Question about Dryers
Roper gas dryer not heating - Dryers
  • Dryers Master
  • 8,220 Answers
ROPER DRYER INFO
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jan 08, 2013
tony2155
  • 64 Answers
SOURCE: my roper gas dryer is not heating up,
check the ignter and or fuse
Posted on Jul 01, 2009
SOURCE: Roper Gas Dryer
Taking the back off the dryer towards the bottom in the center there is a white pc.of plastic about 3 inches long and 3/8" wide. Its clipped on the inside panel and has a screw securing it. It has two wires clipped to it.Thats the fuse ! I got a replacement form the local Sears parts store for about $15.00.
Posted on Dec 31, 2007
  • 163 Answers
SOURCE: My Roper Electric Dryer will not heat
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Posted on Dec 26, 2008
SOURCE: my Roper gas dryer runs, but will not heat up in
gass dryers have what they call an igniter it is either electronic or a ceramic stater check to see if it sparks or if in case its ceramic it glows look by the gas inlet and determin which one you have the ceramic igniter looks like a little torpito it just un clips the electronic starter takes a little knowlege allways disconect power before servicing good luck
Posted on Apr 12, 2010
aasc
  • 1606 Answers
SOURCE: MY ROPER DRYER QUIT HEATING STILLS WORKS NO HEAT
The thermal cut-off , which is the small t-stat looking piece located at the top of the element housing ( on vertical mount elements ) or the far front of the element housing ( on horizontal mount elements ) , is usually the cause for no heat .
Posted on Aug 02, 2010
Roper Electric Dryer...model RED4440XQ0 will not heat.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 04, 2011 | Roper RES7646KQ Electric Dryer
Roper gas dryer has no no heat. not really sure of dryer #. but this is the basic set up.
heatman101[
Mar 24, 2011 | Roper RGX4634KQ Gas Dryer
Roper gas dryer won't heat,even after installing a new inginter what else
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jan 19, 2011 | Roper RGX4634KQ Gas Dryer
Want heat roper heavy duty dryer
heatman101
Dec 14, 2010 | Roper REX4634KQ Electric Dryer
Roper gas dryer does not heat, timer does not move, runs continuously, can the timer malfunction cause dryer not to heat?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 22, 2010 | Roper Dryers
Low heat from roper clothes drier
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 13, 2010 | Roper Dryers
ROPER GAS DRYER WILL NOT BUT RUNS
heatman101
Aug 13, 2010 | Roper REX4634KQ Electric Dryer
Roper dryer gives off no heat
heatman101
jjk
Nov 24, 2009 | Roper RGX4634KQ Gas Dryer
Roper gas dryer does not heat.
If the ignitor is not powering , go to the switch. That has to send power to the ignitor, then on to the gas valve.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jul 22, 2009 | Roper RGX4634KQ Gas Dryer
Dryer tumbles, no heat
its a gas dryer it doesnt have ,,heating element...replace thermal fuse
Dec 28, 2008 | Roper RGX4634KQ Gas Dryer
Dryers Logo
Top Dryers Experts
