Question about Canon imageCLASS D480 Black and White Copier
The scanner function on my Canon D480 has not worked since the installation.
The copy/print/fax functions of my D480 has not operated since we purchased it. We have installed the Scanner MF software twice and it still doesn't function. I place something on the glass to scan. Press the Scan button twice for USB Scanning, since the printer is not networked, then press Start and nothing happens...it's as if I never pushed any buttons. I am operating on a Mac with OS software 10.7.5
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 57 Answers
Go to the scanner company website and see if there are drivers available for download. Sounds as if you may not have the proper drivers installed.
Posted on Jan 08, 2013
Testimonial: "It was a simple Update fix. I updated the Printer and Fax drivers as well as there was a 12/12 update. THANK YOU!"
checkitright
  • 1362 Answers
SOURCE: Printing on Imagerunner 210s
depends on which additional function you are trying to do.
You have it as a copier only right now, you can add
duplexer for two sided copies
network for your computer to fax and print and scan
document feeder to put copies on top and feed automatically
There are a lot of options you need to decide which function you are willing to pay for.
Good luck
Posted on Dec 04, 2007
rylee_smith
  • 8619 Answers
SOURCE: Canon IR C3200N scan with MAC OSX
Hi!
Please download the drivers from the Canon Website.
Please rate this solution if you find this solution helpful.
Thanks
Rylee
Posted on Feb 08, 2009
  • 153 Answers
SOURCE: i want to instal drivers for printer and scanner
just do a search on www.canon.com.au for your print driver and scanner driver its on on there do a search on there if you need to.
regards
canon tech
Posted on Apr 01, 2009
SOURCE: Canon ir 330-400 copier
it is supposed to use a separate scanning board (Interface Board-D1) with SCSI connectivity and TWAIN software.
Posted on May 19, 2009
redzventures
  • 149 Answers
SOURCE: I AM ATTEMPTING TO USE THE SCANNER FUNCTION ON A CANON IR2230
Firstly, the machine must be connected to a pc or network. Secondly, you must scan the document to a pc so, after you have switched on, as you have, the scanner so that it says 'online' you will need to go to the pc and 'PULL' the document to the pc from the scanner. However, to do this you will need to have installed NETWORK SCAN GEAR on your PC inorder to SCAN. When you install the software, you will need to DISCOVER the scanner before it will be ready for use. So, a recap:
1. You NEED a program called NETWORK SCAN GEAR on your PC
2 Your ir2230 must be connected to a PC or network
3 You need to DISCOVER your ir2230 from your PC
4 You then need to INSERT picture FROM SCANNER and select your ir2230 from within a program such as WORD using NETWORK SCAN GEAR
Good luck
Posted on Jan 03, 2010
Lexmark X4550 Scanner not working
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
  1. Disconnect the USB cable connecting the printer from your computer.
  2. On your computer, go to Control Panel > Printers and Faxes.
  3. Delete the Lexmark print object.
  4. Reboot computer.
  5. Re-brick your printer by pulling out the power supply - black box where the power cord is plugged into on the back of the printer, and re-plug after 30 seconds.
  6. When the printer turns on, reconnect it to the computer.
  7. Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to print a document to verify that the problem is fixed.
Jan 05, 2012 | Lexmark X4550 Multifunction Wireless Color...
Unable to do fax can print but unable fax
Canon PIXMA MP250 series serves with PRINT + SCAN + COPY function. No FAX function
Jun 10, 2010 | Canon Pixma Mp250 Allinone Inkjet Photo...
Why our fax sending and receiving solid black
Its a problem with scaner unit. Reports are being printed out, and do not pass trough scaner, because of thath report is Ok.
If the fax is still under warranty, go to warranty provider service.
Next time dont buy "kids toy" for fax machine. Try laser Canon Fax L140.
May 20, 2010 | Canon FAX JX200 Fax / copier Plain Paper...
Will not work with Vista operation system
Correct. There is no easy solution for this issue. Several of the "older" scanners are no longer supported through the Vista operating system. Why not purchase a new multi function printer, scanner, fax and copier unit.. you will not locate vista drivers either online or from the manufacturer and without them, the scanner will not function. Alternatively, you could also roll back or re-install Windows XP operating system..
Nov 02, 2009 | Canon CanoScan LiDE 30 Flatbed Scanner
Can i copy from printer to Computer
No you can't.
Canon Pixma iP45500 is a sigle function printer. That means it just prints to paper.
What you want to do requires a multifunction printer: a printer is also a scanner/copier functions and which which is capable of acquiring an image and transfer it to the computer.
single-function printer
Jul 27, 2009 | Computers & Internet
Canon MultiPASS F50 won't copy but will scan
Does the copy function work if you place the document to be copied on the platen (open the cover and lay it on the glass)? If so, check the area to the left of the platen. There should be a strip of glass with a clear plastic cover over it. This area is used for scanning when feeding paper through the automatic document feeder (ADF) from the top. This area must be clean. If this area is clean and clear, it's possible that the scanner element (below the glass) is no longer going all the way to the left when using the ADF. This would be a problem that would require servicing.
Oct 15, 2008 | Canon MultiPASS F50 All-In-One InkJet...
Will not make a copy
If it won't copy, it is unlikely to handle faxes either since those functions use the same scanner. If your received faxes are coming out blank, then it is a problem with the ink system; if you can get faxes printed but not copy a document, the scanner may be at fault.
Have someone send you a fax to check this function (printing) and then try sending one back to check the scanner.
If either one fails, then hyou know where the problem lays.
Jul 10, 2008 | Brother IntelliFAX 560 Plain Paper Fax
Copy function
well you gotta provide the details in scanners configuration where you want the scanner to copy your Documents to .i.e. whether you want it to scan and store it as a image or open it with some Application or you want it to print just assign any one task with proper configuration it will definately work.
Thanks
Nov 17, 2007 | Canon CanoScan LiDE 30 Flatbed Scanner
Scanner
Download and install full software and driver package for your machine from brothers web site, it sounds like you have installed the print drivers but not the scanning software.
Oct 27, 2007 | Brother MFC-5440CN All-In-One InkJet...
Cannon scanner D1250U2F and Hp photosmart printer 8250
This is a compatibility issue between the Copy function of Toolbox and the specific HP printer driver. The only work-around would be to scan your image and save it, then print it from another application. One other possibility would be to get Toolbox version 2.2.x from the N650U scanner download page. This version will be limited in functionality, but COPY button should function as expected.
Apr 28, 2007 | Canon CanoScan D1250U2 Flatbed Scanner
Canon imageCLASS D480 Black and White Copier Logo
301 people viewed this question
old marine
old marine
