Question about Maytag MHWE300VF Front Load Washer
How do i put the metal ring back on the door seal
THE SEAL CAME OFF PARTIALLY AND WHEN i OPENED THE DOOR THE METAL RING FELL OUT
4 Suggested Answers
woobie dog
  • 1273 Answers
SOURCE: FRONT DOOR OF WASHER LEAKING
Hello. W/D here.
It's actually pretty easy to get it back on when you know the trick.
Since it has leaked on you, you may want to remove the seal off of the rim closest to the door and clean the rim and the sealing surface. The seal has a molded lip that fits on to a raised formed rim, and it gets pressed on snugly before the ring and spring are added. You can seat the seal by pressing on it all the way around with the palms of your hands.
To install the ring:
Start the ring 180 degrees from the spring, placing it in the groove behind the seal face. (You want to make sure that the seal is pressed back into place first). Work the ring on around the seal, until you get to mostly just the spring remaining. Now lever the spring over the lip and into the groove, using a small screwdriver, being careful not to damage the seal with the screwdriver.
Best regards, --W/D--
Posted on Aug 20, 2009
SOURCE: Amana NFW7200TW washer - door seal ring has detached
The ring is a clamp that keeps the rubber part, called the bellow, attached to the front panel of the washer. To reinstall hook the edge of the bellow around the lip of the opening in the front panel (the hole through which you put your laundry). Then take the clamp and seat it in the groove of the bellow behind the lip of the front panel. The spring on the clamp should pull the bellow tight to the opening of the panel.
Like so:
Posted on Dec 11, 2010
oldTech2332
  • 2341 Answers
SOURCE: the metal wire ring fell
With it being off centered and the seal retainer coming off what needs to checked is the concrete counterweight thats bolted to the front of the tub has come loose and wobbling free.
Gene
Posted on Aug 05, 2011
Like so:
Jun 11, 2010 | Maytag NFW7200TW Front Load Washer
Replace LG washing machine seal
Hi
When you open the machine door, you will see a manufacturer's badge. Record the model number and call around to order the door seal from your local parts vendors. Have the replacement seal ready when you are changing the seal. If you remove the seal and then go to source it, then you might not remember how it was put on initially.
To replace door seal, First turn off machine and unplug from its power source.
Next remove top lid. Two screws in the back of the top lid and you can slide the lid back and up to remove. See if you have a clear view of the door seal from above the machine and see how it is joined to the drum mouth. There would be a metal ring holding it in place. Locate the screw which tightens it and unscrew it to loosen the ring.
Next the wire ring which you have already seen on the front of the seal needs to be removed. These are normally spring loaded. Feel around the ring until you get to the spring tensioner. With a flat screw driver, stretch the spring to pull the ring out from around the seal.
Now observe how the door seal is clipped around the front panel of the machine. The seal has a groove which fits snug agains the rim of the front panel. You can now remove the seal by pulling around the edge.
Now go back to the top of the machine and do a similar thing to remove the seal from around the drum. Make sure you observe how it had fitted on originally, and also observe if there are any differences between the top and bottom of the seal where it sits on the door. There normally is a difference.
When replacing the seal in the reverse manner, make sure you fit the seal correctly around the lips of the drum and the front panel. make sure you also correctly tighten and refit the rings to hold the seal in place.
Once you have finished run a couple of quick cycles without cloths, to make sure there are no leaks and that the seal is fitted properly.
Good luck.
Ash
Nov 09, 2009 | LG Washing Machines
I am having problem putting anew door seal on a
hello it a tricky job ,take the top off the washer look down you should see a metal ring with a screw on it . unscrew the the ring it should come apart . then you be able to pull the seal off . the on the front of the washer around opening of the door is a clip with 2 screws unscrew this there should be a metal wire take this off and pull the seal off and the whole seal should come off when you put the new 1 on put the seal on the drum first and don't forget to put the metal ring back on all the best
shaun
Aug 07, 2009 | Washing Machines
Metal ring fell off
If you are talking about a small metal hoop with a spring on one end, it is the outer bellow retaining clamp. The bellow is the rubber door seal. The retaining ring inserts into a groove in the rubber seam around the perimeter of the door where it attaches to the door frame. To reinstall, first make sure the door boot is fitting snugly around the door frame opening. Sometimes when the retaining spring comes loose, the rubber may pull away from the door frame. Beginning at the top of the door, start inserting the wire hoop back into the groove. Make sure the wire spring points towards the bottom. As you work your way around the door to the 4 and 8 o'clock positions, you will need to maintain some constant downward pressure while pulling the spring apart in order to snap it back into place with your thumbs. It would be advisable to use a second set of hands to hold the wire hoop in place while doing this as it has the tendency to want to come out of the groove.
If this is not the spring you are talking about, please post back and elaborate a bit more on what the part looks like to see if I can assist you better. (i.e., size, dimension, where you found the part, etc.)
I hope you find this information helpful.
Jun 30, 2009 | GE Energy Star WCVH6260F Front Load Washer
Bellows seal is not sitting properly and metal ring has fallen out
The following link explains how to replace a door bellow. Towards the end of the link, it explains how to reseat the wire retaining ring:
http://www.fixya.com/support/r385211-replacing_door_bellow_whirlpool_duet
This is not a difficult repair. It can be a tedious, but you can accomplish this easily with a little help. I hope this helps you.
PS I hope you held onto the retaining ring. If not, you will need to order one. Searspartsdirect.com carries replacements.
Aug 14, 2008 | Whirlpool Duet GHW9150P Front Load Washer
We have just bought a new door seal for a indesit washing machine please advise how to fit.
Hi to replace the seal take off the metal ring with a small screwdriver at the spring on the front of the machine than take off the seal then take the top off the machine and locate the screw on the metal ring undo a bit then take off seal replace and put back the new seal in reverse order as I have written
Jul 18, 2008 | Indesit Washing Machines
Kenmore HE 110.4751 front load
soild metal part fits in groove around door boot spring goes in at bottom they can be tough to get back on after inserting in groove around seal you'll have to stretch the spring and pop it under at the same time band will try to come back out and roll seal back off lip..good luck
Jul 16, 2008 | Kenmore Elite 45986 Front Load Washer
Rubber sean and wire spring came off
Hi
Spring should be a the 6 o'clock . you may need someones help have some hold the wire on at 15 and 45 ... when you pull the spring apart and slided it under the bellows. be careful as the spring can fly off. good luck and keep trying...
Apr 05, 2008 | Bosch WFR 145 Front Load Washer
Metal ring aroound rubber seal fell off.
Start with the spring at the bottom, work the retainer around until the seal starts to pull away from the washer. Now grip the loop that the spring attaches to on the side that isn't in place and open the retainer. Push the retainer in place and release the spring.
Jan 09, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Maytag MHWE300VF Front Load Washer Logo
19 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
