Question about Panasonic VIERA X1 series TC-42PX14 42 Inch 720p Plasma HDTV from
I turn my tv on and it just clicks and the screen doesn't come on and the pwr light flashes 10 times, I have replaced the A-board and still nothing, any ideas?
The tv is plugged directly into the wall
  • jason Jan 08, 2013
    everything looks fine, nothing out of the ordinary. Does anyone know how to test the SC board?
    Producer:
    Uploaded 30 video answers.
  • Panasonic Expert
  • 155 Answers
This link might help diagnose
Posted on Jan 19, 2013
4 Suggested Answers
SOURCE: Panasonic TH-50PE700U red light flashing 6 times
Replaced the sc board and tv works fine again.
Posted on Jan 22, 2009
tvhelp-Dave
  • 178 Answers
SOURCE: TH-42PZ80U Panasonic Plasma, red light flashes 10 times
Panasonic said "A" board,
A board SOS Detect (Explanation)
10 Blinks SOS: The voltage regulators IC5400 and IC5401 in the A board generate SUB9V and SUB5V. The 9V and 5V from these ICs are monitored by IC1100. Any abnormality on the SUB9V or SUB5V lines, triggers the shutdown circuit and the MPU shuts down the unit. The power LED blinks 10 times.
But need to measure the connection SC2, if it short, it will be the SC board.
The knowledge obtain from: Real case of repair by myself.
Information from Panasonic training manual.
Posted on May 10, 2010
milkburp
  • 416 Answers
SOURCE: tv will not turn on. Flashes 10 times
You need to replace the power supply, PN: ETX2MM704MGH. This 10 flash failure is common. I hope this was helpful, best wishes.
Posted on May 14, 2010
Samsung TV LN46B530P7FXZA version AA01, ser num AUCU3CUS300985R,
Change the video board. It seems like it is blocking power. The relay signifies that power is working properly.
Nov 14, 2016 | Samsung Televison & Video
TV Not turning on
You can be pretty sure something's wrong with the power board. Defective capacitors may "look" OK but aren't. It could be helpful to lay your hands on a schematic.
Jan 02, 2014 | Televison & Video
The power lights flashes three times and the TV doesn't work
Three times flash to LG TVs denotes a fault with its main board. Contact any service technician. If you're sound in electronics, check this link. http://electronicshelponline.blogspot.com/ Blinking codes to many brand TVs are given in detail. Pull up older posts there, either by its left side bar, or see it in Timslide option.
Jun 23, 2013 | LG 47LG50 47 in. LCD HDTV
TV TURNS OFF EVERY 10 MINUTES, FLASHING RED LIGHT,
This issue is related to a power problem in as much as the TV turns off on it's own.
The problem is consistent with overheating on the power supply board of the TV. it might have worked fine in the past, but that's electronics for you. Power surge, irregular power supply, excess power supply, etc can affect the unit thereby making it to misbehave.
The power supply board of the TV has few capacitors and IC. If any of these IC's gets short or become weak, it can cause the TV to turn off on it's own.
When current passes from electric outlet to the power supply board of TV. The current also goes to the weak/faulty part, then the current stops or slow and the board overheats and TV shuts off on it's own.
To solve this issue, check the power supply board and read it with a meter and continuity tester, in order to detect the faulty part and replace the faulty part on the board which is short due to which power supply board
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors). After replacing these capacitor(capacitors) most likely the normal operation will be restored. Or you can by a refurbished complete power board from www/shopjimmy.com to save you some stress.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't have the ability to read the fault, then you might be needing the help of a repairman or you can call a friend that has the ability to help you out.
I wish you the best of luck.
Regards.
Nov 22, 2011 | Panasonic TH58PX600U 58 in. Plasma HDTV
Wont power on
caps on main board may be defective. power supply may be defective if the caps on the MB arent bubbled
May 27, 2010 | Philips 50PFP5332D 50 in. Plasma...
New lamp turns on flashes 7 times
Just a thought...you *might* have a bad ballast in addition to that defective power supply.That flashing could be the ballast trying to ignite the lamp. A lamp is just like an enclosed welder's arc. The ballast generates a high-voltage spark to initially start the lamp, then low voltage with high current keeps it burning. If you look into the lens and see "lightning" flashes but no lamp ignition, that's what's happening. The ballast could've been damaged by the defective supply. Also, try a known-good lamp...just to rule out a defective new one--in the shop, we kept all old working lamps as testers.
Aug 30, 2009 | Sony XL-2100U Projector Lamp for...
Sony kdf55sx955 has no sound or picture. Won't turn on. standy light flashing 6 times.
switch tv off for 10 min and then back on.
tv should come on.
if this doesn.t work.you will need to replace main board.
May 11, 2009 | Televison & Video
53UWX10B
Good Day, Butchilee,
Sounds like you have patience, hope your TV has some trace left. Hit recommends that you replace the originals with
STK-392-150's and the resistors. Replace said items with care then back down on the screen/ focus controls and gradually bring the screens up until you have pic, adjust focus. Go into customer menu and adjust color down, set brightness to 50%, contrast to 100%. Then go back and adjust the screens for proper, black/white, tracking. AND It's best to double check the soldering connections.
Good Luck, Big Irish.
Jul 04, 2008 | Hitachi 53UWX10B 53" Rear Projection...
RCA D52W20 52 in. Rear Projection
the main pwr board is defective and will need replacement...
Oct 18, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Panasonic VIERA X1 series TC-42PX14 42 Inch 720p Plasma HDTV from Logo
118 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
