Question about Maytag Neptune MAH5500B Front Load Washer
Water goes in but doesnt come out
Just got the pipes unfroze and the water is now going in the washer..why is it not coming out into the tub?
  • hello_79 Jan 23, 2009
    i show to one of person which can repair it. he said to me that machine control connector/wire one of it burn. so can you tell me what i should do it. if i want to replace that timer motor sheet, how much it cost me?
  • lorenzo banks
    lorenzo banks May 11, 2010
    Hi!!!!! You stated that water was now going into the washer .so whats your problem?Explain please!!!
  • 90 Answers
Possibly, chunks of ice, may be blocking the entrance to the tub or still blocking some of the pipes, to where there is not enough water pressure to fill the tub.
Posted on Jan 23, 2009
Ge washer leaks during spin
you may have a slow drain in the stand pipe causing the water to back up. Do you have a laundry sink near the washer you could try and pump in to and see if the water goes out more quickly? May not be the washer at all.
Apr 02, 2013 | Washing Machines
Water dripping under the rim, into the tub
Sounds to me like you have a siphoning problem You probably have your drain hose too far down in the drain pipe. When this happens the drain hose goes into the trap of the drain pipe. It then pull the water from the drain pipe back into your washer cause it cant break the vacuum. Pull your drain hose up so that on a little bit of the pipe is sticking down the drain pipe
Aug 25, 2012 | Maytag Washing Machines
When the water is entering the tub it immediately goes out the outflow. The tub will not even fill up a little bit. What could be the problem? thanks
The drain hose outlet must be located higher that any expected water level in the tub. If too low, gravity drains the tub as it is filled. Extend the (a) drain pipe up to the proper level, even if you are using a floor drain to carry away the water. Hope this helps!
Jan 27, 2011 | GE WDSR2080D Top Load Washer
My washer wont aloud my water to go insidethe washer
If the washer makes a humming sound, but no water goes in, and there is no other action, the water shut-off valve is off (outside the washer), or the pipes are frozen.
For top-load washers: If the washer starts agitating immediately without filling the tub, the water level switch is bad (falsely senses the tub is full already) or the water level sensing hose plugged up while there was water in the machine, and it has still has pressure inside it to fool the level switch.
Nov 27, 2010 | Maytag Washing Machines
This might be a plumbing problem but it only happens when I do a load of washing. When the water drains it goes into a pipe in the wall and then my bath tub fills up and the bath drains .when the water is...
your drain line is plugged up or broken somewhere in the yard,,,try running a pipe snake and see what you come out with,,,come out with mud-you have a broken pipe drain from a tree root!
May 14, 2010 | Washing Machines
Water overflow when tub is emptying during spin cycle
It sounds more like you have a drain problem that a machine problem. Try draining into the laundry tub and check that the tub drains quickly enough. If not, you have a plumbing problem...Good luck...Nomess
May 14, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
My he3t washer when water goes in tub it leaks
most liklet to be a split pipe under the mashine lay it onits side and look under it at all the pipes replace the loos or split one
Oct 25, 2009 | Kenmore HE3T Washer
Water will not stay filled in tub on rinse cycle
It sounds like a siphon issue.
Check that the drain hose does a high loop before it goes into the drain pipe. (ie. drain hose loops above the water level inside the tub). Make sure the drain hose is not pushed too far down into the drain pipe. Also if the drain hose is sealed to the drain pipe this will create an airlock and a siphon will occur, allow air to enter between drain hose and drain pipe connection.
This should help you but if there is still a problem let me know and I'll try to assist you further.
Mar 21, 2009 | Maytag Washing Machines
Whirlpool top load
sphion effect...your hose is to low must come up height of machine before it can go down....or you have unit straight to your waste pipe...onthejob
Jan 12, 2009 | KitchenAid KAWS850L Top Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
