/0151200?pathTaken=&prst=0&shdMod=MDE9700AYW good luck and wish i could help you out more
Dec 20, 2011 | Maytag MDE9700AYW Neptune 174 Electric...
Makes a humming noise but doesn't turn
Try this, open the dryer door and hold down the door light switch. Turn on the dryer and press start.When you hear the motor humming, turn the drum clockwise with your hand to see if it will turn. If itruns, you have a bad motor and will need to be replaced. If it doesn't turn, something is jammedinside and you will need to disassemble the unit to find the jam.
Hope this helps.
Oct 31, 2011 | LG DLE2514 Electric Dryer
I have a Kenmore front loader - when I turn the knob to start the dryer, it make a noise like it wants to start but doesn't. I have tried to move the knob which indicates what drying time you want to...
heatman101
Sep 20, 2011 | Dryers
Fridgidaire dryer aeq6000es. won't start, beeps 3 times with error message dr
Hello
This code means the dryer door is not closed or the door safety switch is not making a good connection at times. The dryer door safety switch is in the opening of the door and when the door is closed the switch button is depressed. If the control circuit board doesn't get a signal that the dryer door switch is closed it will not allow the dryer to start.. Try firmly closing the dryer door a 2nd time when this happens, if that cures the problem you are good to go, if that doesn't cure the issue you must remove the front panel of the dryer and replace the switch. If you need a switch they are available from Sears Direct for about $15.00 Below is a picture of the switch that most likely used in your model and make, the button on top is what the dryer door depresses when closed..
Jul 12, 2011 | Dryers
My Maytag Dryer won't start. Mod.# MDE3000AYW . The on button makes the right noise like it is going to start but nothing happens. Sometimes I get lucky and it will start but most of the time it just...
heatman101
Jul 05, 2011 | Dryers
Dryer was making loud screeching noise for a couple of weeks. Now doesn't work at all. When switch is turned to operate it make a clicking sound then nothing.
heatman101
Jun 28, 2011 | Kenmore Dryers
Kenmore 600 series dryer.model # 110.67622600. wont start. light goes on & off when i push and release the door switch. when i push the starter switch it make a clicking buzzing sound. more noise when...
heatman101
Jun 27, 2011 | Kenmore 67632 Electric Dryer
My Matag dryer does not run, but for a while it hummed before starting.
Motors of this sort have a "start" winding, to give them an extra boost to get them turning. Once they're turning, the start winding shuts off. Critical to this is the start capacitor which, when shorted, causes the exact symptom you've described. The motor's "regular" winding gets power (and then hums), but it needs that extra boost to actually start turning. Have someone check the capacitor (with an ohmeter) or check to see if the motor's start winding is open (broken).
Apr 10, 2006 | Maytag HYG2460AWW Gas Dryer
Hotpoint NVL333EY Electric Dryer Logo
42 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
