Question about QuarkXPress 4.1 for mac
Can i install 4.1 with windows 7 - QuarkXPress 4.1 for mac
I have a hcl hcm780m model i change to install windows 7 then ram space not allowed why?
Windows 7 needs 4 GB or less of ram to instal. It will not install if you have more than 4.
Feb 20, 2015 | Computers & Internet
Tip
Installing Windows 7 to ANY Netbook Using USB Drive
To copy the Windows 7 ISO file to a USB flash drive Before you begin:
  • Make sure you've already purchased and downloaded the Windows 7 ISO file to your PC.
  • Make sure you've copied any files on the USB flash drive to an external location. The Windows 7 USB/DVD Download Tool will erase any data on the USB flash drive.
  1. Click the Start button d49affd.jpg, click All Programs, click the Windows 7 USB/DVD Download Tool folder, and then click Windows 7 USB/DVD Download Tool.
  2. Under Step 1 of 4: Choose ISO file, click Browse, browse to the Windows 7 ISO file you downloaded, click it, click Open, and then click Next.
  3. Under Step 2 of 4: Choose media type, click USB device.
  4. Under Step 3 of 4: Insert USB device, click your USB flash drive in the drop-down list, and then click Begin copying.
  5. If you see a dialog box that says that there isn't enough free space on the USB flash drive, click Erase USB Device, and then click Yes.
  6. When the process is finished, click the Close button 890548ff-eff6-4f93-ba12-92692a835f86.jpg in the upper-right corner of the window.
To install Windows 7 using a USB flash drive If you don't need to start your netbook using the USB flash drive, you can simply browse to the USB flash drive, and then double-click setup.exe to begin Windows 7 installation.
To start your netbook using the USB flash drive:
  1. Turn off your netbook, insert the USB flash drive, and then restart your netbook.
  2. Press any key when prompted, and then follow the instructions that appear.
  3. On the Install Windows page, choose your language and other preferences, and then click Next.
    If the Install Windows page doesn't appear, and you're not asked to press any key, you might need to change some system settings. To learn how to do this, see Start your computer from a Windows 7 installation disc or USB flash drive.
  4. Follow the instructions to finish installing Windows 7.
on Apr 19, 2010 | Computers & Internet
Tip
Run your Windows xp Software on Windows 7 and Vista
Are your software not compatible with Windows 7 and Windows Vista?
Do you need to install driver from Windows XP to Windows 7 and Vista?
Here is how you do it. ^^
This is just a simple trick to show you how to run your installers and software to your Windows 7 and Vista.
Steps to run incompatible application to Windows 7 and Vista:
729dcf7.jpg.
1. Go to the installer/installed application
2. Right click the .exe and click properties
3. Click the Compatibility tab
4. Check the Ru n this program in compatibility mode for:
5. Choose the Operating System you like (most probably it will by Windows XP)
6. And try running the software again.
on Jan 24, 2010 | Computers & Internet
Reset windows 7 password hp
You may try the below steps to reset or recover the windows login password:
1) Insert either your Windows 7 installation DVD, or a Windows 7 System Repair disc, into your optical drive and then restart your computer. If you have either on a flash drive, that'll work too.
Note: If you don't have original Windows 7 media and never got around to making a system repair disc, don't worry. As long as you have access to any other Windows 7 computer (another in your home or a friend's will work fine), you can burn a system repair disc for free.
2) After your computer boots from the disc or flash drive, click Next on the screen with your language and keyboard choices.
Tip: Don't see this screen or do you see your typical Windows 7 logon screen? Chances are good that your computer booted from your hard drive (like it normally does) instead of from the disc or flash drive you inserted, which is what you want. See the appropriate link in the tip from Step 1 above for help.
3) Click on the Repair your computer link.
Note: If you booted with a system repair disc instead of a Windows 7 installation disc or flash drive, you won't see this link. Just move on to Step 4 below.
4) Wait while your Windows 7 installation is located on your computer.
5) Once your installation is found, take note of the drive letter found in the Locationcolumn. Most Windows 7 installations will show D: but yours may be different.
Note: While in Windows, the drive that Windows 7 is installed on is probably labeled as the C: drive. However, when booting from Windows 7 install or repair media, a hidden drive is available that usually isn't. This drive is given the first available drive letter, probably C:, leaving the next available drive letter, probably D:, for the next drive - the one with Windows 7 installed on it.
Hope this helps..
Feb 18, 2015 | HP Computers & Internet
Vmfusion emulation of windows 7 language change
How to change the Windows 7 Display Language:
1. Go to Start -> Control Panel -> Clock, Language, and Region / Change the display language
2. Switch the display language in the Choose a display language dropdown menu.
3. Click OK
4. Log off for the changes to take effect (This will affect only the user profile under which you are currently logged on).
May 05, 2012 | Apple iMac Computers & Internet
Tip
How to Install Windows 7 from USB Flash Drive
what if you don’t have DVD-ROM and you are running Windows XP, you might have guessed in this case we can’t install windows 7. Since Windows 7 ISO size is around 2.24 GB so its obvious that you will need to burn windows 7 iso on DVD and another issue is you can’t start windows 7 installation by mounting ISO file on windows XP as Windows XP upgrade to windows 7 is not allowed. In such situation installing windows 7 from USB pen drive is feasible solution.
Here is small guide on how to install windows 7 from USB flash drive or USB pen Drive for Windows XP users.
How to Install Windows 7 from USB Flash Drive Requirement:
USB Pen Drive (Min 4 GB)
Windows 7 ISO (32 bit or 64 bit)
MBRwiz Download and Extract it on your hard drive (Diskpart utility for Windows XP doesn’t detect USB drive as Disk hence we need to use this free utility to make bootable USB drive).
1. Connect your USB Flash Drive to your computer Format USB drive
2. To Format USB Flash Drive Go to My Computer -> Right click on USB drive and select Format from context menu.
3. Now go to Start Menu->run->cmd (Open Command Prompt) and Type following command
convert i: /fs:ntfs (Where “I” is your USB drive latter)
4. Mount Windows 7 iso as drive (You can use Freeware MagicDisc download from here).
5. Type Start->run->cmd
Now dir to directory where you have extracted MBRWiz and run following commands
mbrwiz /list (note down disk number of your USB Pen drive)
mbrwiz /disk=X /active=X (X is Disk Number of your USB Drive)
exit
6. Now open another command window and type following command
J: (Drive letter of Windows 7 iso mounted with demon tool)
CD boot
bootsect /nt60 Y: (Y is drive latter of your USB drive )
7. Now copy all files from drive where you have mount Windows 7 iso
8. Now reboot your computer and press F9 to get your BIOS screen and select USB drive as your boot drive.
9. If every thing goes fine, Your Windows 7 Installation should start from your USB drive.
on Jan 10, 2010 | Computers & Internet
Need to change Apire 5732z from Spanish laguage to English, kindly assist
To install a different language - Multilingual User Interface (MUI) - you need to have Windows 7 Ultimate.
Anytime Upgrade to Windows 7 Ultimate
Type Anytime Upgrade in the Search programs and files box in the Start menu and click on the Windows Anytime Upgrade icon. From there, you can buy an Anytime Upgrade to Windows 7 Ultimate. Then your can enter your Anytime Upgrade product key and perform a simple upgrade to Windows 7 Ultimate so you can install a different language.
If you are in Australia, Belgium, Canada, France, Germany, Italy, Japan, the Netherlands, Spain, Sweden, Switzerland, the UK, and the US you can use Anytime Upgrade. If not you will need to buy Windows 7 Ultimate, or buy Windows 7 in the language you need.
http://windows.microsoft.com/en-us/windows7/products/windows-anytime-upgrade
Install Language Pack in Windows 7 Ultimate
1. Start -> All Programs --> Windows Update --> Optional Updates.
2. Open optional Updates and go to the section Windows 7 Language Packs.
3. Tick the Language Pack you want and hit OK
4. Proceed with Install Updates
5. Depiction of Windows 7 downloading a Language Pack
6. Automatic install initiated after download
3. Click OK
Feb 28, 2011 | Acer NSK8458AN Keyboard
I want to see all the part i would need for the installation
Thanks for using fixya,
please follow the link for windows XP installation guide.
Boot from cd
http://www.windowsreinstall.com/articles/bios/
XP
http://www.microsoft.com/windowsxp/using/setup/winxp/install.mspx
WIN 7
http://www.windowsreference.com/windows-7/windows-7-beta-step-by-step-installation-procedure/
http://www.techtalkz.com/windows-7/514412-windows-7-installation-guide-tutorial.html
Hope this helps.
If you are helped you can rate on the 4 thumbs and leave a short comment,because,
this is the free side and I can get the chance, to help people like you .
Thanks for using fixya .
Jan 20, 2011 | Computers & Internet
Installed 4 G of RAM. Installed Windows 7. Only 3 G RAM Usable
To recognize more than 3GB of RAM you will need a 64 bit version of the operating system. If you install Windows 7 32 bit (normal for most users) you will only see 3.
You should have both versions of Windows 7 (32bit and 64 bit) on your installation disk. However you will need a 64 bit capable processor to install it. Otherwise 3GB of RAM for a 32 bit operating system is more than enough.
Mar 08, 2010 | MSI PT880 Neo FSR Motherboard
I had installed the windows 7 beta version. now videos not workin
windows 7 is still beta. It is till not a full operating system. Please let windows release the final version of windows 7.
Apr 04, 2009 | Intel Pentium 4, Pentium 4 , Celeron-D -...
QuarkXPress 4.1 for mac Logo
Top Quark Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Tony
Laxman Bisht
Laxman Bisht
Are you a Quark Computer and Internet Expert? Answer questions, earn points and help others
