Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
How to remove rear wheel off a victa 4013tx - Craftsman 42 in. Deck 19.5hp Lawn Tractor
What is the victa lawn mower 35 classic a two stroke or a four stroke please.
search on a victa 35 classic makes it 4 stroke
its a brigs and stratton 3.5 engine on aluminum frame + plastic rear catcher
Sep 03, 2016 | Garden
How to remove the front wheel on a victa NXT23/46 ride on mower
Graeme, usually you remove the rubber/plastic axle/hub cap, jack mower up and secure from falling, next remove retaing clip( C clip, cotter pin, etc), and washer, slide wheel off. Check the attached links,instruction and guides, could not find your model, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Changing Front Tire on The Craftsman
Removing Wheel from Riding Mower
http://support.mtdproducts.com/app/answers/detail/a_id/203/~/wheel-removal---riding-mower
Apr 24, 2016 | Garden
How do I start victa 4013tx?
this is actually a murray model re-badged as a victa. Here is the electrical diagram. Park brake must be engaged, deck must be disengaged and the seat must be sat on.
Hope it helps. I also have other exploded views of this model.
Oct 18, 2013 | Murray Garden
How do you test a coil on a old victa 18 mower
i would be removing the fly wheel check that the points are clean clean up with emery paper set gap and then refit flywheel and hold lead about 8mm from block and pull cord
Feb 13, 2013 | Garden
My victa 4013tx will not drive . the drive belt is on and correctly tensioned but have no drive. was working fine when last used but had a flat tyre when i went to use it and all i've done is removed and...
You removed the rear tire?
My first guess is there is a "key" that holds the tire to the axle. It will be a piece of steel about 1/4 inch square and 1 inch long or a Woddruff key like the one pictured below. Go back to the location where you removed the wheel and find it. Remove your wheel and reinsert the key. toolboxhero_1.jpg
Jan 11, 2011 | Garden
I have a problem with my ride on mower. we need to replace the belt that drives a twin cutting disks on a Victa 4013TX but cannot find any diagrams to help.
4013 HT is a Victa with a 13hp briggs and stratton engine normally with a twin blade 40in deck. These were badge engineered Noma mowers and essentially equivalent to murrays made at the same time. Check diagrams for murray decks to find one with the same deck configuration.
Jan 08, 2011 | Garden
Need manual for Victa - 3012TX -11.5HP I/C Industrial - 5 Speed Transaxle - Ride on mower
Check this link out for exploded views ... maybe will help
http://www.krysiak.pl/download_files/MURRAY/31721X88B.PDF
Oct 17, 2010 | Garden
Would anyone know where Icould get a manual for victa ride on 4013TX mower please. Darrill
Darrill, Your machine is the same as a Murray Model 40506X88A however the bad news is that Murray does not have it on line, Their instructions are to "contact Murray" for the manual.
In doing a GOOGLE search, I did notice there were a couple of them on E-Bay, Aus. and a machinery dealer in Aus. that sells them
Oct 12, 2009 | Garden
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
57 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
